POV-Ray : Newsgroups : povray.beta-test : v3.8 beta 2 seg fault. 32 bit raspbian os on 64 bit pi 4 hardware. Server Time
22 Dec 2024 03:51:51 EST (-0500)
  v3.8 beta 2 seg fault. 32 bit raspbian os on 64 bit pi 4 hardware. (Message 1 to 3 of 3)
Subject: v3.8 beta 2 seg fault. 32 bit raspbian os on 64 bit pi 4 hardware.
Date: 26 Aug 2021 15:19:44
Message: <6127e950$1@news.povray.org>
While I was doing a long overdue disk back up for my main machine, I
decided to try a compile of the beta 2 release on my raspberry pi 4 4GB-
which happened to be running the more common 32bit rasbian os(1).
The configure and compile went mostly OK, except I had trouble getting a
tiff development library installed - for reasons not related to POV-Ray
and which I've not sorted. There are a lot of extra 'notes' from the
compiler over the usual warnings which can probably be turned off, but I
didn't chase these.
We get an almost immediate segfault trying to run even stuff like povray
--help which comes from vfe/vfesession.cpp. I expect others would follow
should one get to where we start to render anything.
We have four unix flavor configuration files in:
unix/povconfig/syspovconfig_bsd.h
unix/povconfig/syspovconfig_gnu.h
unix/povconfig/syspovconfig_posix.h
and
unix/povconfig/syspovconfig_osx.h
All have nearly identical set up code that I've changed - in povr - to:
#if (0)  // Use simpler c++11 method TODO remove 0 if no issues
#if defined(_POSIX_V6_LPBIG_OFFBIG) || defined(_POSIX_V6_LP64_OFF64)
     // Below NOT true 32 raspbian os on 64bit raspberry pi 4 hardware.
     // long is at least 64 bits.
     #define POV_LONG long
#elif defined(_POSIX_V6_ILP32_OFFBIG) || defined(_POSIX_V6_ILP32_OFF32)
     // long is 32 bits.
     #define POV_LONG long long
#else
     // Unable to detect long size at compile-time, assuming less than
64 bits.
#endif
#define POV_ULONG unsigned POV_LONG
#else   //----------------------------
// C++11 required so we can just set macros directly.
#define POV_LONG  std::int_least64_t
#define POV_ULONG std::uint_least64_t
#endif  // Use simpler c++11 method
(1) - There is now a 64bit raspbian os mostly aimed at the newer 8GB
models and there has been for quite a while 64bit Ubuntu versions for
the raspberry pi 4. Not everyone with a raspberry pi will hit this
issue, but many with a raspberry pi 4 will.
The issue can be guessed at from the code comments; It turns out that
first test can be true and the 'long int' not be at 64 bits as the code
comment states. The C++11 standard guarantees 'long long int' is at
least 64bits, but 'long int' can be only 32 bits and this we get with
the raspbian 32 bit os.
Aside: We have code since the move to c++11 taking POV_LONG and
POV_ULONG to always be 64 bits - the bit in vfesession.cpp is just the
first tripped upon where this not true. The code there has a hard LL
literal assuming long long int is 64 bits.
Bill P.
Subject: Re: v3.8 beta 2 seg fault. 32 bit raspbian os on 64 bit pi 4 hardware.
Date: 27 Aug 2021 05:04:32
Message: <6128aaa0$1@news.povray.org>
On 8/26/21 3:19 PM, William F Pokorny wrote:
> The code there has a hard LL literal assuming long long int is 64 bits.
Blast it, I meant to write:
"The code there has a hard LL literal assuming POV_LONG is 64 bits."
With C++11 'long long int' and 'unsigned long long int' are always at
least 64 bits.
Bill P.
Subject: Re: v3.8 beta 2 seg fault. 32 bit raspbian os on 64 bit pi 4hardware.
Date: 5 Oct 2021 16:28:49
Message: <615cb581$1@news.povray.org>
> least 64 bits.
In working on documentation for my povr branch changes I noticed the
issue here is essentially github issue #384.
"vfesession.cpp:342 overflow in conversion from long long int to
long int on m68k #384"
https://github.com/POV-Ray/povray/issues/384
I've for a month or so in those handful of configuration files simply
had the lines:
// C++11 required. We can set following macros directly.
over the conditional logic which was there.
This looks to be what clipka recommended in responding to #384.
Bill P.
