POV-Ray : Newsgroups : povray.beta-test : CSG Issues with disc shape. v38 beta 2. Server Time
7 Dec 2025 19:00:28 EST (-0500)
  CSG Issues with disc shape. v38 beta 2. (Message 18 to 18 of 18)
Subject: Re: CSG Issues with disc shape. v38 beta 2.
Date: 10 Oct 2025 15:57:31
Message: <68e9652b@news.povray.org>
On 9/30/25 19:36, William F Pokorny wrote:
>> POV-Ray screwed me.
>> "Unnecessary bounding object removed."
>> Might be time to fix that or update the bounded_by documentation page.
> You can manually bound, if you use '-ur' / 'remove_bounds=off'.
Ugh! In looking more at bounded_by{} and clipped_by{} myself of late, I
re-discovered / remembered - after thrashing a couple days - that
official versions of POV-Ray have this weird 3D volume test which limits
user specified bounding to that which is 'smaller' than the initial
automatic bounding volume. The code just does this "I know better than
the user bit," silently.
The yuqk fork removed the volume increase limiting code back in 2017. It
was always a bad idea for reasons - not the least of which is that it
often prevents users from working around automatic bounding which isn't
working correctly.
So... I was too flippant with my initial response with respect to
official releases of POV-Ray supporting manual bounding and +-ur /
remove_bounds=. Manual bounding is at least somewhat broken / limited in
recent official POV-Ray releases.
I'm working in yuqk mostly, and thousands of changes down the road, my
old head doesn't remember everything different relative to official
POV-Ray releases. I've been trying to get yuqk's documentation up to
date - largely for my own sanity in helping me remember changes like
these - but I'd not gotten to writing updated documentation for
bounded_by{} and clipped_by{}. :-( FWIW.
There are other yuqk manual bounding differences too. Another of note,
is that the official POV-Ray code will update bounding based upon the
clipped_by{} shape(s) alone (or by overriding bounded_by{}). The yuqk
fork only updates manual bounding based upon any bounded_by{} block(s)!
IIRC, using clipped_by{} to also manually bound was a v3.6 -> v3.7
change. In any case manual, bounding sometimes needs to be slightly
larger than any clipped_by{} specifications - we shouldn't be using
clipped_by{} to set or update bounding.
Bill P.
