POV-Ray : Newsgroups : povray.beta-test : New semi-official development build Server Time
10 Nov 2026 17:39:06 EST (-0500)
  New semi-official development build (Message 1 to 9 of 9)
Subject: New semi-official development build
Date: 21 Jan 2015 18:04:42
Message: <54c0308a$1@news.povray.org>
Hi folks,
a new set of semi-official Windows binaries of the current development
branch can be found at:
https://github.com/c-lipka/povray/releases/tag/v3.7.1-alpha.7918791
Don't be alarmed at the "alpha" version number; being only a
semi-official release, it simply lacks an official beta number.
As always, Unix jockeys can find the latest and greatest dev source code at:
https://github.com/POV-Ray/povray
Subject: Re: New semi-official development build
Date: 23 Jan 2015 03:13:47
Message: <54c202bb$1@news.povray.org>
Thanks. Are there particular things we need to be aware of or we need to
look for?
Date: 23 Jan 2015 11:17:12
Message: <54c27408$1@news.povray.org>
Am 23.01.2015 um 09:13 schrieb Thomas de Groot:
> look for?
Under the hood, so much has changed that you'll probably want to keep an
eye on anything suspicious.
There's one potentially breaking change: Where the parser expects a
filename, it used to ignore (most) escape sequences; while this allowed
the easy use of backslashes in literal filenames, it was obviously
inconsistent and never really documented. Specifying "#version 3.71"
will cause backslashes to be treated consistently in all string literals.
A few changes to SDL worth experimenting with:
* More realistic finish:
- Radiosity now fully supports brilliance; specify "brilliance on" in
the global radiosity settings to activate.
- Brilliance is now taken into account not only for incoming light, but
also for outgoing light; specify "brilliance FLOAT,FLOAT" to activate
(set both values to same for most realistic results).
- Fresnel angle-dependent attenuation is now also available for
highlights and diffuse; specify "fresnel on" directly in the finish
block (another "fresnel on" is still needed in the reflection block).
* Nonlinear colour map and pigment map gradients:
- Specify "blend_mode 1" in a colour or pigment map to force linear
interpolation regardless of assumed_gamma, which is presumed to be
physically most realistic, and has also proven to give visually pleasing
colour gradients.
- Specify "blend_mode 2 blend_gamma FLOAT" to force non-linear
interpolation as if assumed_gamma was set to FLOAT (defaulting to 2.5),
which is known to give visually pleasing brightness gradients.
- Specify "blend_mode 3 blend_gamma FLOAT" to force non-linear
interpolation of luminance, while forcing linear interpolation of
chromaticity, to give gradients that are visually pleasing with respect
to both brightness and colour.
* True inverse-power-law light fading:
- Specify "fade_power FLOAT fade_distance 0" (with FLOAT=2 for physical
realism) to have the light intensity follow a true inverse power law,
reaching nominal intensity at a distance of 1 unit (requires #version 3.71).
A few other highlights since v3.7.0 release proper:
* Removed limit of 256 entries per blend map.
* Removed limit of 1000000 components per blob.
* Improved accuracy of media sampling in mode 3.
Date: 26 Jan 2015 07:20:41
Message: <54c63119$1@news.povray.org>
This:
       color_map {
         blend_mode 1
         [0.10  color Red transmit 0.5]
         [0.50  color Green transmit 0.5]
         [0.90  color Yellow transmit 0.5]
gives a parse error: Must have at least one color in color map
This:
       pigment_map {
         blend_mode 1
         [0.10  rgb <1,0,0> transmit 0.5]
         [0.50  rgb <0,1,0> transmit 0.5]
         [0.90  rgb <1,1,0> transmit 0.5]
works correctly.
Date: 26 Jan 2015 07:47:35
Message: <54c63767$1@news.povray.org>
Second comment: Changing blend_gamma in blend_mode 3 does not make any
visible difference. All settings equal to blend_mode 1.
Date: 26 Jan 2015 15:53:27
Message: <54c6a947@news.povray.org>
Am 26.01.2015 um 13:20 schrieb Thomas de Groot:
> This:
>        color_map {
>          blend_mode 1
Whoops - to my surprise you're right.
I'll look into it.
Date: 26 Jan 2015 16:11:52
Message: <54c6ad98@news.povray.org>
Am 26.01.2015 um 13:47 schrieb Thomas de Groot:
If your transitions are between different colours, with not much
difference in brightness, then that is to be expected.
If your transitions are between different brightness levels, with not
much difference in colour, then I am inclined to attribute your
observation to you doing something wrong ;)
Here's what I get with blend_mode 3, and blend_gamma varying from 0.5
(left) to 2.5 (center) to 7.5 (right). Note the differences in the
struts connected to the black ball.
Download 'gradients.png' (95 KB)
Preview of image 'gradients.png'
Date: 26 Jan 2015 18:21:06
Message: <54c6cbe2$1@news.povray.org>
Am 26.01.2015 um 21:53 schrieb clipka:
>> This:
>>        color_map {
>>          blend_mode 1
> I'll look into it.
Fixed with commit 44d47df. As a preliminary workaround until a new
Windows binary is released, I suggest simply replacing "color_map" with
"pigment_map".
Date: 27 Jan 2015 03:06:43
Message: <54c74713$1@news.povray.org>
OK! My experiment was mainly with fairly equal brightness. I see now
what you mean. Thanks!
