POV-Ray : Newsgroups : povray.beta-test : bezier.pov Server Time
10 Nov 2026 17:26:53 EST (-0500)
  bezier.pov (Message 1 to 26 of 26)
Subject: bezier.pov
Date: 4 Mar 2016 10:11:01
Message: <56d9a585@news.povray.org>
scenes/objects/bezier.pov
8< snip >8
bicubic_patch { type 1 flatness 0.1  u_steps 8  v_steps 8
8< snip >8
I don't see a bicubic_patch 8[
Any confirmations?
Thorsten aka ThH
Subject: Re: bezier.pov
Date: 4 Mar 2016 10:41:14
Message: <56d9ac9a$1@news.povray.org>
Messed up. Second try ...
Am 04.03.2016 um 16:11 schrieb ThH:
> 8< snip >8
> 8< snip >8
> Any confirmations?
> Thorsten aka ThH
...any bicubic _patch...
Only the background is visible in the rendered image.
Date: 4 Mar 2016 11:22:01
Message: <56d9b629$1@news.povray.org>
>> 8< snip >8
>> 8< snip >8
>> Any confirmations?
>> Thorsten aka ThH
Same here. The patch disappears in 3.7.1-alpha.8499454 while it works in
3.7.0-stable.
Ubuntu 14.04.
Bill P.
Date: 4 Mar 2016 11:40:46
Message: <56d9ba8e$1@news.povray.org>
Am 04.03.2016 um 17:22 schrieb William F Pokorny:
> 3.7.0-stable.
Thanks for your confirmation Bill :))
> Ubuntu 14.04.
Debian "Jessie" here ;) Used Ubuntu for a long time before changing to
Debian last december.
Date: 4 Mar 2016 12:59:41
Message: <56d9cd0d$1@news.povray.org>
>>> Any confirmations?
> 3.7.0-stable.
> Ubuntu 14.04.
Want to take a guess what I see with the Windows version?
(Spoiler alert!)
Hey, it's an issue reported by ThH. _Of course_ it works perfectly fine
on Windows >_<
Date: 4 Mar 2016 13:01:09
Message: <56d9cd65$1@news.povray.org>
>>> 8< snip >8
>>> 8< snip >8
>>> Any confirmations?
>>> Thorsten aka ThH
3.7.0-stable.
Testing 3.7.1-alpha.8503825.unofficial, the object is there, same as with stable
version.
(but with gcc and intel compiler, but not clang, my own master branch does have a
small problem of two squares on the patch that are gone, but that's another story)
Ubuntu 15.10
> Ubuntu 14.04.
> Bill P.
Date: 4 Mar 2016 13:22:32
Message: <56d9d268$1@news.povray.org>
Am 04.03.2016 um 19:01 schrieb Le_Forgeron:
3.7.0-stable.
version.
While I did my own testing with 3.7.1-alpha.8503825 as well, I'd be
quite surprised if any of the changes since alpha.8499454 had fixed it.
They appear to be as unrelated as I could possibly imagine.
Date: 4 Mar 2016 13:24:30
Message: <56d9d2de$1@news.povray.org>
Am 04.03.2016 um 18:59 schrieb clipka:
> on Windows >_<
Haha :D
No reason for me to change the OS ;))
Just hoping it's your natural interest to get it fixed for Linux users :))
Date: 4 Mar 2016 13:41:49
Message: <56d9d6ed$1@news.povray.org>
3.7.0-stable.
version.
Think you are correct. I just pulled and compiled 3.7.1-alpha.8503825 on
seeing Jérôme at a newer version, but still nothing (no ray patch
intersections are found). So maybe a 14.04 vs 15.1 difference ?
My compiler is g++ 4.8.
Bill P.
Date: 4 Mar 2016 13:51:51
Message: <56d9d947@news.povray.org>
3.7.0-stable.
version.
> Think you are correct. I just pulled and compiled 3.7.1-alpha.8503825 on seeing
Jérôme at a newer version, but still nothing (no ray patch intersections are found).
Nope, even with a produced "right" picture, valgrind reports a definitive problem of
uninitialised data.
Just ignore the syscall param write, the interesting parts seem to be in bezier.cpp
I presume even windows get the same problem if you have some auditing tools on it.
And using the same valgrind on the stable version: no such issue.
It's new, it's fresh, it's hidden and unreliable, due to the memory content.
Download 'memcheck2.txt' (48 KB)
Date: 5 Mar 2016 02:54:13
Message: <56da90a5$1@news.povray.org>
Am 04.03.2016 um 19:25 schrieb ThH:
>> on Windows >_<
> Haha :D
It is. But alas! ...
Well, you probably know the drill: Toy around and try to figure out
/some/ useful information.
@Jerome: Care to do some "binary search" again to narrow down the
offending version?
(Let me guess: It's that range of commits again that refuses to compile
on Linux, right?)
Date: 5 Mar 2016 03:14:14
Message: <56da9556$1@news.povray.org>
Am 04.03.2016 um 19:51 schrieb Le_Forgeron:
uninitialised data.
If valgrind was right, that would certainly explain the problems.
Unfortunately it's mistaken.
Valgrind's report indicates that Bezier_Node_Struct::Radius_Squared is
not (or not always) initialized properly when
BicubicPatch::bezier_tree_walker() is called.
But if that is the case, then adding
    Node->Radius_Squared = -1;
to BicubicPatch::create_new_bezier_node() and adding
    POV_ASSERT(Node->Radius_Squared >= 0);
to the beginning of BicubicPatch::bezier_tree_walker() should force the
code to bomb.
It doesn't. Valgrind must be seeing ghosts.
Date: 5 Mar 2016 04:10:49
Message: <56daa299$1@news.povray.org>
Am 05.03.2016 um 08:54 schrieb clipka:
SIR YESSSS SIR... Just had some other things to do... SIR !
8< snip >8
//bicubic_patch { type 1 flatness 0.1  u_steps 8  v_steps 8
bicubic_patch { type 0 flatness 0.1  u_steps 8  v_steps 8
8< snip >8
Line 1: no_image effect ;)
Line 2: 8D
SIR!
Time for breakfast here...
Date: 5 Mar 2016 04:19:05
Message: <56daa489$1@news.povray.org>
Am 05.03.2016 um 10:11 schrieb ThH:
SOLDIER, I don't remember having ordered you to do OTHER THINGS!
> 8< snip >8
> 8< snip >8
> Line 2: 8D
Does that mean "it works"?
Date: 5 Mar 2016 04:25:47
Message: <56daa61b$1@news.povray.org>
Am 05.03.2016 um 10:19 schrieb clipka:
Sir soldier used it's brain SIR !
>> Line 2: 8D
Yes.
Date: 5 Mar 2016 09:23:08
Message: <56daebcc$1@news.povray.org>
of uninitialised data.
> code to bomb.
I do not say that the Radius_Squared is not initialized...
but adding
memset(Node, 0, sizeof(BEZIER_NODE));
in create_new_bezier_node does remove the issue with valgrind.
Now, remember that we are using -O3 as default level of optimisation,
which means the execution can be reported on line X while the compiler
is actually performing some operations of line X-1 or X+1.
And we are dealing with an hybride code: the declaration of Bezier_Node_Struct is a
100% C++ thing,
with an implicit constructor that would call Véctor3d constructor for Center,
yet create_new_bezier_node is a C thing, calling a memory allocator and casting the
type.
The other members of Bezier_Node_Struct are still C thing, so they are not
initialised.
Nevertheless, for Center, the code that computes it has been "optimised".
Instead of using a temporary variable, initialised to 0 (xc, yc, zc), to add the
various contributions
and then copying the result in Center at the end, the function now add directly the
to Center. But what if... you start with *garbage* in Center ? Garbage in, Garbage
out.
(it's in bezier_bounding_sphere() )
And to finish it (give me a hammer, that's the last nail on the coffin):
 If I replace the memset over the whole structure with just (in addition to Data_Ptr =
NULL):
 Node->Center = Vector3d();
valgrind become as happy as with the full initialisation.
Even a bigger hammer: if I use memset with a value of 0xFF (instead of 0), I get a
100% background image.
Reliably.
Date: 6 Mar 2016 01:20:03
Message: <web.56db04ff8ece4badc77518d0@news.povray.org>
> Reliably.
That did the trick.
Found the culprit and about to submit a fix any moment now.
Message: <web.56db0b418ece4badc77518d0@news.povray.org>
Please test the newest master.
Date: 6 Mar 2016 03:18:01
Message: <56dbe7b9$1@news.povray.org>
POV-Ray 3.7.1-alpha.8508492.unofficial seems ok, at least for valgrind (but I was only
getting small artefacts, randomly)
Date: 6 Mar 2016 03:19:15
Message: <56dbe803$1@news.povray.org>
Good to be back on news.povray.org:119 !
Am 05.03.2016 um 17:37 schrieb clipka:
Bezier is fine now. Thanks clipka :))
Thorsten aka ThH
povray --V
Date: 6 Mar 2016 03:25:11
Message: <56dbe967$1@news.povray.org>
Am 06.03.2016 um 09:18 schrieb Le_Forgeron:
only getting small artefacts, randomly)
Does it also affect the Leak Summary?
Date: 6 Mar 2016 03:31:19
Message: <56dbead7$1@news.povray.org>
Am 06.03.2016 um 09:20 schrieb ThH:
bezier.pov shows some artefacts.
flatness seems to have some influence on this. Lower flatness, less/no
artefacts.
Just to let you know ;)
Date: 6 Mar 2016 03:42:12
Message: <56dbed64@news.povray.org>
If you want more details about the leak, attached file was done with:
valgrind --log-file=memcheckpovray2.txt --track-origins=yes --leak-check=full dmpovray
bezier.pov
Download 'memcheckpovray2.txt' (24 KB)
Date: 6 Mar 2016 03:46:10
Message: <56dbee52$1@news.povray.org>
Am 06.03.2016 um 09:32 schrieb ThH:
> artefacts.
Thin lines?
They're normal, and the flatness parameter is indeed the setting to
counteract them.
Date: 6 Mar 2016 03:47:35
Message: <56dbeea7$1@news.povray.org>
dmpovray bezier.pov
And to compare with the stable head, another attached file.
It was less leaking before :-)
Download 'memcheckpovray.txt' (6 KB)
Date: 6 Mar 2016 04:09:43
Message: <56dbf3d7$1@news.povray.org>
Am 06.03.2016 um 09:46 schrieb clipka:
> Thin lines?
Yes.
> counteract them.
Looked up the docs. That's why I tried this ;)
To be honest... I've never used bicubic_patch before.
For me the image is fine :)
The 'rest' is yours.
Only citing valgrind here: Go fix your program! ;))
