POV-Ray : Newsgroups : povray.beta-test : SSLT translucency values Server Time
10 Nov 2026 18:07:03 EST (-0500)
  SSLT translucency values (Message 1 to 6 of 6)
Subject: SSLT translucency values
Date: 17 Jun 2012 07:19:32
Message: <4fddbd44$1@news.povray.org>
Hello,
I am working with the SSLT features in RC5 (Windows 64bit) and so far
they seem to give nice results and I am adding it to PoseRay as a
material property.
According to the POV-Ray documentation, there is additional information
about the translucency for several materials listed in
http://graphics.stanford.edu/papers/bssrdf/bssrdf.pdf.
I suppose the documentation refers to Figure 5 in the SIGGRAPH
publication. Which of the values (or combination of them) are we
supposed to use? I was given by clipka a skin value of <2.0,1.5,0.8>
which, according to him, should be between the skin1 and skin2 values in
Figure 5 but does not seem to match the data.
Thanks for any info on this.
regards,
FlyerX
Subject: Re: SSLT translucency values
Date: 17 Jun 2012 09:53:27
Message: <4fdde157$1@news.povray.org>
Am 17.06.2012 13:19, schrieb FlyerX:
> Hello,
> material property.
The SSLT parameterization has been changed since its introduction, to
allow for more intuitive tweaking, and also for easier use of patterned
pigments.
The early implementation was parameterized by the "reduced scattering
coefficient" (sigma-prime[s]) and the "absorption coefficient"
(sigma[alpha]); as these two parameters completely define a material's
apparent color, the materials regular pigment was ignored; finding
suitable parameters for materials not listed in the paper was
cumbersome, as the relation between the coefficients and the resulting
color is far from intuitive. Furthermore, using image maps to e.g. add
some variation to a skin texture would have been impossible with this
approach.
The current implementation takes two different parameters, from which it
then computes the aforementioned coefficients internally. These
parameters are the material's "diffuse reflectance" (R[d]) - i.e. the
resulting apparent color of the material, which is conveniently
specified via the classic pigment statement (modulated by the diffuse
parameter) - and the "mean free path" (the inverse of sigma[tr]) - which
is what you specify via the "translucency" parameter.
This parameterization has been suggested by Jensen & Buhler in a
follow-up paper, "A Rapid Hierarchical Rendering Technique for
Translucent Materials", but they didn't compute the corresponding values
for the materials listed in the earlier paper.
Of course, from the equations in the two papers a formula can be thrown
together to compute the translucency parameter from the measured values,
but so far I haven't found the time and patience.
Date: 17 Jun 2012 19:43:11
Message: <4fde6b8f$1@news.povray.org>
>> Hello,
>> material property.
> pigments.
> approach.
Thanks for the clarification. In that case I went ahead and calculated
the translucency or the inverse of the Effective extinction coefficient
and put the values below:
Apple		6.96	6.40	1.90
Chicken1	11.61	3.88	1.75
Chicken2	9.44	3.35	1.79
Cream		15.03	4.66	2.54
Ketchup		4.76	0.57	0.39
Marble		8.51	5.57	3.95
Potato		14.27	7.23	2.04
Skimmilk	18.42	10.44	3.50
Skin1		3.67	1.37	0.68
Skin2		4.82	1.69	1.09
Wholemilk	10.90	6.58	2.51
The skin values do not match what you gave me but I may have made a
calculation error. The relative magnitude of the values seems to make
sense. Larger ones for skim milk and low ones for skin and apple. I
calculated the values as follows:
sigma_t(prime)=sigma_s(prime)+sigma_a,  (both are given in Figure 5)
sigma_tr=sqrt[3 * sigma_a * sigma_t(prime) ]
translucency = mean free path = 1/sigma_tr
the math was done on each RGB component separately.
later,
FlyerX
Date: 17 Jun 2012 21:09:30
Message: <4fde7fca$1@news.povray.org>
Am 18.06.2012 01:43, schrieb FlyerX:
> calculation error.
Same goes for my results - I guess I may have gotten the R component wrong.
Thanks for your contribution. I'll give them a sanity check, and if they
pass I suggest we include them in the POV-Ray documentation.
Date: 19 Jun 2012 14:13:01
Message: <4fe0c12d$1@news.povray.org>
>>>> values in
>> calculation error.
It could be possible to make an include file for several typical
translucency, and make it part of the official distribution.
Date: 19 Jun 2012 16:06:55
Message: <4fe0dbdf$1@news.povray.org>
I like this idea better ... if someone want's to put something together
that we /ALL/ can agree upon I'll get it into the distribution.
Jim
