POV-Ray : Newsgroups : povray.beta-test : wrong report about max_gradient Server Time
10 Nov 2026 23:22:24 EST (-0500)
  wrong report about max_gradient (Message 1 to 23 of 23)
Subject: wrong report about max_gradient
Date: 19 Nov 2001 03:22:16
Message: <5tfhvt4uj921171obes8j1hfl93eoi64ei@4ax.com>
POV 3.5 b 7 on PII 233 128 MB with NT 4 Sp 6
I had such syntax within isosurface:
  max_gradient 10
  evaluate 1, 10, 0.99
but renderer said after trace
  Warning: The maximum gradient found was 184.775, but max_gradient of
  the isosurface was set to 1988.679. Adjust max_gradient to
  get a faster rendering of the isosurface.
IMO 1988.679 <> 10. Expected behaviour, misunderstand or bug ?
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Subject: Re: wrong report about max_gradient
Date: 19 Nov 2001 04:37:16
Message: <3bf8d2cc@news.povray.org>
I think this is something which has been fixed for the next beta. You should
wait for it and see if the problem still exists.
Date: 19 Nov 2001 05:29:42
Message: <3bf8df16$1@news.povray.org>
See  http://news.povray.org/3be10cf9@news.povray.org
>**** Dynamic maximum gradient estimation *****
>max_gradient G_max
>"eval(uate) P0, P1, P2"
>where
>  P0 is the minimum max_gradient value in the estimation process,
>  P1 should be more than 1 (over-estimation parameter), and
>  P2 should be less than 1 (attenuation parameter).
>The max_gradient, G_max, is re-calculated for each ray as following
>        If (G_max< G*P1)
>             then   G_max = G*P1*P1
>             else if (G_max>P0) then G_max = G_max*P2,
So, the max_gradient value in the scene file is the 'initial' value
and it is re-declared in the estimation (or rendering) process.
I think only the sentense "Warning: The maximum gradient found was 184.775."
 is enough for the evaluatation result.
R. Suzuki
Date: 19 Nov 2001 05:35:06
Message: <lunhvt07a7gg1ffmln18bmq6pvug3ftn88@4ax.com>
On Mon, 19 Nov 2001 19:29:39 +0900, "R. Suzuki" <r-s### [at] aistgojp> wrote:
I can't agree. When there are more then one isosurfaces simetimes initial value
is only way to recognize where founded value shuold be applied.
ABX
Date: 19 Nov 2001 06:37:43
Message: <3bf8ef07@news.povray.org>
In article <5tfhvt4uj921171obes8j1hfl93eoi64ei@4ax.com> , W„odzimierz ABX
>   max_gradient 10
See
Newsgroups: povray.beta-test
Subject: Isosurfaces *much* slower in beta 7?
Date: Tue, 30 Oct 2001 23:07:31 +0100
Message-ID: <3bdf24b3$1@news.povray.org>
Xref: news.povray.org povray.beta-test:2475
e-mail: tho### [at] trfde
Date: 19 Nov 2001 06:41:54
Message: <3bf8f002@news.povray.org>
In article <3bf8df16$1@news.povray.org> , "R. Suzuki" <r-s### [at] aistgojp>
The problem is that many people don't read the documentation and then
complain about "holes and other bugs" with isosurfaces (see several messages
in these groups).  I would also prefer a shorter message, but as long as
many people who use a free software cannot be asked to read the
documentation before reporting something as a bug this message is a
inconvenience that has to be forced upon all users :-(
    Thorsten
Date: 19 Nov 2001 07:21:54
Message: <k0uhvt4l9ppp8pgs655obeirbedjovd74n@4ax.com>
On Mon, 19 Nov 2001 12:37:42 +0100, "Thorsten Froehlich" <tho### [at] trfde>
> See
> From: "JRG" <jrg### [at] hotmailcom>
I don't like bothering but there is nothing about difference between typed value
and outputed value. in that thread :-(
Perhaps it was misunderstand but I reported here that I wrote 10 in script but
report message said I wrote 1988.679. I know meaning of the message. It is
annoing when you are trying find isosurface from many isosurfaces to apply
calculated value.
ABX
Date: 19 Nov 2001 07:28:02
Message: <8duhvto4s52070im27o3fkomaif4cms34e@4ax.com>
On Mon, 19 Nov 2001 12:41:53 +0100, "Thorsten Froehlich" <tho### [at] trfde>
> complain about "holes and other bugs" with isosurfaces.
IMO you misunderstand this bug report. I wrote 10 but report said I wrote more
than 1900. I understand inner behaviour, I just pointed out is says false.
ABX
Date: 19 Nov 2001 08:01:41
Message: <3bf902b5@news.povray.org>
In article <8duhvto4s52070im27o3fkomaif4cms34e@4ax.com> , W„odzimierz ABX
I was not refering to you or the bug report at all.  I was only pointing out
the need for the additional parts of the message that appear unnecessary for
those who did read the documentation.
    Thorsten
Date: 19 Nov 2001 08:05:40
Message: <3bf903a4@news.povray.org>
In article <k0uhvt4l9ppp8pgs655obeirbedjovd74n@4ax.com> , W„odzimierz ABX
> value and outputed value. in that thread :-(
> calculated value.
Here it is:
>From: "Thorsten Froehlich" <tho### [at] trfde>
>Subject: Re: Isosurfaces *much* slower in beta 7?
>Date: Mit, 31. Okt 2001 10:27 Uhr
>Message-ID: <3bdfc402@news.povray.org>
>Xref: news.povray.org povray.beta-test:2503
>> That's really sad, i was just starting to use it intensively.
> That is part of beta testing.  It is not really a serious problem, it is
> just very slow...
>> Apart from
>> being incredibly slow it also seems to produce wrong results.
> No, it only changes your max_gradient.  The reported found maximum gradient
> value is still correct.
Date: 19 Nov 2001 08:09:27
Message: <sv0ivt0suh5ra8oni81ipqs75871j849ln@4ax.com>
On Mon, 19 Nov 2001 14:05:38 +0100, "Thorsten Froehlich" <tho### [at] trfde>
But I didn't wrote about 'found' value but about initial value!!!
ABX
Date: 19 Nov 2001 08:16:27
Message: <3bf9062b@news.povray.org>
In article <sv0ivt0suh5ra8oni81ipqs75871j849ln@4ax.com> , W„odzimierz ABX
Yes, I say it "changes your max_gradient", so if it *changes* your
max_gradient, how can it report *your* max_gradient? - It cannot and thus it
will report the *changed* max_gradient!
Anyway, just take my word for it:  This has long ago been fixed for the
_next_ beta.
    Thorsten
Date: 19 Nov 2001 08:22:54
Message: <3bf907ae@news.povray.org>
BTW, why do you try to convince me that it is a bug when I have already
*acknowledged* that it is a bug? (Rhetoric question only, no answer
expected!)  Somehow communication failed completely...
    Thorsten
Date: 19 Nov 2001 08:25:33
Message: <8p1ivtseldt44no1iddgo697vlkuqqpnt2@4ax.com>
On Mon, 19 Nov 2001 14:16:26 +0100, "Thorsten Froehlich" <tho### [at] trfde>
Can't it be remembered in local variable? It can report isosurface line within
source. Why it can't remember initial value? It shows line and then says 'value
was set to ...'
> _next_ beta.
Ok. I don't like bothering so sorry for this long bothering :-)
ABX
Date: 19 Nov 2001 08:33:35
Message: <s52ivt885j48ckodtdit0dtseqp7u8fekn@4ax.com>
On Mon, 19 Nov 2001 14:22:52 +0100, "Thorsten Froehlich" <tho### [at] trfde>
Becouse I thought all the time you're talking about different thing.
> (Rhetoric question only, no answer expected!)
Please don't read  above answer ;-)
The easiest explanation for me is my english
but I don't know if it is good enough :-(
Sorry again for bothering, really sorry.
ABX
Date: 19 Nov 2001 08:56:39
Message: <3bf90f97@news.povray.org>
In article <8p1ivtseldt44no1iddgo697vlkuqqpnt2@4ax.com> , W„odzimierz ABX
Because it is a ***bug*that*it*changes*the*user*supplied*max_gradient***!!!
It was never supposed to change it the way it does and then output that as
the user supplied max_gradient!!!
> 'value was set to ...'
It has nothing to do with the *algorithm*, but a ***bug*** in the
*implementation* of the algorithm.  This obviously has to be fixed by
changing the *implementation* of the algorithm, not by *changing* the
*algorithm* itself!!!  And as I said:  It *has* been fixed this way already,
so any suggestion on how to change the *algorithm* to fix it is completely
unnecessary because the *algorithm* is correct, only its *implementation* is
*not* correct in beta 7!!!
    Thorsten
Date: 19 Nov 2001 08:59:05
Message: <3bf91029@news.povray.org>
In article <s52ivt885j48ckodtdit0dtseqp7u8fekn@4ax.com> , W„odzimierz ABX
Try reading more English and using it actively whenever you a chance.  It
really helps!
No problem.
    Thorsten
Date: 19 Nov 2001 09:07:45
Message: <3bf91230@news.povray.org>
Włodzimierz ABX Skiba <abx### [at] babilonorg> wrote:
: I don't like bothering but there is nothing about difference between typed value
: and outputed value. in that thread :-(
  Really? Did you actually read the whole thread? More precisely, this
article of mine:
From war### [at] tagpovrayorg Mon Nov 19 16:05:26 2001
Message-ID: <3be0175a@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote:
: * Warp: Do a sync (get change 1235) to try it.
  Ok, I did it, and there clearly is a difference.
  I tested with this small example:
#include "functions.inc"
camera { location -z*5 look_at 0 angle 35 }
light_source { <100,200,-300>, 1 }
isosurface
{ function { x^2+y^2+z^2-(1-.2*f_noise3d(x*8,y*8,z*8)) }
  contained_by { sphere { 0,1 } }
  max_gradient 2
  evaluate 1,10,.99
  pigment { rgb x } finish { specular .5 }
  The older version (ie. beta7) rendered that in 1 min 30 seconds in this
computer. The report was a bit odd:
Warning: The maximum gradient found was 3.555, but max_gradient of
the isosurface was set to 310.201. Adjust max_gradient to
  The newer version renders the example above in 13 seconds, which is a clear
improvement.
Warning: The maximum gradient found was 3.477, but max_gradient of the
isosurface was set to 2.000. The isosurface may contain holes!
Adjust max_gradient to get a proper rendering of the isosurface.
  The max_gradient value of 3.477 seems to be correct. When I set max_gradient
to that, the isosurface renders ok.
  It seems that now 'evaluate' doesn't actually change the max_gradient, but
just calculates the correct one and reports it. The example above renders
equally whether or not the 'evaluate' is there.
  This behaviour seems logical to me.
Date: 19 Nov 2001 09:08:54
Message: <3bf91276@news.povray.org>
In article <lunhvt07a7gg1ffmln18bmq6pvug3ftn88@4ax.com> , W„odzimierz ABX
value
You do realize that it outputs the line number of the isosurface, don't you?
So there is absolutely no need to use the max_gradient to identify different
isosurfaces...
    Thorsten
Date: 19 Nov 2001 09:11:08
Message: <ul4ivt0ibrum7gmdsfseofsh6jc1ukfjp9@4ax.com>
On Mon, 19 Nov 2001 15:08:52 +0100, "Thorsten Froehlich" <tho### [at] trfde>
Yes, before I missed this.
> isosurfaces...
Yes, I agree now. Congratulations of your patience :-)
ABX
Date: 19 Nov 2001 09:14:37
Message: <hq4ivt851smfiln0i3t9iakt95e1mkrc32@4ax.com>
>article of mine:
Please, stop. I repeat it was my wrong perception of words. Should I repeat 100
times "I'm guilty"? Sorry again and again.
ABX
Date: 19 Nov 2001 09:17:59
Message: <3bf91497@news.povray.org>
: Please, stop. I repeat it was my wrong perception of words. Should I repeat 100
: times "I'm guilty"? Sorry again and again.
  Your punishment: Write 100 times "I will not do it again".
  Just kidding ;)
Date: 20 Nov 2001 07:33:35
Message: <53jkvt4kt904487q74gncv0eddlq84rru1@4ax.com>
Without using a #while loop!
Peter Popov ICQ : 15002700
