POV-Ray : Newsgroups : povray.beta-test : 3.8 and text {} Server Time
19 Mar 2026 04:37:27 EDT (-0400)
  3.8 and text {} (Message 8 to 17 of 18)
<<< Previous 7 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: Hello darkness (was Re: 3.8 and text {})
Date: 14 Nov 2019 07:00:00
Message: <web.5dcd41b7bf609be64eec112d0@news.povray.org>
Dick Balaska <dic### [at] buckosoftcom> wrote:
> (and the annoying not-an-error "possible error" comes through as a
> "mGenericStatus" message (normally the 'Rendered 10 of 20 pixels (50%)'
> messages) so it shows up in the povwin status bar.  This confuses my
> renderfarm progress bars, which resize bigly to display the message that
> shouldn't even be there.)
Isn't there a message pane switch that can be toggled to shut things like that
off?
Date: 14 Nov 2019 07:10:01
Message: <web.5dcd4322bf609be64eec112d0@news.povray.org>
> off?
http://wiki.povray.org/content/Reference:Text_Output_Options#Text_Streams
Date: 14 Nov 2019 07:26:39
Message: <5dcd47ff$1@news.povray.org>
On 11/14/19 2:27 AM, Dick Balaska wrote:
> On 11/13/19 9:21 AM, Dick Balaska wrote:
>> Looking at the povray source code, the solution is to change all of my
>> files to
>> #version 3.8;
>> and leave my text {} objects exactly as they are.
> Well poo.
> Changing my SDL from #version 3.7 to 3.8 causes the image to be much
> darker.
One of the changes 3.7 to 3.8 was to take the default ambient to 0.0.
It's a funky color adder disconnected from gamma handling, and at 0.1,
it tends to brink near blacks way up in intensity with AG 1.0 - washing
out the contrast in the images. Your 1.7 AG is already compensating for
this effect to a large degree.
Have you tried changing the default ambient back to 0.1 when changing
your version to 3.8?
Bill P.
Date: 14 Nov 2019 15:49:32
Message: <5dcdbddc@news.povray.org>
>> darker.
> Bill P.
I'm trying to explore/understand this.
This,
https://www.povray.org/documentation/3.7.0/r3_4.html#r3_4_1
says the default ambient is <1,1,1>, not 0.1.  Am I looking at the wrong
thing?
dik
Rendered 23,657,702,400 of 40,928,716,800 pixels (57%)
Date: 14 Nov 2019 16:20:00
Message: <web.5dcdc498bf609be64eec112d0@news.povray.org>
> This,
> thing?
This is why I hate "documentation" compared to direct access to the values and
parameters that something uses.
I think, after 25 years, there ought to be access through SDL, or at least a
text-stream command that regurgitates things that are hidden "under the hood".
And, you probably _are_ looking at the wrong thing, since we're on
3.8.something.
http://wiki.povray.org/content/Reference:Finish#Ambient
"In version 3.8 there has been a Change to the ambient default setting. The
default setting is now ambient 0 as opposed to the ambient 0.1 value used in
previous versions. Requires #version 3.8; or equivalent INI setting or
command-line option. See also: Version Directive."
Date: 14 Nov 2019 23:58:33
Message: <5dce3079$1@news.povray.org>
The global ambient_light is silently ignored if the #version is 3.8
I used the Basic Scene 01 - Checkered Plane template
and added a Wire_Box.  Then at the top changed these 3 lines:
#version 3.8;
global_settings{ assumed_gamma 1.7 ambient_light 5.0}
//#default{ finish{ ambient 0.1 diffuse 0.9 }}
If the version is 3.7, then that ambient_light 5.0 washes everything
right out.  If the version is 3.8, it matters not what I set that number to.
So I tried
global_settings{ assumed_gamma 1.7 }
#default{ finish{ ambient 0.1 }}
This does look a lot like the effect I want, after a couple of tests on
my movie.  However, I am greeted with a plethora of:
Parse Warning: Scene language version changed after a 'default'
statement. The changes in defaults normally associated with the language
version change are not applied.
because the standard includes push the version, change to 3.5, pop the
version.
sigh.
dik
Rendered 23,792,486,400 of 40,928,716,800 pixels (58%)
Date: 15 Nov 2019 09:02:11
Message: <5dceafe3$1@news.povray.org>
> #version 3.8;
> to.
> So I tried
> version.
> sigh.
Hey. Sorry, I should've written out 'default{ finish{ ambient 0.1 }}'
(1) to make clear what's needed if using #version 3.8 and wanting to
match the 3.7 finish ambient behavior.
The ambient_light color has an effect only when a texture's ambient
setting is > 0.0 and so has no effect anywhere the v3.8 default ambient
0 finish is used.
Those parse warnings showed up in one of the last updates and I join you
in not being a fan of the warning in it's current form. It's very noisy
in typical use. I worked recently a little in v3.8 with Norbert's
assumed_gamma scene which included stdinc.inc - and yuck. If the warning
could not warn when an alternate version is detected but the original
restored before exiting an include file - or the main file - it would be
better(2).
Bill P.
(1) - Christoph recommends using default {} over #default {}.
(2) - I recall no discussion around the addition of this parser check
and warning before its introduction. Perhaps Christoph was thinking all
the shipped includes would be updated to version 3.8 before any v3.8
release so those wouldn't be an issue for this warning. I don't know.
Date: 15 Nov 2019 11:52:07
Message: <5dced7b7$1@news.povray.org>
>>> darker.
>> washing out the contrast in the images. Your 1.7 AG is already
>> compensating for this effect to a large degree.
>> Bill P.
> This,
> thing?
Yes, you are looking at the wrong thing.
This refers to ambient_light in the global_settings. This is not the
default ambient value but a multiplicator that is applied to every
ambient values in the whole scene.
If you set that value to <1,0,0>, then, ALL ambient, default and
explicit, will become red. Then, if you have an ambient value set to
something like rgb<0, 0.02, 0.1>, it will result in black.
You need to look in the finish section :
https://www.povray.org/documentation/3.7.0/r3_4.html#r3_4_6_3_1
Date: 15 Nov 2019 11:55:08
Message: <5dced86c$1@news.povray.org>
> version.
> sigh.
You can get rid of those warnings simply by moving the #default
statement after your includes.
Date: 16 Nov 2019 16:42:53
Message: <5dd06d5d$1@news.povray.org>
>> on my movie.  However, I am greeted with a plethora of:
>> language version change are not applied.
>> version.
>> sigh.
Yeah, but that's a hacky hacking hack.
I think really my only way out is to bite the bullet, surrender to
clipka, and rework the whole shebang to gamma 1.0.
It's only 90,984 lines of lovingly handcrafted SDL.  (And 17,047 lines
of Java and 9,799 lines of c++ giving 68,245 separate images.)
How hard can it be?
[insert maniacal laughter here]
dik
Rendered 24,043,392,000 of 40,928,716,800 pixels (58%)
