POV-Ray : Newsgroups : povray.beta-test : Cached Macros! Server Time
10 Nov 2026 17:26:57 EST (-0500)
  Cached Macros! (Message 1 to 32 of 32)
Subject: Cached Macros!
Date: 14 Jul 2016 19:15:19
Message: <57881d07$1@news.povray.org>
Hi Folks,
Until now, each and every invocation of a macro from a file other than
the one it was declared in, inevitably caused the latter file to be
opened again for the macro code to be re-read -- a process that
seriously bogged down the parser. It therefore used to be recommended to
copy frequently used macros into the main scene file (or whatever file
they were called from).
I have now implemented a mechanism that keeps a copy of each and every
macro's code in memory (except for macros more than 65536 characters in
size), greatly increasing the execution speed of macros in such
scenarios, to the point that said recommendation should be obsolete from
now on.
While I'm satisfied with the cross-file macro execution speed, I would
like additional feedback from you guys about execution speed of macros
declared in the same file. I see a slight increase there, too -- can you
confirm?
Also, I'd like you folks to go wild trying to find scenarios where the
caching of macros has any drawbacks, and of course find that one bug I
have hidden there.
As usual, both Windows binaries and source code packages can be found at
https://github.com/POV-Ray/povray/releases. The source code can also be
found as the current master branch at https://github.com/POV-Ray/povray.
(The source code in question carries the version number
v3.7.1-alpha.8697421, the Windows binaries carry the build suffix +av151.)
Subject: Re: Cached Macros!
Date: 17 Jul 2016 15:26:05
Message: <578bdbcd$1@news.povray.org>
when i went to document this ... noticed syntax diagram /might/ be
missing the term optional in a couple of places. agreed?
http://wiki.povray.org/content/Reference:User_Defined_Macros
Date: 18 Jul 2016 04:05:24
Message: <578c8dc4@news.povray.org>
> confirm?
Slight? You are kidding! :-)
The speed increase is huge in fact compared to version 3.7.
With the attached quick-and-dirty scene I get the following results
using 1 million iterations:
+av151; macro inside scene parsing time: 1 minute 5 seconds (65.988 seconds)
+av151; macro outside scene parsing time: 1 minute 6 seconds (66.971
seconds)
V 3.7; macro inside scene parsing time: stopped parsing manually after
more than 10 minutes!
Note: for using the test scene with outside macro, just copy the macro
to another place and uncomment the macro's include.
> have hidden there.
Not found any yet.
Download 'clipka_cached macros_test.pov.txt' (2 KB)
Date: 18 Jul 2016 04:17:28
Message: <578c9098$1@news.povray.org>
Am 17.07.2016 um 21:25 schrieb Jim Holsenback:
I guess that's a matter of philosophy: Do you want the documentation to
generally reflect the newest version (even if that's still under
development), with side notes mentioning what features aren't available
in earlier versions, or do you want the documentation to generally
reflect a well-established version, with side notes mentioning the
features added in newer version?
So far I have been following the latter approach for documenting the new
3.7.1 features, mostly because 3.7.1 hasn't even reached beta phase yet;
theoretically, any modifications since 3.7.0 are still subject to
change, and 3.7.0 is still the latest version for which we provide a
Windows installer.
But if you are significantly more comfortable with the former approach,
I can live with that as well.
Date: 18 Jul 2016 05:48:43
Message: <578ca5fb$1@news.povray.org>
Am 18.07.2016 um 10:05 schrieb Thomas de Groot:
>> confirm?
Actually no, I'm not.
> seconds)
> seconds)
I was quite puzzled about your results, until I saw your test scene, and
found that the in-file macro you presumably tested actually calls
various other macros, which are declared in rand.inc. So what you are
actually measuring is the speed of macro invocations across file boundaries.
With the macros RRand, VRand_In_Box and VRand_In_Obj moved to the scene
itself and "rand.inc" no longer included, I actually see a noteworthy
_slowdown_ in parsing time on my machine: about 60 seconds, as opposed
to 45 seconds with 3.7.0.
The picture changes a bit when the scene file is large -- or, more
precisely, when the macro is declared far away from where it is invoked:
With approximately 64k worth of comments inserted between the macro
declaration and its invocation, the parse time increases to about 95
seconds with 3.7.0, while remaining at about 60 seconds with the new
version.
This is to be expected, since the parser uses buffered file access, with
a 64k buffer on Windows machines, so in 3.7.0 a macro invoked from near
its declaration may still be included in the buffer, in which case
parsing can proceed without actual file access, while a farther-away
macro will trigger a 64k read to fill the buffer with different content.
It's still a good deal faster than cross-file invocation, since there is
no need to re-open another file. As for why macro caching is slower than
3.7.0's "near invocation", that's because it also adds a bit of overhead
every time a macro is invoked from the cache.
I'd be interested to hear from the Linux jockeys how they are faring
with in-file macro invocation. I'd expect a similar picture as with
Windows, but the "sweet spot" may be around 0.5k worth of code between
macro declaration and invocation, since that's the size of the buffer on
Unix. Then again, Unix may provide additional buffers for file access --
there must be a reason why POV-Ray's own buffers where chosen that small
on the Linux platform.
One thing seriously worrying me, however, is that the version using
cached macros exhibits seriously worse parsing performance on the 2nd
and any subsequent runs, taking about 100 seconds instead of 60 seconds.
Not sure yet what's going on there.
Date: 18 Jul 2016 06:08:53
Message: <578caab5$1@news.povray.org>
> Windows installer.
well yikes ... was hoping for a less vague response. i was just trying
to be proactive. back when the new / change template request was
suggested i roughed something out quickly but didn't get a chance to
implement, then noticed it's usage in the documentation. couple of day
ago had some time to put towards this and finished up the templates,
found ALL the old usage and changed to new, even added code to
wikidocgen to translate template to it's html equivalent. now i'm unsure
what to do next because i was under the impression that we were running
as fast as we can towards 3.7.1 release ... well like i said now i'm not
sure anymore
Date: 18 Jul 2016 06:30:48
Message: <578cafd8$1@news.povray.org>
>> Windows installer.
> sure anymore
just a follow up ... to address the concern that i /might/ be getting
ahead of the game here.
Welcome to the POV-Ray version 3.7.x documentation repository ... if
you're looking for the most up to date documentation, you've found it!
This content is used to generate the documentation included with the
distribution, so occasionally it can get ahead of the current release.
this preamble /is/ there for /everyone/ to see at:
http://wiki.povray.org/content/Documentation:Contents
Date: 18 Jul 2016 07:29:49
Message: <578cbdad@news.povray.org>
> between macro declaration and invocation, since that's the size of
> the buffer on Unix. Then again, Unix may provide additional buffers
> for file access -- there must be a reason why POV-Ray's own buffers
> where chosen that small on the Linux platform.
   Using Thomas example on my recently installed Ubuntu 16.04:
   current alpha, inside : 1m20s
   current alpha, outside: 1m20s
   previous alpha, inside: 8m11s
   previous alpha, outside: 12m46
   Can I just say "wow!"?
> 2nd and any subsequent runs, taking about 100 seconds instead of 60
> seconds. Not sure yet what's going on there.
   Cannot see that here... subsequent runs still take 1m20s.
jaime
Date: 18 Jul 2016 07:47:04
Message: <578cc1b8@news.povray.org>
[snip]
I like how you've done these. Seems pretty clear to me.
-- Chris
Date: 18 Jul 2016 07:49:07
Message: <578cc233$1@news.povray.org>
> now on.
Nice improvement there Christoph :)
-- Chris
Date: 18 Jul 2016 07:55:27
Message: <578cc3af$1@news.povray.org>
Am 18.07.2016 um 13:29 schrieb Jaime Vives Piqueres:
I presume the "inside" is still with the random macros residing in
"rand.inc", right?
Remember that under those conditions, that's still mostly a test of the
"outside" macros.
Note that "subsequent runs" on Windows means the executable isn't
terminated between runs. On Linux, the closest equivalent would be
subsequent frames in an animation.
Date: 18 Jul 2016 08:46:28
Message: <578ccfa4$1@news.povray.org>
> "rand.inc", right?
   Yes...
> the "outside" macros.
   Ok, will try a more "pure inside" test later.
   Ah... then I just traced a few frames: the first took 1m20s, and
subsequent ones took 1m24s. Not a big increase.
jaime
Date: 18 Jul 2016 08:55:40
Message: <578cd1cc$1@news.povray.org>
Am 18.07.2016 um 13:49 schrieb Chris Cason:
>> now on.
Dunno. I'm just realizing that I've implemented in the wrong place: By
using the existing IMemStream, which parallels basic file access as
implemented by the IStream family, parsing of cached macros currently
still uses the file buffer mentioned in one of the other posts, being
implemented in the ITextStream. This means some unnecessary bulk data
copies in memory.
I'm now pondering whether to solve this by implementing an unbuffered
alternative to ITextStream, which would still access an underlying
IStream, or whether to implement an alternative to ITextStream that
reads directly from the macro cache.
Date: 18 Jul 2016 08:59:07
Message: <578cd29b$1@news.povray.org>
>>> confirm?
>> seconds)
>> seconds)
You are right of course. I am so used to this kind of scene building
that I forgot the rand.inc implications. I shall have to retest this
better tomorrow.
Date: 18 Jul 2016 13:49:17
Message: <578D169D.3000705@ignorancia.org>
> "rand.inc", right?
   Ok, revised results with "everything inside" (copy-paste of 3 macros
from rand.inc"):
   current alpha : 1m20s
   previous alpha: 1m20s
   kinda logical, isn't?
jaime
Date: 18 Jul 2016 17:05:10
Message: <578d4486$1@news.povray.org>
Am 18.07.2016 um 19:49 schrieb Jaime Vives Piqueres:
> from rand.inc"):
What happens if you put >512 bytes between the macro declarations and
the place where they're invoked?
No, not necessarily.
With the new version, macros are always executed from the cache (unless
they're larger than 64k), while previously they were executed from
buffered file access. The two approaches involve different types of
overhead, so I'd normally expect them to actually result in at least
slightly different execution times.
Date: 18 Jul 2016 17:27:55
Message: <578d49db$1@news.povray.org>
>> from rand.inc"):
   Nothing... still 1m20s.
   The difference must be really small in this case then...
jaime
Date: 18 Jul 2016 17:47:33
Message: <578d4e75$1@news.povray.org>
Am 18.07.2016 um 23:27 schrieb Jaime Vives Piqueres:
>>> from rand.inc"):
Did you verify that you're testing the right versions?
Apparently.
Date: 19 Jul 2016 03:28:34
Message: <578dd6a2$1@news.povray.org>
Correct. the 1 minute 5 seconds I mentioned previously, against 54
seconds in standard version.
Date: 19 Jul 2016 07:45:26
Message: <578e12d6@news.povray.org>
>>>> from rand.inc"):
  Yes, I just checked the test was using correct versions. Now, testing a
bit further, I don't get any noticeable increase in parse time until I
increase the extra in-between comments to 2017 bytes. With 2016 bytes it
still parses on 1m20s, but with 2017 it jumps to 1m24s and keeps stable
at that time even if I increase the extra comments further.
jaime
Date: 19 Jul 2016 19:16:50
Message: <578eb4e2$1@news.povray.org>
Ok, folks -- I've just submitted an update to the macro caching
mechanism. The 64k (Windows) / 0.5k (Linux) buffer is now bypassed,
further increasing the parsing speed of Thomas' demo scene on my machine
from 60 to 50 seconds.
Please test intensively.
Date: 20 Jul 2016 04:00:54
Message: <578f2fb6$1@news.povray.org>
Looking good. I tested with/without little counter:
av155; macros in; counter yes: 57 sec (57.283)
av155; macros in; counter no: 53 sec (53.836)
av155; macros out; counter yes: 1 min 10 sec (70.232)
av155; macros out; counter no: 1 min 6 sec (66.862)
v3.7.0; macros in; counter yes: 56 sec (56.145)
v3.7.0; macros in; counter no: 53 sec (53.118)
I leave the in-between comments testing to Jaime ;-)
Date: 20 Jul 2016 06:40:04
Message: <578f5504$1@news.povray.org>
> machine from 60 to 50 seconds.
   Hmmm... here the new version is a bit slower parsing: from 1m20s to
1m23s, either with macros defined inside or outside, and even with
in-between comments no matter the size (I tried several MB of comments
and it still parsed in 1m23s).
3.7.1-alpha.8704732.unofficial (g++ 5.4.0 @ x86_64-pc-linux-gnu)
jaime
Date: 20 Jul 2016 07:43:59
Message: <578f63ff$1@news.povray.org>
Am 20.07.2016 um 12:40 schrieb Jaime Vives Piqueres:
Hmm... maybe that's due to the top layer in the file access
(ITextStream, the one where the buffer used to reside in) now using
polymorphism. Still, it puzzles me a bit why the copying-around of the
macro content does so little to counteract that penalty. Might even have
to do with CPU properties.
Since this 3.6% performance loss on your machine buys a 12% performance
bonus on Thomas' machine, I guess I'm willing to pay that price.
Date: 20 Jul 2016 08:15:15
Message: <578f6b53$1@news.povray.org>
You put that in, to be commented upon. Didn't you? ;)
Regards
Date: 20 Jul 2016 10:59:14
Message: <578f91c2$1@news.povray.org>
Ubuntu 14.04 (i3-4130). Latest always came in faster for me using a
scene of my own. Inserted an error statement to stop after parsing so
these times are for the parsing phase. Command suffix the commit.
-------------------------- Disk ----------------------------
povray371_2965368:
Command exited with non-zero status 1
158.46user 3.64system 2:42.42elapsed 99%CPU (0avgtext+0avgdata
151536maxresident)k
0inputs+6608outputs (0major+28992minor)pagefaults 0swap
povray371_8e965a9:                       -8.60% (elapsed)
148.02user 0.08system 2:28.45elapsed 99%CPU (0avgtext+0avgdata
151548maxresident)k
0inputs+6608outputs (0major+28482minor)pagefaults 0swaps
-------------------------- Memory disk ---------------------
povray371_2965368:
153.68user 3.26system 2:37.26elapsed 99%CPU (0avgtext+0avgdata
151676maxresident)k
0inputs+0outputs (0major+28482minor)pagefaults 0swaps
povray371_8e965a9:
Command exited with non-zero status 1    -3.85% (elapsed)
150.72user 0.14system 2:31.20elapsed 99%CPU (0avgtext+0avgdata
151460maxresident)k
0inputs+0outputs (0major+28477minor)pagefaults 0swap
-------------------------- Memory disk (one file) ----------
povray371_2965368:
151.63user 1.63system 2:33.59elapsed 99%CPU (0avgtext+0avgdata
151628maxresident)k
0inputs+0outputs (0major+28479minor)pagefaults 0swaps
povray371_8e965a9:
Command exited with non-zero status 1    -3.37% (elapsed)
148.01user 0.07system 2:28.41elapsed 99%CPU (0avgtext+0avgdata
151556maxresident)k
0inputs+0outputs (0major+28988minor)pagefaults 0swaps
Date: 20 Jul 2016 11:15:44
Message: <578f95a0$1@news.povray.org>
Am 20.07.2016 um 14:15 schrieb Stephen:
Absolutely. Substantial ones preferred, thanks :P
Date: 20 Jul 2016 11:23:58
Message: <578f978e$1@news.povray.org>
Am 20.07.2016 um 16:59 schrieb William F Pokorny:
> povray371_2965368:
Just wondering -- which one is that? I failed to find any commit with
that id in the repository.
Date: 20 Jul 2016 12:22:25
Message: <578fa541$1@news.povray.org>
>> povray371_2965368:
POV-Ray 3.7.1-alpha.8697045.unofficial
No idea what happened...
git log --oneline currently shows me:
8e965a9 Improved cached macro performance.
fa3a1dc Fixed a code flaw in macro caching.
39a6c9f [ci skip] Minor changes to comments and dev documentation.
edfae26 Fixed a bug in cleanup of fog with turbulence.
3b5b4eb added missing file pavement_s3_t6_p12.txt / issue #37 (#77)
051b674 Implemented macro caching.
2d0a42c fix filenames / issue #36 (#76)
And looking back through my bash command history 2d0a42c is what I
checked out ahead of the compile to the pre-cached macro version.
"git checkout 2d0a42c"
Bill P.
Date: 20 Jul 2016 12:32:50
Message: <578fa7b2$1@news.povray.org>
> the macro content does so little to counteract that penalty. Might
> even have to do with CPU properties.
   AMD FX-6300 here...
> performance bonus on Thomas' machine, I guess I'm willing to pay that
> price.
   Well, it's still a little loss compared to the huge gain respect to
the old macros mechanism. Good job!
jaime
Date: 21 Jul 2016 02:13:46
Message: <5790681a$1@news.povray.org>
I thought so too. So, I agree with Jaime that the principal gain is on
the outside use of macros and that is more than a bonus. Excellent job
indeed!
Date: 22 Jul 2016 05:20:37
Message: <5791e565@news.povray.org>
And on Macintosh:
- 3.7.0
allInside: 32,957 sec
allOutside: 96,369 sec
rodOutsideRandInside:  481,025 sec  !! (8minutes)
- av155
allInside: 37,021 sec
allOutside:  36,480 sec
rodOutsideRandInside: 36,869 sec
Files used:
// Persistence of Vision Ray Tracer Scene Description File
// File: Clipka_cached macros_test.pov
// Vers: 3.7.1 Cached Macros version
// Desc: Basic Scene Example
// Date: mm/dd/yy
// Auth: ?
#version 3.7;
#declare allInside = 1;
#declare allOutside = 2;
#declare rodOutsideRandInside = 3;
#declare MacroType = allInside;
#if ( (MacroType = allInside) | (MacroType = rodOutsideRandInside))
	 #debug "\nRand inside"
	#macro VRand_In_Box(Mn, Mx, RS) (< rand(RS), rand(RS),
rand(RS)>*(Mx-Mn) + Mn) #end
	#macro RRand(Min, Max, RS) (rand(RS)*(Max-Min) + Min) #end
	#macro VRand_In_Obj(Obj, RS)
    		#local Mn = min_extent(Obj);
   		 #local Mx = max_extent(Obj);
    		#local Pt = VRand_In_Box(Mn, Mx, RS);
    		#local J = 0;
   		 #while(inside(Obj, Pt) = 0 & J < 1000)
        		#local J = J + 1;
    	(Pt)
#end //if (MacroType = allInside || MacroType = rodOutsideRandInside)
#if (MacroType = allInside )
	 #debug "\nRod inside"
	#macro Rods()
	#ifndef(Box)
		#declare Box =
		box {
  			<-10, 0, -10>,<10, 0.2, 10>
  			translate 10*y
		#declare Rand = seed(1101);
	#end //#ifndef(Box)
	#declare Norm  = <0, 0, 0>;
	#declare Start = VRand_In_Obj(Box, Rand);
	#declare Pos   = trace (Surface, Start, -y, Norm);
	#declare Cyl =
	cylinder {
 		 0, <0,1,0>, 0.05
 		 scale <1, RRand(0.5, 1.5, Rand), 1>
  		translate Pos
  		pigment {srgb <RRand(0.1, 0.9, Rand), RRand(0.1, 0.9, Rand),
RRand(0.1, 0.9, Rand)>}
	#end //	#macro Rods()
#end //#if (MacroType = allInside || MacroType = allOutside)
#if (MacroType = allOutside   | MacroType = rodOutsideRandInside)
	#include "rods.inc"
global_settings {
  assumed_gamma 1.0
  location  <0.0, 5, -40.0>
  direction 1.5*z
  look_at   <0.0, 0.0,  0.0>
sky_sphere {
    gradient y
    color_map {
      [0.0 srgb <0.6,0.7,1.0>*1.3]
      [0.7 srgb <0.0,0.1,0.8>*1.3]
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <-3, 3, -3>*1000
#declare Surface =
plane {
  y, 0
  pigment { color srgb <0.7, 0.5, 0.3> }
object {Surface}
#declare I=0;
#for (I, 0, 1000000)
Rods()
object {Cyl}
#if (mod(I,10000) = 0)
  #debug concat("\nRods: ", str(I,4,0))
//File: rods.inc
#if (MacroType = allOutside)
	 #debug "\nRand outside"
	    #local J = 0;
	        #local J = J + 1;
	    (Pt)
	#end //#macro VRand_In_Obj(Obj, RS)
#end //#if (MacroType = allOutside)
#if (MacroType = allOutside | (MacroType = rodOutsideRandInside))
	 #debug "\nRod outside"
	#macro Rods()
		#ifndef(Box)
		#declare Box =
		box {
		  translate 10*y
		#declare Cyl =
		cylinder {
		  0, <0,1,0>, 0.05
		  translate Pos
POV-Ray 3.7 unofficial: http://megapov.inetart.net/povrayunofficial_mac/
UberPOV Mac: http://megapov.inetart.net/uberpov_mac/index.html#Mac
MegaPOV: http://megapov.inetart.net
E-mail: yvo(DOT)s(AT)gmx.net
Download 'iso-8859-1' (17 KB)
