POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0-beta 1 - Parse error using "%s" in Win10 Server Time
29 Jun 2024 02:17:51 EDT (-0400)
  POV-Ray v3.8.0-beta 1 - Parse error using "%s" in Win10 (Message 21 to 30 of 36)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: POV-Ray v3.8.0-beta 1 - Parse error using "%s" in Win10
Date: 29 Jul 2021 08:54:35
Message: <6102a50b$1@news.povray.org>
Am 29.07.2021 um 13:45 schrieb William F Pokorny:
> Supposing the SDL:
> And the 'date' command on my Ubuntu 20.04 computer returning:
> The v3.8 branch returns:
> The povr branch returns:
> Bill P.
Oh hooray.
So, after some digging, it turns out that on Linux machines,
`boost::posix_time::microsec_clock::universal_time()` does specifically
*NOT* do what it was designed to do (at least with the boost version
we're bundling for Windows builds).
> (*) The -100000 days is somewhat arbitrary. Just needs to be earlier
> than the unix epoch time to trigger the dst aware mode.
I have no idea what you're saying there. What do you need to trigger,
and why?
Date: 29 Jul 2021 17:43:55
Message: <6103211b$1@news.povray.org>
Can someone test whether the fix in this pull request actually solves
the time zone issue?
https://github.com/POV-Ray/povray/pull/433
It should cause `datetime(now)` to print UTC (as opposed to local) time,
while still incrementing significantly faster than once per second.
What I'm doing there is query another timer to get a second opinion.
While that timer is of lower precision (seconds instead of
microseconds), it should reliably give proper UTC. So by using that as a
reference, we can adjust the high-precision timer accordingly by a
multiple of 15 minutes, to give us high-precision UTC.
Date: 30 Jul 2021 10:00:59
Message: <6104061b$1@news.povray.org>
First, what the -1e5 argument to datetime() does in the povr branch is
flip to code inside Parser::Parse_Datetime which uses std::time(nullptr)
over the argument - POV-Ray's 'now' is not relevant.
In my testing your fix gives me the utc time as a hard coded result -
and it's the only datetime string I can get with 'now'.
2021-07-30 12:48:35Z
What about local datetime strings with %z or %Z? The secondary issue I'd
forgotten I hit back in June with the boost code is that:
std::tm t =
boost::posix_time::to_tm(boost::posix_time::from_time_t(timestamp));
doesn't set up the %Z and %z capability. Using both in the string format
option gives me: "2021-07-30 12:48:35".
One can set up those fields by calling strftime() with an argument of:
std::localtime(&t), here getting EDT/-0400, but the date and time string
is still strictly UTC - so it's not particularly useful except maybe to
work backward to the actual time zone date and time in a uncommon /
awkward way and to do that you'd need to know the data/time was UTC no
matter the EDT or -0400 in the returned string.
I guess I see a place for a hard coded 'now' UTC/Z result - and as
accurate an internal time/timer as we can get (is your fix at odds with
timer use?). I don't see it as what most people will want with
datetime(). This why I coded up a more traditional std::time(nullptr) as
an optional mode of datetime()(a).
Aside 1: A reminder that in newer(to be v4.0) code, you moved 'now' off
boost completely. This is in fact is the code povr uses - meaning any
unix/linux 'bug' is in that code too.
Aside 2: The Parse_Datetime() code has too that use of:
setlocale(LC_TIME,"");
the full implications of which made me a little nervous along with the
etting being afterward persistent. So after the strftime() call I added:
setlocale(LC_TIME,"C");
to return the setting to the C++ start up default. In a scan of the code
I didn't pick up any other adjustments to the default locale.
Bill P.
(a) Lying some. Unsure what might happen with the boost variant over the
pure c++11 one for now, but the latter didn't account for daylight
savings adjustments which also makes datetime(), %z and %Z less than
precisely useful.
Date: 30 Jul 2021 14:29:34
Message: <6104450e$1@news.povray.org>
Am 30.07.2021 um 16:00 schrieb William F Pokorny:
> std::tm t =
That would require making `now` a more complicated beast than just a
numeric value, as we can't transport timezone information in that format.
I'm not going there. Not in v3.8, at any rate. Nor am I going the povr
route of hacking something into `datetime` to make it look up the
current time on its own when it gets passed some magic value. Retrieving
the current time is precisely the job of `now`.
As it currently stands, we have no sane way (in v3.8) of achieving all
the following ideal goals:
- Have separate mechanisms to get the current point in time (`now`), and
print a point in time (`datetime`).
- Have a simple "phrase" (combo of the above) to automatically print the
given point in time as UTC, without extra effort, and in a way that it
won't be mistaken for local time.
given point in time as local time, without extra effort, and in a way
that it won't be mistaken for UTC.
I think the following arguments lead to the sanest solution:
- If we have `datetime` default to a string that explicitly prints any
time zone information (as we currently do), then for the default to be
not blatantly wrong, we limit ourselves to one "flavor" of point-in-time
information: Either local ("%z" suffix), or UTC ("Z" suffix). If on the
other hand we omit the time zone entirely from the default, the output
will, for both flavors, be at least not entirely wrong.
This speaks heavily in favor of not including any time zone suffix at
all by default, i.e. dropping the "Z" we're currently appending.
- When users see a date or time, they will usually expect it to indicate
local time. To achieve that, the parameter passed to `datetime()` would
have to be of local time flavor.
This speaks heavily in favor of making `now` return local time, as
opposed to UTC.
I think it can be argued that local time is of far more relevance to
most users than UTC.
Should someone come up with any use case that needs access to the
current time in UTC, then possible workarounds would be:
- for the user to hard-code time zone offset into their scene file;
- for the user to design the scene such that time zone offset can be
passed via `Declare=` INI file setting;
- for us to provide some `timezone` pre-defined variable that evaluates
to the time zone offset in days, ready to be subtracted from `now` to
give UTC, or a `utc()` function that converts from local time to UTC. (I
would lean towards the latter, as the former variable would not be in
the common format of hours, which might give rise to confusion.)
> timer use?).
I'm not sure what you mean by "at odds with timer use".
What I can say is that the fix does not compromise timer precision, if
that's what you mean.
Actually, no - in this case `now` returning local time is not a
Unix/Linux bug (or, more to the point, not a "boost on Unix/Linux bug"),
but rather proper intrinsic behavior of the new implementation I chose.
I realize only now that I accidently implemented the wrong behavior
(judging by the documentation, and intent so far).
It's not the worst of accidents though. I'd like to consider it a Bob
Ross moment.
You and me both, bro.
Without any additional safety net, that would actually be
counter-productive: `setlocale` is not thread-safe; so if we ever run
multiple parser threads in parallel, and they come across the same piece
of code nearly at the same time, your "cleanup" could throw the other
thread off the rails.
The good news is that the above call only sets the time-specific
portions of the locale, which we don't mess with anywhere else. So
ideally we should call `setlocale(LC_TIME,"")` somewhere on program
startup, and never look back.
> precisely useful.
The v4.0 variant doesn't respect daylight savings zone? Yikes!
That'll be another problem to solve then.
Date: 30 Jul 2021 17:38:49
Message: <61047169@news.povray.org>
> opposed to UTC.
> [snip]
The 3.8 documentation say 'now' should return GMT, and on my GNU/Linux
box, it (pre-beta) does return UTC or GMT.  Are you proposing a change
in behavior?
Date: 30 Jul 2021 19:13:23
Message: <61048793$1@news.povray.org>
Am 30.07.2021 um 23:38 schrieb Cousin Ricky:
> in behavior?
I think I do, yes.
The current behavior appears to be quite inconsistent across platforms
and systems and whatnot.
Date: 31 Jul 2021 04:18:55
Message: <6105076f$1@news.povray.org>
>> in behavior?
> I think I do, yes.
Cousin Ricky is onto something; Me screwing up with respect to v3.8 beta
1 results. :-(
I maintain "many" versions of POV-Ray which I run with wrapper scripts
that are careful to strip any $HOME directory or environment variable
customizations - so I'm always testing the native code and set up.
When I grabbed and compiled:
https://github.com/POV-Ray/povray/releases/tag/v3.8.0-beta.1
I created a 'p380b1' wrapper script, but I screwed up and pointed it to
the v3.8 compile directories for the commit from off of which I'm basing
my povr stuff. All my testing of v3.8 beta 1 over the last couple weeks
has been against something closer to the current master branch.
#@%^$^%$&!!! The version is clearly there in the text output, which I
ignore 99.99% of the time...
What this means is the 'now' command I was running as v3.8 beta 1 was
the newer(1) c++11 version. It's that one not returning the utc/gmt/zulu
time making the default 'Z' format suffix wrong.
(1) - Though I've been running primarily that one for years - so I was
seeing what I expected to see as datetime(now) output.
I think, Christoph, an option - if you want to minimize v3.8 release
change - would be to let things go as they are. This would mean a hard
UTC datetime() result without working %z and %Z format options (others?).
I agree with your thinking the behavior of 'now' should updated, but
this could be delayed to v4.0.
Bill P.
Date: 31 Jul 2021 10:03:13
Message: <61055821@news.povray.org>
On 7/28/21 3:16 PM, William F Pokorny wrote:
> #version 3.8;
> #debug concat("v3.8 default -> ",datetime(now),"\n")
> I've gotten back:
> because the default format strings has a 'Z' on the end where I suspect
> ' %Z' was intended.
Z is for Zulu Time Zone, often used in aviation and the
military as another name for UTC +0.
tTh
|                      sphinx of black quartz, judge my vow.        |
Date: 31 Jul 2021 11:10:15
Message: <610567d7$1@news.povray.org>
>> in behavior?
> I think I do, yes.
In my case, #debug concat("v3.8 default -> ",datetime(now),"\n")
Running the Windows version under Windows 10.
Date: 11 Aug 2021 07:13:43
Message: <6113b0e7$1@news.povray.org>
Am 28.07.2021 um 15:16 schrieb William F Pokorny:
> Just to toss it out there, for as long as I've used datetime(now) as in:
> #version 3.8;
Can you put some estimate on "as long as I've used datetime(now)"?
Further back than 2019?
If so, can you remember whether you already got local time out of the
function back then, or whether it could originally have been UTC after all?
