POV-Ray : Newsgroups : povray.beta-test : Intended image_pattern, etc, warning not generated. (v3.8 beta 2) Server Time
25 Mar 2026 16:57:58 EDT (-0400)
  Intended image_pattern, etc, warning not generated. (v3.8 beta 2) (Message 1 to 1 of 1)
Subject: Intended image_pattern, etc, warning not generated. (v3.8 beta 2)
Date: 13 Mar 2023 16:30:27
Message: <640f87e3$1@news.povray.org>
Issue seen while playing with image_pattern{} vs image_map{}.
In the function parse_image() located in the file:
<source install>/source/parser/parser_materials.cpp
there is code to generate a warning when no image gamma is specified and
the image is being used in a height_field, bump_map or image_pattern.
The code back to v3.7 at least, has never worked. Where today the code has:
if (options.gammacorrect && !options.gammaOverride)
it should read:
if (!options.gammacorrect && !options.gammaOverride)
In povr I also added a second warning about using exr and hdr images
files with the height_field, bump_map or image_pattern.
if (!GammaCorrect)
         Warning("...");
     if ((filetype==EXR_FILE) || (filetype==HDR_FILE))
         Warning("...");
Using:
image_pattern { "test.exr" ... }
and not specifying a gamma correction, I now get:
File 'hmm3.pov' line 67:
Parse Warning:
Input image gamma not specified for height_field, bump_map or
image_pattern; no gamma adjustment (equals gamma 1.0) performed on input
image; Specify the appropriate gamma correction or, to be rid of this
warning, "gamma 1.0".
Parse Warning:
High Dynamic Range Image being used with a height_field, bump_map or
image_pattern; This will likely lead to artefacts as such images have
internal values outside the zero to one range.
