POV-Ray : Newsgroups : povray.beta-test : Assigning an interior crashes 3.8 beta 2 Server Time
30 Mar 2026 13:31:37 EDT (-0400)
  Assigning an interior crashes 3.8 beta 2 (Message 1 to 7 of 7)
Subject: Assigning an interior crashes 3.8 beta 2
Date: 9 May 2023 09:14:14
Message: <645a4726@news.povray.org>
The following scene crashes with the error:
  line 4: Parse Error: std::bad_alloc
----------[BEGIN CODE]----------
#version max (3.5, min (3.8, version));
#declare Int = interior { ior 1.5 }
#declare myInt = Int
-----------[END CODE]-----------
The discontinued 3.7.1-rc.1 also crashes, but previous versions of
POV-Ray do not.
POV-Ray version: POV-Ray 3.8.0-beta.2 (self-compiled)
Operating system: openSUSE Leap 15.3 GNU/Linux
Hardware: Lenovo Ideapad Slim 7
CPU: Intel Core i7
Subject: Re: Assigning an interior crashes 3.8 beta 2
Date: 9 May 2023 09:45:00
Message: <web.645a4d41f1deef259b4924336e066e29@news.povray.org>
[in Windows 10, running official v3.8.0 beta 1, Lenovo desktop machine, Core i7]
These first 3 lines run OK...
Adding the 4th line...
...causes a fatal error-- but the error message changes(!)
If I freshly start POV-ray, the error says
       "Parse error: vector <T> to long"  (whatever that means).
Immediately running the code again, it's
      "Parse error: bad allocation"
By changing the 4th line to
      #declare myInt = interior{Int}
it all runs fine, no error.
Date: 9 May 2023 09:50:00
Message: <web.645a4f0df1deef259b4924336e066e29@news.povray.org>
I just tried a similar construct using a pigment instead of an interior--
thinking that the same error might occur...
#declare PIG = pigment{bozo}
#declare myPIG = PIG
... but that runs OK! So it seems that the problem might be exclusive to the
'interior' block... or ior... ?
Date: 9 May 2023 16:30:00
Message: <web.645aac2bf1deef2558c093306cde94f1@news.povray.org>
hi,
same for self-compiled 3.8.0-alpha.9945627.
regards, jr.
Date: 11 May 2023 07:49:58
Message: <645cd666$1@news.povray.org>
> POV-Ray do not.
> CPU: Intel Core i7
Thanks Cousin Ricky and Kenneth and jr for confirmations and tests with
other shapes. I've been looking at this, but will be away for a while
starting later today.
So, an update.
At the bottom the issue here seems to be that the first created interior
gets deleted before the copy in the symbol table code. There was an
attempt to move to smart pointers on removing the reference counting in
v3.7, and something went wrong there. I just cannot yet see it - or how
I might patch it.
The form and feel of this bug rings a bell. There was some other bug
recently due a similar move from reference counting to smart pointers
that I patched by creating a local copy of something to itself be what
was really copied because the original smart pointer controlled to be
copied version was going poof too quickly.
Bill P.
More for those interested.
a) What I suspect here and with that other bug (I can't completely
remember at the moment...) is that thinking a smart pointer can always
simply replace reference counting method is dangerous.
I believe what's happening is the reference counting previous had
different in timing with respect to when some allocated thing was
'counted' as no longer referenced then deleted than the scope based auto
magic happening with smart pointers to do the reference tracking and
deletion. I think the latter tends to clean up faster.
b) There is on top of the issue above another in that the template
function introduced in the symbol table code depends on there being a
valid form of an = type object copy. There was none.
Someone had added an explicit bit of C++ preventing an '=' overload for
the copy. I don't know why. I cannot see a reason for it.
So, I fixed things so there was a proper = overload as there is with
some other things (media, camera..) using the same template id copying
function in the symbol table code. But, the core issue was still there -
which didn't surprise me too much.
And why was that? Well in a happy world where C++ helps you, the
compiler would have just died on not finding the matching '=' copy. The
lack of the '=' copy was just something I noticed. My, unconfirmed,
suspicion is all the casting to void pointers happening within that
template function, bypassed the C++ feature preventing the original '='
sort of object copy of interiors.
Anyhow. No idea when I'll get back to this. The free time I'll have in
the coming weeks amounts to small run fragments.
Date: 11 May 2023 13:25:00
Message: <web.645d23e2f1deef251f9dae3025979125@news.povray.org>
Yeah - I vaguely recall that too.  Was it with the heightfield stuff?
Date: 28 Jul 2023 09:13:06
Message: <64c3bee2$1@news.povray.org>
> I might patch it.
I've spent a little more time on this and I don't currently see a clean
way to fix this issue. Well, other than returning to a plain pointer and
reference counting as in v3.7 (and v3.8 to some point during development).
Given how the parser is set up, v3.8 is running smart, shared, interior
pointers through casts to a void pointer and back to a shared pointers.
Pending an actual fix, I strongly recommend v3.8 add a throw in
symboltable.cpp just after the switch "case INTERIOR_ID_TOKEN:".
Something like:
throw POV_EXCEPTION_STRING("Interior ID = ID copies broken in v3.8");
While likely the garbage in memory pointed to after the attempted
interior ID copy will stink enough to crash code somewhere within
POV-Ray(a), a scene with such a copy could 'execute' without a crash -
if one is unlucky.
Bill P.
(a) - It's not the actual copy which crashes, but some later operation
on garbage data.
