POV-Ray : Newsgroups : povray.beta-test : Pre-Release Expired Server Time
30 Sep 2024 02:14:48 EDT (-0400)
  Pre-Release Expired (Message 1 to 10 of 10)
Subject: Pre-Release Expired
Date: 15 Apr 2004 01:25:00
Message: <web.407e1c81f321750da94cf7e10@news.povray.org>
No matter what I do, with both beta2 and beta3 (I had this problem until a
little while before beta3 came out,) when I start up POV-Ray it says "This
pre-release version of POV-Ray for Windows has expired."  I've tried it in
98se, XP and XP 64-bit on 3 different systems.  I also tried uninstalling
and reinstalling but no luck.  Any ideas?
Thanks,
Tim
Subject: Re: Pre-Release Expired
Date: 15 Apr 2004 06:59:32
Message: <407e6b14@news.povray.org>
  Wait for the next release?
  If you *really* must use the beta version instead of 3.5 (which the beta
shouldn't have removed from your system by default), you could turn your
system clock back, but that's just ugly...
Date: 15 Apr 2004 13:04:22
Message: <Xns94CCC1ED278CBraf256com@203.29.75.35>
war### [at] tagpovrayorg news:407e6b14@news.povray.org
>   beta
> your system clock back, but that's just ugly...
And it will mess up other applications running on computer and can cause
serious problmes.
But POV checks time only at start-up.
Btw, I agree now that its a *good* idea that beta expire.
But for some special-cases like (I want to compare beta2 with beta3) etc,
how about an hidden option to start expired beta (i.e. command line option,
windows-register, some disk .ini file, etc)?
http://www.raf256.com/3d/
Computer Graphics
Date: 15 Apr 2004 13:14:25
Message: <d9gt70halmta0j0q4b64hmgbrncdul7s0p@4ax.com>
On 15 Apr 2004 13:04:22 -0400, "Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote:
> >   beta
> serious problmes.
If you are not prepared for serious problems then you are not prepared for
being betatester because betatesting means looking for as many as possible
problems in every aspect of using tested software.
ABX
Date: 15 Apr 2004 14:24:44
Message: <407ed36c$1@news.povray.org>
In article <Xns94CCC1ED278CBraf256com@203.29.75.35>, "Rafal 'Raf256' Maj"
You do not want a third reply to this one, do you?
    Thorsten
e-mail: tho### [at] trfde
Date: 16 Apr 2004 08:11:16
Message: <Xns94CD901A2369Eraf256com@203.29.75.35>
abx### [at] abxartpl news:d9gt70halmta0j0q4b64hmgbrncdul7s0p@4ax.com
> for being betatester because betatesting means looking for as many as
> possible problems in every aspect of using tested software.
How about zipping all releases with password that will not be reviled to
anyone? Thats a problem ;)
Computer Graphics
Date: 16 Apr 2004 12:00:00
Message: <web.4080026dbc19fd43a94cf7e10@news.povray.org>
The problem is I already have waited for the next release -- beta3.  My
computer clock is set right (on all 3 systems.)  It is April, 2004, is it
not?  What is the expiration date of beta3?  I'm going to go messing around
the registry.  This is weird.
Date: 16 Apr 2004 12:13:57
Message: <40800645$1@news.povray.org>
Program ended abnormally on 16/04/2004 11:57, Due to a catastrophic
Administrator error:
Beta 3 expired on April 15.  The next one should be available shortly... I hope!
Date: 16 Apr 2004 20:25:00
Message: <web.40807834bc19fd43a94cf7e10@news.povray.org>
Wow.  April 15 is kind of rediculous when beta3 only showed up a few days
ago.
> /*Francois Labreque*/#local a=x+y;#local b=x+a;#local c=a+b;#macro P(F//
> /*    flabreque    */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
> /*        @        */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
> /*   videotron.ca  */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 18 Apr 2004 08:29:11
Message: <40827497@news.povray.org>
> ago.
don't know what planet you were on the last two weeks; beta 3 was released
on April 1.
-- Chris
