POV-Ray : Newsgroups : povray.beta-test : Testing on XP required. Server Time
28 Sep 2024 18:35:58 EDT (-0400)
  Testing on XP required. (Message 1 to 10 of 14)
Subject: Testing on XP required.
Date: 30 Aug 2016 00:52:52
Message: <57c51124$1@news.povray.org>
The binaries of the following build want to be tested on Windows XP
(both 32 and 64 bit):
https://github.com/POV-Ray/povray/releases/tag/v3.7.1-alpha.8764097
Only basic testing needed, to make sure they run at all.
Subject: Re: Testing on XP required.
Date: 30 Aug 2016 06:29:21
Message: <57c56001$1@news.povray.org>
WinXP32, pvengine32.exe
Warning: did not find colors.inc...
Did not load GUI extension.
Basic scene ran without problem.
Stephen S
Date: 30 Aug 2016 06:59:01
Message: <57c566f5$1@news.povray.org>
Am 30.08.2016 um 12:28 schrieb StephenS:
Is that a symptom you also see with previous development builds?
Date: 30 Aug 2016 20:44:41
Message: <57c62879$1@news.povray.org>
It looks like every time I start pvengine32.exe
(3.7.1-alpha.8764097+av168.msvc14.win32)
It creates a new "pvengine.ini", resetting changes.
Does this help?
pvengine.exe, 3.7.0.msvc10.win32, does not do this.
Stephen S
Date: 30 Aug 2016 21:19:55
Message: <57c630bb$1@news.povray.org>
> Does this help?
> Stephen S
pvengine.exe, 3.7.0.msvc10.win32, updates the date modified of
"pvengine.ini" each time it's run, but keeps my changes.
example:
ExtDLL16=C:\Program Files\Bishop3D\Bishop3DPovComm.dll
Stephen S
Date: 31 Aug 2016 00:36:21
Message: <57c65ec5@news.povray.org>
Am 31.08.2016 um 03:19 schrieb StephenS:
>> Does this help?
>> Stephen S
To re-iterate my quiz question:
Is that a symptom you also see with previous DEVELOPMENT builds?
E.g. this one:
https://github.com/POV-Ray/povray/releases/tag/v3.7.1-alpha.8737777
I need to know if this effect is something I've introduced with the new
build procedure, or whether it's a pre-existing bug introduced earlier
during development.
If you see the symptom with 3.7.1-alpha.8737777 as well, I might ask you
to also try this one:
https://github.com/POV-Ray/povray/releases/tag/v3.7.1-alpha.8451792%2Bav100
And if the 3.7.1-alpha.8451792 doesn't have it, I'd like to ask you to
try releases in between (excluding those marked "experimental"), to
narrow down where the error was introduced.
If you have the time of course.
Date: 31 Aug 2016 06:08:51
Message: <57c6acb3$1@news.povray.org>
Some during the week, lots during the weekend.
Will start as time permits.
Stephen S
Date: 4 Sep 2016 10:45:31
Message: <57cc338b$1@news.povray.org>
I have many of the builds, maybe some experimental, ops.
8451792 av100 not valid
8558038 av124 working
8586521 av129 not valid
8737777 av158 not valid
8764097 av168 working, missing color.inc
working through more.
Stephen S
Date: 4 Sep 2016 11:31:47
Message: <57cc3e63$1@news.povray.org>
Am 04.09.2016 um 16:44 schrieb StephenS:
That's seriously odd, as the build process hadn't changed between the
latter two.
I presume that "not valid" means Windows XP is claiming the .exe to be
not a valid XP application, and that you're making sure to run the
32-bit version, right?
Date: 4 Sep 2016 11:34:42
Message: <57cc3f12$1@news.povray.org>
8514084 av121 working
8545805 av122 working
8555867 av123 working
8600570 av138 not valid
...all not valid
8730959 av156 not valid
> Stephen S
The testing is for pvengine32.exe only, not "-sse2"
Both can run on my computer.
Athlon64 X2 Dual, 4200+, 2gb ram
WinXP sp3 (Media center edition)
