![](/i/fill.gif) |
CB wrote:
> On install, Linux 2.4.19-SMP on Opteron system was not recognized as a Linux
> PC. Required an install with -no-arch-check. No problems after that.
That is to be expected. Although the official binary will probably run
on an opteron it is surely better to compile from source (which will be
available soon).
> The -GA option on the command line seems to have quit working.
That's somewhat unprecise, you mean '+GAfile' does not generate a file
with the whole text output?
> Not sure if either is intended behavior or not.
> Please regard this as feedback rather than any defect report.
Since beta phase has ended this is in fact the wrong group for such a
posting (povray.unix would be correct).
Last updated 01 May. 2004 _____./\/^>_*_<^\/\.______
![](/i/fill.gif) |
![](/i/fill.gif) |
-GA should suppress almost all the output. It did. It doesn't.
![](/i/fill.gif) |
