POV-Ray : Newsgroups : povray.beta-test : splinefollow Server Time
10 Nov 2026 17:39:06 EST (-0500)
  splinefollow (Message 1 to 20 of 20)
Subject: splinefollow
Date: 27 Feb 2016 04:41:24
Message: <56d16f44$1@news.povray.org>
could some kind soul please check this...
Trying scenes/animation/splinefollow.pov I got this:
thh@quadro:~/POV_Master/share/povray-3.7/scenes/animations/splinefollow$
povray splinefollow.pov +p +w320 +h240
Persistence of Vision(tm) Ray Tracer Version
3.7.1-alpha.8492620.unofficial (g++
  4.9.2 @ x86_64-unknown-linux-gnu)
This is an unofficial version compiled by:
  ThH <no.spam@address>
  The POV-Ray Team is not responsible for supporting this version.
8< snip >8
==== [Parsing...] ==========================================================
Speicherzugriffsfehler
Thorsten aka ThH
Subject: Re: splinefollow
Date: 27 Feb 2016 04:49:18
Message: <56d1711e$1@news.povray.org>
Am 27.02.2016 um 10:42 schrieb ThH:
> 8< snip >8
> ==== [Parsing...]
Can't confirm for the Windows version.
Date: 27 Feb 2016 08:04:33
Message: <56d19ee1$1@news.povray.org>
Hash: SHA256
ow$
>> 3.7.1-alpha.8492620.unofficial (g++ 4.9.2 @
>> x86_64-unknown-linux-gnu) This is an unofficial version compiled
>> by: ThH <no.spam@address> The POV-Ray Team is not responsible for
>> 8< snip >8
>> ==== [Parsing...]
I can confirm for the master branch ( 3.7.1-alpha.8497793.unofficial )
Segmentation fault (core dumped)
No such problem on stable branch, and not yet either on my two branches.
So, it's new, it's fresh... (less than a year old)
traced to se.resize()
void mkfree(GenericSpline * sp, SplineEntryList::size_type i)
    SplineEntryList::size_type j;
    SplineEntryList& se = sp->SplineEntries;
    se.resize(se.size()+1);
    for (j=sp->SplineEntries.size()-1; j>i; j--)
        se[j] = se[j-1];
But it might be due to a previous memory corruption because the
segfault is due to malloc.c, a code that is safe as long as memory is
not corrupted.
I would bet for, somewhere else, a write out of allocated area.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iJwEAQEIAAYFAlbRnuAACgkQhKAm8mTpkW2wcwQA0kis+HZ0zkrjkpgdxvgeC2K6
R6KKULjeHiamzUhiZy14BLvONh13YqAbk0Tjh3V7D9CuNuuh6eHsLv3ImeAA3QhZ
vksF78lF7oGaJGRFI1r3Q8aO63jf58gtW5uw2eg4c6mdOFcWXfFzK+xuvF5qVdms
1FDrUDfkeAUtJUjpf18=
=Nu25
-----END PGP SIGNATURE-----
Date: 27 Feb 2016 08:33:50
Message: <56d1a5be$1@news.povray.org>
Am 27.02.2016 um 14:04 schrieb Le_Forgeron:
Thank you for checking and confirming Le_Forgeron :)
>          se[j] = se[j-1];
> not corrupted.
This part is for real coders, right? At least I can read it but am not
understanding it ;)
Date: 27 Feb 2016 08:46:01
Message: <56d1a899@news.povray.org>
s.
>>          se[j] = se[j-1];
>> not corrupted.
> understanding it ;)
Attached is a log from valgrind (a memory checker) about trying to run
splinefollow.
The spline parsing code should be checked, because it seems to have
miscounted its number of entries.
Download 'memcheck.txt' (16 KB)
Date: 27 Feb 2016 08:54:01
Message: <56d1aa79$1@news.povray.org>
Am 27.02.2016 um 14:45 schrieb Le_Forgeron:
> splinefollow.
I see 8)
Thank you again. Always learning something new :))
Date: 27 Feb 2016 08:55:18
Message: <56d1aac6@news.povray.org>
>         se[j] = se[j-1];
> not corrupted.
`se.resize()` is `std::vector::resize()`, so yes, I guess we can safely
presume that the error is somewhere else ;)
Date: 27 Feb 2016 09:11:07
Message: <56d1ae7b@news.povray.org>
Hash: SHA256
>> void mkfree(GenericSpline * sp, SplineEntryList::size_type i) {
>> SplineEntryList::size_type j; SplineEntryList& se =
>> sp->SplineEntries;
>> se.resize(se.size()+1); for (j=sp->SplineEntries.size()-1; j>i;
>> j--) se[j] = se[j-1]; }
>> memory is not corrupted.
> safely presume that the error is somewhere else ;)
Yes... And in fact, I already encountered that problem on my master
branch (which try to follow the official master... when I have time to
follow)
The problem is in Insert_Spline_Entry, the condition try to handle too
much and fails.
I rewrote it
https://bitbucket.org/LeForgeron/povray/src/8813d261f3c529cb734c0f5697b86e9dbf916966/source/backend/math/splines.cpp?at=default&fileviewer=file-view-default
Version: GnuPG v2
iJwEAQEIAAYFAlbRrnoACgkQhKAm8mTpkW2JwAP/cMQfYj7+N/rsONb1pADU3g3J
jW7hVB0agTuWk5+A2JXTPRLQY8gB4Ib34uGyou5Nu8kU55+H1ezcobmPYsmPKDUx
SngVsUesaDpeiSLYNXuemkSEr/Yo8LfZ73GhZEzqvpL/fPxunXN+KHnnQZz69NlE
cz9jRSt43BUAqSFySEQ=
=WTV+
Date: 27 Feb 2016 09:24:00
Message: <56d1b180@news.povray.org>
Hash: SHA256
If it can help, it's already in github
https://github.com/LeForgeron/povray/commit/489e2eaf8e655eacdf102b6d5961
3f0f725584b8
613f0f725584b8
But
I do not know how to create a pull request for a single commit..
Just do it if you can.
Version: GnuPG v2
iJwEAQEIAAYFAlbRsX4ACgkQhKAm8mTpkW1mqAQAjqYKwURLp8tSWg2/grQ32t2w
T7rs84l84xdCYaryIjRN8yxz9gcCJHf4XQCylSL5jAbwcQUSpL0rEfhwj9XrU7wd
lh2L2M0cPiOY7mFckZgfrMtO9L+ldpylQAXLShg1FPhZpaw6lrXxXVoKxLdw1Itc
Ny5OuHmz+Ou0Pr8/Yyw=
=2SFD
Date: 27 Feb 2016 09:35:38
Message: <56d1b43a@news.povray.org>
Am 27.02.2016 um 15:11 schrieb Le_Forgeron:
> much and fails.
Yup, the comparison is bogus: It tests `sp->SplineEntries[i].par == p`
before even verifying that i is within bounds.
Date: 27 Feb 2016 09:45:40
Message: <56d1b694$1@news.povray.org>
Strangely enough, the offending code has been around ever since we put
POV-Ray on GitHub, i.e. it is also in the stable branch.
Date: 27 Feb 2016 09:58:21
Message: <56d1b98d$1@news.povray.org>
Am 27.02.2016 um 15:23 schrieb Le_Forgeron:
> 3f0f725584b8
> 613f0f725584b8
> But
Actually your solution, too, still has a bug: If the last entry of the
spline is to be replaced, replacement is done on [i] when it should be
on [i-1].
Date: 27 Feb 2016 10:27:58
Message: <56d1c07e$1@news.povray.org>
>> 3f0f725584b8
>> 613f0f725584b8
>> But
> on [i-1].
I think that I just tried to "uncompress" the original condition (of
four tests) to avoid the problem.
And you are correct, the branch i==splineSize ... replace=true should
also reduce the value of i !
Nicely spotted.
Date: 27 Feb 2016 10:28:27
Message: <56d1c09b$1@news.povray.org>
> 8< snip >8
> ==== [Parsing...]
Please try the source code now available at
https://github.com/POV-Ray/povray (still waiting for the Windows builds
to complete, so it's not available in the Releases section yet).
Date: 27 Feb 2016 10:45:22
Message: <56d1c492@news.povray.org>
Gitid: 832d5713976c6f883c8242035b9694c262b07fc5
still crashing... do not try to be smart, if spline is not empty, and i
is size, but last entry is not the new index, you take the else
branch... and access out of bound to compute replace.
+    if (!sp->SplineEntries.empty())
+        if (i == sp->SplineEntries.size() &&
(sp->SplineEntries[i-1].par == p))
+            --i;
+            replace = true;
+        else
+            replace = (sp->SplineEntries[i].par == p);
I unrolled the code... there was a reason.
Date: 27 Feb 2016 11:01:44
Message: <56d1c868@news.povray.org>
Am 27.02.2016 um 16:45 schrieb Le_Forgeron:
> still crashing...
Same here.
> +            --i;
> +            replace = true;
> +        else
Date: 27 Feb 2016 11:24:07
Message: <56d1cda7$1@news.povray.org>
Am 27.02.2016 um 17:02 schrieb ThH:
>> still crashing...
> Same here.
Please try again with the newest stuff.
Date: 27 Feb 2016 11:56:41
Message: <56d1d549$1@news.povray.org>
>>> still crashing...
>> Same here.
works better with POV-Ray 3.7.1-alpha.8498421.unofficial
Gitid: 6211eee2626b8ebc0b2a3364798c2c0be5fcf57c
no more crash for splinefollow
Date: 27 Feb 2016 12:02:39
Message: <56d1d6af$1@news.povray.org>
Am 27.02.2016 um 17:56 schrieb Le_Forgeron:
>>>> still crashing...
>>> Same here.
Same here. Fine :))
Date: 27 Feb 2016 19:07:24
Message: <56d23a3c@news.povray.org>
Damn, did we just discover again a bug here, CLIPKA? :-D
Ts, ts, ts...
> 8< snip >8
> ==== [Parsing...]
