POV-Ray : Newsgroups : povray.beta-test : Wavefront OBJ import Server Time
10 Nov 2026 17:26:51 EST (-0500)
  Wavefront OBJ import (Message 1 to 31 of 31)
Subject: Wavefront OBJ import
Date: 13 Sep 2016 20:08:07
Message: <57d894e7$1@news.povray.org>
Source code:
https://github.com/c-lipka/povray/tree/feature/obj_import
Syntax is as follows:
    mesh {
      obj FILENAME
      [ OBJ_TEXTURE_LIST ]
      [ inside_vector VECTOR ]
    OBJ_TEXTURE_LIST:
      texture_list {
        [ OBJ_TEXTURE_LIST_ITEM ... ]
    OBJ_TEXTURE_LIST_ITEM:
      STRING texture { TEXTURE } |   (A)
      STRING material { TEXTURE } |
      prefix STRING |                (B)
      suffix STRING
At present, associated .mtl files will /not/ be evaluated; instead,
textures must be defined using one of the following means:
(A) in the texture_list, as a list of the individual material names as
used in the .obj file and the respective texture definition to use; or
(B) before the `mesh` statement, by defining texture variables with
corresponding names. For some ease of use, a pre- and suffix can be
defined that will be added to the material name as used in the .obj file.
For additional ease of use, materials can be used instead of textures;
however, in that case only the texture is taken from the material, while
the interior_texture and interior are ignored.
e.g.
    #declare MyTexture = texture { ... }
    #declare MyMaterial = material { ... }
    mesh {
      obj "MyMesh.obj"
      texture_list {
        "Foo" texture { MyTexture }
        "Bar" material { MyMaterial }
        prefix "Tx"
        suffix "_"
      inside_vector y
will map the material name "Foo" in the .obj file to `MyTexture` and the
material name "Bar" to `MyMaterial`, while any other name, say, `Fnord`
or `Uqbar`, would be mapped to `TxFnord_` and `TxUqbar_`, respectively.
OBJ import provides rudimentary support for non-triangular polygons, but
currently just blindly cuts up such polygons into triangles, relying on
the polygons to be nicely planar and convex. This may also affect the
apparent curvature of such polygons.
That said, I have a hunch that someone might like this feature.
Subject: Re: Wavefront OBJ import
Date: 14 Sep 2016 01:20:00
Message: <web.57d8ddb5d98a4381a1334c0c0@news.povray.org>
[snip]
Excellent! This will be very useful. Almost everything can export to obj, so
this immediately improves workflow for any project that uses a third-party
modeller.
Presumably the slight increase in read speed over mesh2 stems from the fact that
..obj is slightly less verbose in its syntax?
Bill
Date: 14 Sep 2016 03:39:51
Message: <57d8fec7$1@news.povray.org>
Am 14.09.2016 um 07:18 schrieb Bill Pragnell:
> clipka <ano### [at] anonymousorg> wrote:
> [snip]
> modeller.
That of course depends on the quality of the exporter. If it exports
poor meshes, with flipped normals and stuff, an external tool like
PoseRay is still recommended.
> ...obj is slightly less verbose in its syntax?
Exactly.
Date: 14 Sep 2016 16:10:19
Message: <57d9aeab$1@news.povray.org>
It's been documented: http://wiki.povray.org/content/Reference:Mesh
I also created a talk page in case it's needed.
Date: 14 Sep 2016 16:40:42
Message: <57d9b5ca$1@news.povray.org>
Am 14.09.2016 um 22:10 schrieb Jim Holsenback:
Thanks; I guess I'll have to hurry to integrate it into the official
branch then ;)
Date: 14 Sep 2016 17:43:40
Message: <57d9c48c$1@news.povray.org>
> branch then ;)
why the limitation of interior when material is used? that would leave
out a glass object just to name one
Date: 14 Sep 2016 18:52:24
Message: <57d9d4a8$1@news.povray.org>
Am 14.09.2016 um 23:43 schrieb Jim Holsenback:
>> branch then ;)
Because POV-Ray's architecture currently doesn't support different
interiors in a single primitive (which may not even make much sense),
and OBJ import is currently designed to generate a single mesh.
You can always add an interior to the entire mesh as part of the
OBJECT_MODIFIERS.
Date: 15 Sep 2016 07:13:30
Message: <57da825a$1@news.povray.org>
Now I know who has the real power to get things into the master branch :-).
FYI - A new object in the "lemon" is in the master branch and not yet
documented in povray's documentation. Jérôme has some documentation for
it already on his page at:
   http://wiki.povray.org/content/User:Le_Forgeron#Lemon
Unsure if on yours or Jérôme's todo list. If I can help in some way
update the docs for the lemon, let me know.
Bill P.
Date: 15 Sep 2016 12:03:23
Message: <57dac64b@news.povray.org>
it's been added http://wiki.povray.org/content/Reference:Lemon
looks like the opening paragraph could use some help so I also created a
talk page as well: http://wiki.povray.org/content/Reference_Talk:Lemon
Date: 15 Sep 2016 12:59:06
Message: <57dad35a$1@news.povray.org>
Thanks. I've attempted some descriptive text at:
Bill P.
Date: 15 Sep 2016 13:18:57
Message: <57dad801$1@news.povray.org>
> Bill P.
I like it, but the introducing description is a bit harsh for the
non-mathematically-addicted.
So I added a bit in the discussion too
Date: 15 Sep 2016 18:34:03
Message: <57db21db$1@news.povray.org>
a combination of both: http://wiki.povray.org/content/Reference:Lemon
Date: 16 Sep 2016 04:08:40
Message: <57dba888$1@news.povray.org>
I really liked the passage about the american football and other real
evocations. It gave flesh to the description.
The constraint on minimal inner_radius is really a dangerous beast:
If base & cap radius are both 0, the inner_radius must be at least half
the distance between base and cap point (it would be a sphere)
So, as stated, the doc is false.
If base & cap radius are identical, the minimal inner_radius would be
sqrt( radius² + (distance/2)² ) , where distance is the length between
base and cap points.
when base & cap radius are different, it become nightmare (the exact
equation is in the code, if you dare to want to know it).
Date: 16 Sep 2016 08:53:23
Message: <57dbeb43$1@news.povray.org>
no worries /but/ i wish you'd been as verbose with your previous post
... however i see a bit of a conflict (perhaps i've characterized
incorrectly) item 4 and 5 seem a bit murky or are the /both/ correct:
Date: 16 Sep 2016 09:33:21
Message: <57dbf4a1@news.povray.org>
Argh. Sorry Jim. I got the wording for what I believe is the lower-most
bound for the inner radius wrong. I had in my head only to offer general
guidance there.
Adding the full equations is an option I guess - we do for other objects
in the docs. If we stick with a general description, we could build on
what you, Jérôme, wrote with perhaps:
the distance between base and cap point (it would be a sphere).
Otherwise the minimum inner radius is larger than half the distance
between base and cap point. Any time the inner radius given is too
small, the code uses the minimum radius over the specified one and
issues a warning.
Bill P.
Date: 16 Sep 2016 09:49:12
Message: <57dbf858$1@news.povray.org>
I believe we need to delete the following list item (me originally
leading you wrong I think):
* generally speaking Inner_Radius must be greater than or equal to the
distance between end points
or change it to:
* generally speaking the Inner_Radius must be greater than or equal to
half the distance between end points
Bill P.
Date: 16 Sep 2016 10:41:14
Message: <57dc048a$1@news.povray.org>
> guidance there.
like i said ... no worries
sticking with general description
> issues a warning.
i /think/ i've got it this time:
Date: 16 Sep 2016 12:05:09
Message: <57dc1835$1@news.povray.org>
>> guidance there.
>> issues a warning.
I added yet another comment in the discussion.
Date: 17 Sep 2016 08:57:10
Message: <57dd3da6$1@news.povray.org>
Date: 17 Sep 2016 09:52:39
Message: <57dd4aa7$1@news.povray.org>
Suggesting a correction and further tweak at bottom of the page:
Bill P.
Date: 17 Sep 2016 10:14:46
Message: <57dd4fd6$1@news.povray.org>
i had it there previously had it but thought it looked better where i
had it ... oh well moved/updated it
Date: 17 Sep 2016 10:15:56
Message: <57dd501c$1@news.povray.org>
i had it there previously but thought it looked better where i had it
... oh well moved/updated it ... sheesh
Date: 18 Sep 2016 20:56:32
Message: <57df37c0$1@news.povray.org>
updated image and example code:
Date: 19 Sep 2016 07:20:55
Message: <57dfca17@news.povray.org>
The following point still does not make sense:
* minimal Inner_Radius is a spherical segment where the center of the
arc lies on the end points axis
Please see the discussion for the original sentence.
Date: 19 Sep 2016 09:12:20
Message: <57dfe434$1@news.povray.org>
oh-key-doe-key then ...
Date: 19 Sep 2016 11:36:46
Message: <57e0060e$1@news.povray.org>
thanks. Remember that I'm not a native speaker, so it's ok to amend any
of my text, as long as I can still understand it.
Date: 21 Sep 2016 12:52:10
Message: <57e2baba$1@news.povray.org>
Folks, just to let you know: Don't get too accustomed to the exact
syntax; I have strong reason to suspect I'll change it.
For starters, there may be cases when you want to import an .obj not as
a single mesh but as a set of meshes. (Point in case: Poser or DAZ
figures with eyelashes; the skin should have a refractive index of
around 1.45 for the Fresnelian effects to be modeled properly, while the
eyelashes must not have a refractive index at all or they'll look weird;
and while we're at it, the teeth should have a reflective index of
around 1.6. But POV-Ray does not support different refractive indices in
a single mesh.) The .obj mesh import syntax could be changed to import
only geometry that matches certain criteria (based on material, group or
object), but this would mean that in order to import all parts of an
.obj file it would have to be parsed multiple times, which isn't efficient.
So the approach I'll probably take is to make the obj import feature
create a single mesh if no filtering is done, but also provide means to
create a CSG union of meshes. But obviously it would be a tad confusing
to have a `mesh` statement create a CSG.
Also, in case we ever extend the import to support non-mesh geometry
(obj also supports points, lines and various NURBS-ish stuff) or even
other file formats that may support genuine geometric primitives,
stuffing all of it into the `mesh` syntax would seem rather odd.
Date: 22 Sep 2016 03:49:28
Message: <57e38d08$1@news.povray.org>
I am looking forward to this. One of the (future) benchmarks will
probably be when the import of a (complex) Poser figure will become
standard procedure :-)
However, I can also imagine other interesting complex things...
Good work! Thank you indeed for your unrelenting dedication!
Date: 22 Sep 2016 04:12:51
Message: <57e39283$1@news.povray.org>
Seconded.
Bravo.
Regards
Date: 22 Sep 2016 10:08:17
Message: <57e3e5d1$1@news.povray.org>
Am 22.09.2016 um 09:49 schrieb Thomas de Groot:
Actually I'm aiming for import of DAZ figures...
... which is why JSON import is next on my list (DAZ Studio 4.x's .duf
file format is actually based on JSON), in order to provide a vector for
the import of arbitrary DAZ materials. (The .mtl files that accompany
.obj files are far too restricted to be of any practical use with DAZ
figures.) The envisioned workflow would be (1) export of materials from
DAZ as (uncompressed) material presets, (2) import into POV-Ray using an
inbuilt syntax for JSON files, (3) processing of the imported data via
SDL macros to generate a set of POV-Ray material and texture
definitions, and (4) association of those materials to the meshes.
Which in turn means I'll have to implement yet a few more SDL goodies,
most notably mixed-type arrays. Some means to iterate over the elements
of a dictionary will also be needed, and possibly also a means to
identify what type of data a given variable holds.
And of course someone will have to implement a default include file to
actually do the DAZ materials data processing.
Date: 23 Sep 2016 02:44:09
Message: <57e4cf39$1@news.povray.org>
Hmm. I suppose that is ok, although /personally/ I am no fan of DAZ for
different reasons and prefer Poser, with all its inherent weaknesses.
