POV-Ray : Newsgroups : povray.beta-test : semicolon not expected Server Time
18 Mar 2026 19:51:02 EDT (-0400)
  semicolon not expected (Message 11 to 18 of 18)
Subject: Re: semicolon not expected
Date: 7 Jan 2002 17:46:22
Message: <3c3a253e@news.povray.org>
"Christopher James Huff" wrote:
> If you wrap the conditional in parentheses, it will work fine
Yes, I use that trick all the time...
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Jan 2)
Date: 7 Jan 2002 17:49:16
Message: <jkJfWHAWefO8EwOg@econym.demon.co.uk>
>On Mon, 07 Jan 2002 13:18:44 +0100, "Thorsten Froehlich" <tho### [at] trfde>
>wrote:
>> Semicolons are listed as required after every #local, #declare and #version
>> with a float, vector or color value.  If you don't include the required
>> semicolon the problem is in your scene and the parser reports it as soon as
>> it is possible to report this.
>I think you misunderstand my report so I post shorter example:
>#macro Test2() #if(yes) 2 #end #end
>#local F=Test2();
>note: there is semicolon but parser expects object or directive
But POV macros behave as if they were *macros* not functions.
If POV macros behaved like *functions* then Test2() would return the
value "2". "2" is a float, so you'd expect a semicolon to be
permissible.
Since POV macros behave like *macros*, Test2() behaves as if it returns
the code "#if(yes) 2 #end".
So
        #local F=Test2();
behaves like the illegal statement
        #local F=#if(yes) 2 #end;
Note that this is legal:
        #macro Test2() (#if(yes) 2 #end) #end
        #local F=Test2();
Because that behaves like the legal statement
        #local F=(#if(yes) 2 #end);
Mike Williams
Gentleman of Leisure
Date: 7 Jan 2002 18:25:08
Message: <3c3a2e54@news.povray.org>
Mike Williams <mik### [at] nospamplease> wrote:
: But POV macros behave as if they were *macros* not functions.
  In fact, POV-Ray macros do not work like real substitution macros
(like the #defined macros in C).
  This:
    #macro A()
      #local a = 5;
    #local a = 6;
    A()
is *not* the same as:
    #local a = 6;
    #local a = 5;
  I think that at low-level the difference between pov-macros and C-macros
is that in the latter the macro body is truely placed in the place of the
macro call by the pre-compiler (and then the actual compiler sees just this
but has no knowledge of the original macro), while in POV-Ray the macro is
parsed where it is, without making a real substitution. The difference is
very tenuous and most of the time it has no effect, but in some cases it
has (like when you use #local identifiers inside the macro).
Date: 8 Jan 2002 02:18:03
Message: <e27l3uo56s3vv86e0rcf75ngov3v340ava@4ax.com>
On Mon, 7 Jan 2002 19:31:34 +0000, Mike Williams <mik### [at] nospamplease> wrote:
I agree paranthesis are best workaround but IMO there is no place in
documentation where above is listed as illegal.
ABX
Date: 8 Jan 2002 06:42:20
Message: <Xns91908178BAC86seed7@povray.org>
wrote:
> [..] IMO there is no place in
I'll see what I can do about it.
Ingo
Date: 8 Jan 2002 07:00:36
Message: <imnl3ugieel5s8n4du2t2noe339ctren0k@4ax.com>
Wait for the team. Perhaps it is yet a bug.
ABX
Date: 9 Jan 2002 12:53:56
Message: <3c3c83b4@news.povray.org>
No, if this worked the way in 3.1 it was by design hat only macros may
return data.  I don't see a point in changing something that worked this way
before without problems, also it doesn't work as one would expect as a
programmer it is still deterministic and an easy rule for users.
    Thorsten
e-mail: tho### [at] trfde
Date: 14 Jan 2002 16:06:36
Message: <slrna46i2u.bc5.ron.parker@fwi.com>
On 7 Jan 2002 09:00:15 -0500, Warp wrote:
>: #macro Test2() #if(yes) 2 #end #end
>: #local F=Test2();
>   Isn't the "right way" of returning values from a macro something like:
> #macro Test2() #if(yes) #local res=2; #end res #end
Except for that minor detail of it causing crashes when you return a local.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
