Am 17.08.2012 22:08, schrieb Le_Forgeron:
> Should the literal be extended with a "u" to make it happy ?
Yes.
> (only the 3 big ones)
Why not all of them?
On 8/17/2012 4:17 PM, clipka wrote:
>> vfesession.cpp:594:11: warning: case label value is less than minimum
>> value for type [enabled by default]
> That line seems somewhat bogus.
Variable 'm_BackendState' is declared as type 'State' (vfe/vfesession.h
line 1316). The switch statement (vfe/vfesession.cpp line 576) contains
a 'case -1:'. Whoever wrote that code perhaps expected that
m_BackendState could have the value '-1'. If it does, then the case will
never be caught since '-1' is not a valid value for that enum.
Am 17.08.2012 23:35, schrieb Dave:
Yes, that's what I'm thinking. Have done some quick code digging to see
if it is ever set to -1 somewhere, but it turns out to be more than a
5-minute job.
clipka <ano### [at] anonymous org> wrote:
> Am 17.08.2012 19:53, schrieb Dave:
> > renderfrontend.cpp:1165:57: warning: trigraph ??) ignored, use
> > -trigraphs to enable [-Wtrigraphs]
> Trigraphs suck, but yes, we should avoid them.
Hard to believe there was a time when not all English-based computers understood
7-bit ASCII.
Am 18.08.2012 00:39, schrieb Cousin Ricky:
> 7-bit ASCII.
Well, the trigraphs were there for /non/ English-based computers, which
often used 7-bit national derivatives of ASCII. Those typically replaced
a common set of 8 characters - curly braces, square brackets, pipe
symbol, backslash, tilde and hash - with language-specific characters
(in the German "GSCII", for instance, those were the umlauts, the sz
ligature, and the German paragraph sign), so C programs without
trigraphs would look pretty odd on those computers.
BTW, the UK also had their own derivative of ASCII, replacing the hash
sign with a pound sterling sign, but AFAIR the other characters were
left unharmed.
Why does a German acronym begin with the letter 'G'?
Le 17/08/2012 23:19, clipka nous fit lire :
> Yes.
Your wish are my command.
Am 18.08.2012 03:05, schrieb Cousin Ricky:
Because in this case it's a variation of an English acronym?
Le 17/08/2012 23:17, clipka nous fit lire :
The issue with trigraph is that young coders do not know they might
indeed use them without knowing. Same would go for digraph, but the
pattern is less obvious for them.
Trigraph in C are started by a doube ?. So chess comments are dangerous
in C. ( ?? (blunder, in chess) ).
http://en.wikipedia.org/wiki/Digraphs_and_trigraphs
Here, trigraph happens with ??)
Trigraphs were there for computers using EBCDIC, 6-bit bytes, and so on.
> Those typically replaced a
> common set of 8 characters - curly braces, square brackets, pipe symbol,
> backslash, tilde and hash - with language-specific characters (in the German
> "GSCII", for instance, those were the umlauts, the sz ligature, and the
> German paragraph sign), so C programs without trigraphs would look pretty
Well, that too. But I think it was more for being able to code C on punched
cards than it was replacing umlauts with equally-unreadable trigraphs.
> BTW, the UK also had their own derivative of ASCII, replacing the hash sign
> with a pound sterling sign, but AFAIR the other characters were left unharmed.
That's why Americans sometimes call # the "pound sign".
"They're the 1-800-#-GORILA of the telecom business."
