POV-Ray : Newsgroups : povray.beta-test : material_map bug in v3.8 beta 2 Server Time
12 Sep 2025 21:27:49 EDT (-0400)
  material_map bug in v3.8 beta 2 (Message 1 to 10 of 10)
Subject: material_map bug in v3.8 beta 2
Date: 16 Jan 2025 05:22:17
Message: <6788ddd9$1@news.povray.org>
(The bug can be avoided by never using image interpolation)
While working on a renamed and refurbished material_map{} feature for
the yuqk fork, ran across a bug where non-indexed / non-palette image
was - by numerical noise - sometimes slipping into an indexed state of 0
when interpolation was used. This happening no matter whether the base
image was indexed or not.
The bug traced to two functions in imageutil.cpp called
InterpolateBicubic() and Interp(). These are general routines so the
exposure touches any code which looks at the calculated 'index' value to
decide later actions.
The fix I used was to apply rounding rather than a cast to int when
returning the index value - which is always calculated alongside the red
/ grey color channel. (Yes, the index values themselves are interpolated
too for actual indexed images)
In InterpolateBicubic() change:
   *index = (int)tempIndex;
to:
   *index = (int)std::lround(tempIndex);
In Interp() change:
   *index = (int)temp_index;
to:
   *index = (int)std::lround(temp_index);
Find attached a sample scene for v3.8 beta 2 and an image where the top
portion shows noise from the bug and the bottom being the yuqk fork's
current output for the same set up with the fixes above applied.
Bill P.
Download 'image_indexed_textures_v38.pov.txt' (2 KB) Download 'material_map_bug.jpg' (198 KB)
Preview of image 'material_map_bug.jpg'
Subject: Re: material_map bug in v3.8 beta 2
Date: 18 Jan 2025 09:10:00
Message: <web.678bb62c89dcc098e83955656e066e29@news.povray.org>
[using v3.7.0 and v3.8 beta 1 in Windows 10]
The material_map feature is new to me; I don't think that I have ever used it in
a scene-- probably because I never use 'indexed' images. But your post spurred
me to take a look at the documentation, and to try it out.
Instead of using a true indexed image, I decided to make a typical .png 24-bit
image for use in the map, by following the docs' example code at  "2.3.5.11 When
All Else Fails: Material Maps". (The material_map pattern still makes use of
so-called 'indices' in the image, but they are the red-channel gradations of
0/255, 1/255, 2/255 etc, rather than 1,2,3 etc.) I rendered this initial image
with *no* antialiasing, which makes a big difference...and *no* interpolation
later, when I used it in the map.
So far, I have not been able to reproduce the 'noise' that you mentioned-- but I
discovered something else: Once I carefully made the preliminary image for the
material_map, and added the required number of textures to correspond to the
'indices' of its red-channel steps, the final rendered texture results did not
quite correspond correctly to the indices: A few textures were missing.
After a lot of double-checking of my code and some experimentation, I made a
'lucky informed guess' as to the cause: It turned out to be a gamma issue. To
make the initial image for use in the material_map, I had used assumed_gamma 1.0
as usual, and with my File_Gamma as 'srgb' (as usual). But this 'mis-match' of
gammas caused the problem! So I re-made the image, keeping assumed_gamma at 1.0
but *changing* the File_Gamma to 1.0 to match it-- and the missing textures
appeared correctly in the final material_map render. (Using assumed_gamma 2.2
and a matching 2.2 File_Gamma also solves it.) Apparently, those two gamma
values need to be the same for that initial render, so that the material_map
code will then work correctly with it under-the-hood.
I don't yet know if this problem affects true 'indexed' images.
This solution leads me to believe that, when the material_map code was first
implemented in POV-ray long ago, the various gammas of rendering might have been
different than they currently are... possibly with a gamma of 2.2 being used
across-the-board, or by default. That's my guess.
Date: 18 Jan 2025 11:54:55
Message: <678bdcdf$1@news.povray.org>
Thanks for the feedback. I think I need to tweak my documentation on
gamma. Up front I recommended it not be used because I assumed these
'indexed aimed' images would be written at a file gamma of 1.0 where the
red channel was used, but you're right, ultimately gamma while reading
an image file needs to match the gamma encoding for the image (*) when
it was written. Excepting indexed images, for which the gamma settings
should not matter.
(*) - IIRC the default srgb set up with png files for recent official
v3.8 releases has an issue where the srgb block is not being written.
This was fixed in the yuqk fork.
Did you intend to attach an image to your post?
The noise issue can only show up if one of the interpolation modes is
used. It's more likely to be there for interpolations 3 and 4. It didn't
show up for me always with linear interpolation. In being numerical
noise, it might be somewhat sensitive to compiler settings too.
Bill P.
Date: 18 Jan 2025 20:25:00
Message: <web.678c544589dcc0981f9dae3025979125@news.povray.org>
So, I may be way off base here, but I just wanted to speculate, to promote
clarification of what's going on.
It occurred to me that what Kenneth might be seeing is an artifact of one gamma
"stretching" the color values sufficiently so that they skip over some of them.
I now also wonder if he's missing a "compression" in another part of the
mapping, where one value gets represented twice, and so it _looks_ like a single
instance.
Probably something to do numerically rather than graphically to really see
what's going on.
Just some thoughts.
Date: 19 Jan 2025 05:35:00
Message: <web.678cd1d689dcc098e83955656e066e29@news.povray.org>
I was going to originally, but the image may not have been very informative
without comparing it the test code I used. So I have attached the code here
instead.
It uses a switch, to first *create* the 24-bit .png image-- which needs to be
renamed as "MMT" --then to use that image to run the material_map/textures
result. (This code is my own slight re-working of the documentation's example
and uses only five texture entries in the material_map.)
I didn't know that. Although, for all of my usual .png renders in 3.8 beta 1,
Ive's IC app reports them as having the correct sRGB embedded gamma.
from BE:
> gamma "stretching" the color values sufficiently so that they skip over
> some of them. I now also wonder if he's missing a "compression" in another
> part of the mapping, where one value gets represented twice, and so
> it _looks_ like a single instance.
I have been contemplating that idea as well, if I understand your meaning. For
example, an sRGB 'File_Gamma' has a slightly different 'curve' from straight 2.2
gamma, at the low and high ends of its brightness(?) representations (if I
understand this stuff sufficiently.) And both of those gammas vary greatly from
a straight 'linear' gamma 1.0, of course. So numerically, these odd combinations
between assumed_gamma and File_Gamma don't match-- which will throw off the
material_map's indices of textures vs. red-channel brightness values.
To truly see where all of these differences occur in a material_map, an
interesting experiment would be make the 'preliminary' .png image with 256
distinct levels of brightness in the red channel-- and then to create 256
different texture entries in the material_map, to correspond! (I think my posted
code here could probably be re-jiggered to automatically do all of
this...although the visual result might be a bit difficult to interpret in a
meaningful way!)
Download 'material_map_tester_kw.pov.txt' (2 KB)
Date: 19 Jan 2025 08:16:08
Message: <678cfb18$1@news.povray.org>
Thanks for the scene code! :-)
I don't have a v3.8 beta 1 compile currently and I cannot find the
newsgroup post where I wrote about the png, sRGB block bug...
Using your scene; Once I have created an MMT.png file (using
file_gamma=1.0 on the command line), if I run:
   p380b2 material_map_tester_kw.pov
I get an output file size of 6625 bytes. When I use the command:
   p380b2 material_map_tester_kw.pov file_gamma=srgb
I get an output file size of 6638 - because the srgb block has been
added with the latter command (13 bytes larger). It's not there by
default and should be (and for a LONG while it was. It should be there
in v3.7 renders, for example). Our default gamma handling in v3.8 is srgb.
You can 'see' whether the srgb block exists in any png file by looking
at the first 100 bytes or so in an editor or by using a command to write
those initial bytes to the screen of a terminal window. On linux:
'head -c100 my.png'
	�PNG
IHDR 'gAMA��
             �asRGB���s��O�tIME�
               above
When you run v3.8 beta 1 without using 'file_gamma=1.0' on the command
line (or as an ini setting), do you see the sRGB text in the png file?
The sRGB block being missing leads to an inconsistency where we cannot
make a read-->immediate_write, srgb round trip of an png image through
POV-Ray without image changes.
On the interpolation noise bug, I ran your scene with 'interpolation 3'
and I do see it with my v3.8 beta 2 compile (top). See attached image -
the current yuqk result on the bottom.
With the traditional material_map implementation, if you have in the
index control image (MMT.png), indexes larger than the length of the
texture list it gets wrapped back onto the list with a sort of
'mod(index,txtr_list_length)'.
I thought this approach confusing. Now in yuqk, the map overruns are set
to the index zero texture.
Regions outsides the effective mapping and/or 'once' area (or to actual
indexed image indexes which are transparent I believe) already get
mapped to the zero index. I think it makes sense to map out of bounds
indexes to the zero index in the same way.
Bill P.
Download 'material_map_tester_kw_noise.jpg' (51 KB)
Preview of image 'material_map_tester_kw_noise.jpg'
Date: 19 Jan 2025 08:50:01
Message: <web.678d026f89dcc098f3dafc4d6cde94f1@news.povray.org>
hi,
> line (or as an ini setting), do you see the sRGB[**] text in the png file?
no, you're correct.  have attached output of a quick 'hexdump'[*], comparing
images rendered by beta.2 and the recent yuqk.
[*] easier to read :-).
[**] another "easy" one for the 1st commit ;-)
regards, jr.
Download 'betavyuqk.png' (40 KB)
Preview of image 'betavyuqk.png'
Message: <web.678d02a689dcc0981f9dae3025979125@news.povray.org>
> instance.
> what's going on.
> Just some thoughts.
One thing you might try is, rather than use png, use gif.
https://en.wikipedia.org/wiki/GIF
It seems that gif exclusively used an indexed color palette (color look up
table).
Then you can simply open the gif in IrfanView, and use Image > Information, and
it will tell you how many unique color indices you have.
If you're going to do graphic / visual experiments, it might be worth assembling
a color_map such that your color entries are non-adjacent in the color wheel.
So, all of the even entries would be "monotonically" increasing from 0, and all
the odd entries would get shifted - say, by adding 127, and taking mod(N, 255)
to get the result that's "wrapped around to 0".
That way, you get maximum contrast between color indexes, and might be better
able to see doubled entries.
You'd need hard stops in your color map to prevent interpolation between
entries, and then you could simply render a smooth gradient across a wide image
format (1920 x 1080).
- BW
Date: 19 Jan 2025 10:00:00
Message: <web.678d128a89dcc098e83955656e066e29@news.povray.org>
> [The srgb block is] not there by
Ah, I see what you mean now. Yes, if I leave out an explicit File_Gamma=srgb
when running a render in 3.8 beta 1, Ive's IC reports the image as having a
'vanilla' 2.2 gamma instead, when it should be srgb 'by default'.
Sorry to say that I don't have an appropriate editor to check that in Windows
(unless there is some trick that I don't know of!)
Yes, I see a bit of speckling even with interpolate 2, and far worse noise (like
your example) with interpolate 3 and 4.
Yes, that sounds like a more logical way of doing it, and more understandable as
to the visual result. (The documentation about "taking modulo N" is not very
easy to mentally visualize, ha.)
Date: 21 Jan 2025 08:05:00
Message: <web.678f9b6389dcc098e83955656e066e29@news.povray.org>
My apologies, Willaim: I mis-quoted your reply, which probably made my own reply
a bit confusing. It should have been the following:
[Kenneth:]
   {because I use an explicit File_Gamma=srgb]
[William:]
[Kenneth:]
'vanilla' 2.2 gamma instead, when it should be sRGB 'by default'.
When running 'official' v3.7.0 instead, the 'default' File_Gamma is indeed sRGB,
as you mentioned.
