Parts of the contained_by box shows up in this scene.
My system: Duron 700@900 Duron, 512 SDRAM.
Pov version 3.5 beta 1 on Windows 2000.
The iso appears as expected in MegaPov 0.7
#declare S=.4; // setting this to less than .5 gives strange results
#declare L=.5; // setting this to 0 still produces artifacts
isosurface {
function { L*sqrt(cos(x/S)) + y^2+z^2 }
threshold 1
max_gradient 10.77
accuracy 0.01
contained_by{box{-<.8,1,1>,<.8,1,1>}}
pigment { rgb 1 }
light_source { 5,1}
background{rgb 1}
camera {location 2 look_at 0}
ICQ 74734588
In article <abucpt89se7ck11gmj7hcv8f9643su0kth@4ax.com> , Sigmund Kyrre Aas
OK, so increase the size of the bounding box! What is want with that?
Thorsten
On Wed, 05 Sep 2001 15:37:35 -0400, "Thorsten Froehlich" >
Err, not sure what you mean.. bounding is done automatically.
ICQ 74734588
In article <149dpt01qbu5l4oro6b4mv2c7k1s6va00n@4ax.com> , Sigmund Kyrre Aas
Well, "contained_by" used to be called "bounded_by" and in some way it
bounds the function to a a limited space. Anyway, what i meant was that you
should change the container box.
Thorsten
e-mail: tho### [at] trfde
PS: Sorry for the cryptic sentence, but occasionally I don't pay attention
to the words my spell-checker suggests - "want" should be "wrong"...
Thorsten
"Sigmund Kyrre Aas" <as### [at] studntnuno> wrote...
Please note that "cos(0.64 / 0.4)" is less than one. This occurs well
within your contained_by box, which ranges from x=-0.8 to x=0.8.
Taking the square root of a negative number is not defined in real number
space. This is the source of your problem.
-Nathan
On Wed, 5 Sep 2001 19:45:30 -0400, "Nathan Kopp" <nat### [at] koppcom>
Right, thanks. I added abs() and now it renders fine. Sorry to bother
y'all with this.
sig
ICQ 74734588
