POV-Ray : Newsgroups : povray.beta-test : Scale limit? Server Time
28 Sep 2024 18:08:49 EDT (-0400)
  Scale limit? (Message 1 to 8 of 8)
Subject: Scale limit?
Date: 25 Jun 2012 04:08:50
Message: <4fe81c92$1@news.povray.org>
Using the following code for a (sky) sphere in a scene, with light
source well outside the sphere:
#declare T_sky =
     gradient y
     pigment_map {
       [0.0 srgb <1.0,0.7,0.6>*1 transmit 0.5]
       [1.0 srgb <0.8,0.1,0.0>*1 transmit 0.5]
   finish {
     emission 0.9
     diffuse 0.0
#declare T_cosmos =
     color rgbt <0,0,0,1>
   finish {
     ambient 0.0
     diffuse 0.0
sphere {
   <0,0,0>,1
   texture {T_sky}
   interior_texture {T_cosmos}
   no_shadow
   no_reflection
   inverse
   scale 99.9*10e4
works correctly until the above scale value. Use a value of >=100*10e4
and the sphere becomes black.
Is this normal for version 3.7 RC5? I seem to remember that with lower
versions of POV-Ray on could go at least to 10e6. Especially with the
Ringworld scenes back in 2010 the scales used where much larger without
any black out.
Working with windows version of POV-Ray and Win7 x64
Subject: Re: Scale limit?
Date: 25 Jun 2012 04:23:22
Message: <4fe81ffa$1@news.povray.org>
> any black out.
I can indeed confirm that the Ringworld scene does not render correctly
anymore, with identical black out.
Date: 25 Jun 2012 04:40:26
Message: <4fe823fa$1@news.povray.org>
Le 25/06/2012 10:08, Thomas de Groot nous fit lire :
> any black out.
> Thomas
Confirmed with RC6 (adding #version & assumed_gamma).
Might be related somewhere with flyspray entry #226, or not.
(it seems not)
With 100*10e4 :
Ray->Shape Intersection          Tests       Succeeded  Percentage
Sphere                          480000          480000    100.00
With 99.9*10e4:
Sphere                          960000          635272     66.17
Transmitted Rays:            480000
Playing with configbackend.h (source/backend/) MAX_DISTANCE &
SMALL_TOLERANCE restores the previous situation.
(MAX_DISTANCE in RC6 is 1.0e+7 instead of 1.0e+10, SMALL_TOLERANCE in
RC6 is 0.001 instead of 1.0e-6 )
Date: 25 Jun 2012 07:03:35
Message: <4fe84587$1@news.povray.org>
On 25-6-2012 10:40, Le_Forgeron wrote:
> Confirmed with RC6 (adding #version&  assumed_gamma).
> (it seems not)
needing a bug report? (don't remember how that was done... :-( )
Date: 25 Jun 2012 07:53:35
Message: <4fe8513f$1@news.povray.org>
Le 25/06/2012 13:03, Thomas de Groot nous fit lire :
>> (it seems not)
> Thomas
Done for you (task#246).
Usual process is to connect to http://bugs.povray.org/
Date: 25 Jun 2012 10:01:15
Message: <4fe86f2b$1@news.povray.org>
Ah thanks. I lost the site reference. Shall save it now.
Date: 12 Sep 2012 17:47:04
Message: <505102d8@news.povray.org>
Le 25/06/2012 10:23, Thomas de Groot nous fit lire :
>> any black out.
> Thomas
Reviving this thread...
Could you (Thomas ?) provide the version for which Ringworld does or did
render correctly ?
Archeology seems to indicate that Max_Distance (or MAX_DISTANCE) get
raised only between February and May 2005. (at the same time,
SMALL_TOLERANCE get finer too). These had generated some visibles issues
with lathes and spheresweep(es ???).
Date: 13 Sep 2012 03:59:01
Message: <50519245@news.povray.org>
> render correctly ?
I posted a Ringworld macro in p.t.scene-files.
