POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0-beta.1 issue #410 Server Time
22 Dec 2024 04:36:56 EST (-0500)
  POV-Ray v3.8.0-beta.1 issue #410 (Message 1 to 10 of 23)
Subject: POV-Ray v3.8.0-beta.1 issue #410
Date: 3 Aug 2021 12:05:00
Message: <web.610968fb83d5a85b5e0fed26cde94f1@news.povray.org>
hi,
> The unix folder in our repo is littered with various files ...
> Make recommendations how to get them back up to snuff if they
> could still be of use.
regarding 'unix/icons/*.png'.  I think they could be installed under
'/usr/share/icons/', perhaps '/usr/share/icons/POV_Ray/'?  would require
organising them by size, and renaming, to accommodate the existing conventions.
benefit: would be available in "desktop environments" (Gnome/KDE/etc).
the 'install' and 'README.*' weren't included in the 'povunix' tarball.  the
'*.x?m' files could go under '/usr/share/pixmaps/', I suggest.
(either '/usr/share/' or '/usr/local/share/' would do.)
regards, jr.
Subject: Re: POV-Ray v3.8.0-beta.1 issue #410
Date: 3 Aug 2021 14:23:20
Message: <61098998$1@news.povray.org>
Am 03.08.2021 um 18:04 schrieb jr:
I'm not 100% sure about the `README.*` files off the top of my head, but
`install` should be present in the main folder of the tarball as `INSTALL`.
Date: 4 Aug 2021 02:35:00
Message: <web.610a34215f6dda2a5e0fed26cde94f1@news.povray.org>
hi,
ah, found the 'README.*'s -- once I looked in the correct directory.  (will get
back on these in a couple of days)
regards, jr.
Date: 5 Aug 2021 06:10:00
Message: <web.610bb7f35f6dda2a5e0fed26cde94f1@news.povray.org>
the 'NEWS' file makes it clear the release is source only, so 'README.bin' could
simply be deleted.  the 'README' and 'README.md' files are, essentially,
identical. suggest updating the 'Dependencies' and 'Generating configure..'
sections in 'README.md', and rename that to 'README'.  the 'README.unix' too
needs some updating (from v3.6); I think that file will become (more) relevant
again (cf X support).
the 'ChangeLog', 'AUTHORS', 'COPYING', 'NEWS', and 'README*' files ought to
"migrate" to the archive's top-level directory.
regards, jr.
Date: 5 Aug 2021 09:59:15
Message: <610beeb3$1@news.povray.org>
Am 05.08.2021 um 12:05 schrieb jr:
That's where they currently are in the tarball, are they not?
Date: 5 Aug 2021 10:35:00
Message: <web.610bf63b5f6dda2a5e0fed26cde94f1@news.povray.org>
hi,
I was looking at the /unix/ files (only).  duplicates can just be deleted.  the
'README.md' in the top-level dir is newer, still suggest that should become
"the" new 'README'; then only 'README.unix' needs moving up.
regards, jr.
Date: 5 Aug 2021 11:15:37
Message: <610c0099$1@news.povray.org>
Am 05.08.2021 um 16:31 schrieb jr:
No, not really. `README.md` is specificially aimed at someone looking at
the entire repository package (or, even more to the point, someone
looking at the repository on GitHub).
The `README` in the Unix-specific package should be aimed specifically
at someone looking at that particular tarball.
Date: 5 Aug 2021 12:05:00
Message: <web.610c0b855f6dda2a5e0fed26cde94f1@news.povray.org>
hi,
then, surely, it should be on github, and not in the archive; a paragraph in the
'README' with repository url would suffice (to my thinking).
agree.  and that tarball will already have been downloaded.  so I'd be looking
for intro/overview + general instructions - only.
anyway, the whole thing makes me wonder why you .. bother.  *NIX-ness is not a
high priority for you, I feel, so why even have tarballs?  would just "git
clone" not be preferential?
(this rant is "tainted" -- probably -- by your mentioning that even the POV-Ray
development code resides "in the cloud" now rather than on own(ed) server(s))
regards, jr.
Date: 6 Aug 2021 06:33:34
Message: <610d0ffe@news.povray.org>
Am 05.08.2021 um 18:02 schrieb jr:
I think that's a severe misunderstanding.
My *NIX expertise is very low, that's why I'm not doing much for *NIX.
That doesn't mean I don't care. It just means I can't do.
It has been ever since we moved to a Git-based solution, right at the
time of the 3.7.0.0 release.
And to be frank, the GitHub infrastructure around the repo has been
quite an asset in the development work ever since. With the manpower
available to us, it would have been impossible to set up (let alone
maintain!) anything even remotely like it on our own turf.
As a matter of fact, *NIX-ness might have been the feature to benefit
most. With the dev team stocked pretty much with pure Windows jockeys,
automated test builds were the only thing that had us on our toes
regarding *NIX-incompatibilities. Setting up such facilities on our own
would have required quite the effort.
Automated test builds also helped a lot to get us through the times when
C++11 and clang both started to see widespread use, sending additional
ripples across the boost library, and opened up new portability pitfalls
due to incomatibilities between ever shifting boost versions, certain
constructs that turned out to no longer work in C++11, and the like.
With us Windows jockeys having no (or only cumbersome) access to a truly
C++11-compatible (let alone C++11-strict) development environment back
then, the availability of not just one but three(!) independent
free-for-open-source hosted build test services was invaluable to keep
POV-Ray compatible with all the fast-changing world of C++ back then,
both the established and the emerging.
We also got some feedback and contributions via GitHub that we might not
have gotten otherwise. Certainly not on as large a scale as in CompuServ
times, but still.
Among those who got into touch with us were the folks who maintain the
"homebrew" packages to provide *NIX software for MacOS. Which put
official MacOS compatibility back on the menu, after it had already
dropped off the back of the truck in the years prior.
The issue tracker also proved useful, if only because it meant we no
longer had to waste time keeping spammers out of our self-hosted bug
tracker.
And the fact that *NIX tarballs are back on the menu is also courtesy of
GitHub, because as we now migrated all the automated build tests from
3rd party services to GitHub's new own, we found that we could easily do
additional stuff whenever we were to auto-build Windows binaries. Even
stuff that would require a *NIX machine to run. (Or a MacOS machine, for
that matter, but that's not a thing that has manifested so far). So we
added *NIX tarballs to that build process.
And a developers' manual, just because we could. I had already set up a
few scripts and configs for that purpose years ago for my own use, but
never got around to setting up a channel for publishing the generated
documents.
Which is another boon of GitHub: It is so much easier to set up a new
release there, with any arbitrary set of associated downloadables, than
it would be on our own web server.
Which is what has gotten you folks each and every alpha release since
v3.7.0.0. I have no access to the web server to bundle up and publish
releases there, and I wouldn't have dared to bother Chris with anything
other than betas or better. Let alone that it would have taken a couple
of days minimum (if not weeks) for each such release to eventually make
it onto some downloadable page.
I wouldn't even have seen the benefit of such releases in the first
place. It was more a matter of, "hey, we can do this on a regular basis
with almost zero effort, so why not."
And I won't even mention the occasional experimental build, such as the
OpenType support builds.
Even whether beta.1 would be out yet, without GitHub's ease of deploying
software, is anybody's guess. It might still be in the pipeline between
me and Chris Cason. Or I might still be procrastinating about even
actually running the build process on my local machine. Having GitHub
run it is so much easier and leaves far less room for PEBCAK errors,
once the process has been set up.
There's no fault in being somewhat suspicious of 3rd party services like
GitHub. But let that not blind you to their benefits.
Division of labour has been one of the most efficient strategies in the
history of humanity, and this is just another application of that principle.
Date: 6 Aug 2021 09:50:00
Message: <web.610d3c9a5f6dda2a5e0fed26cde94f1@news.povray.org>
hi,
glad to read this.  (very) probably I read too much into things.  (like your
post re declare=X=Y syntax, where you wrote using a "faux Windows command line";
cannot imagine a shortage of (computing) resource on your side, so wondered why
isn't he using a VM with a BSD or some Linux, then a "real" command-line would
be at hand)
> times, but still.
additional channels of communication is useful.
> documents.
moot, of course, but wonder whether publishing that to the wiki would have been
so very different (time+effort-wise).
personally, my main "beef" with such sites is that in order to orient myself and
look at some info, my browser has to divulge all sorts of info about the system
it's running on.  and a requirement to create an account just to comment/add an
issue? when a captcha to confirm it's not a bot would do.  (the IP address is
logged anyway)
sure.  true also of alternatives, like eg 'fossil'.
regards, jr.
