POV-Ray : Newsgroups : povray.beta-test : Photons not working as expected? Server Time
10 Nov 2026 18:07:03 EST (-0500)
  Photons not working as expected? (Message 1 to 19 of 19)
Subject: Photons not working as expected?
Date: 20 Mar 2012 10:03:41
Message: <4f688e3d$1@news.povray.org>
Not getting the expected results from using photons, for example
"scenes\advanced\optics.pov" and a couple of my own.
Has something changed?
Subject: Re: Photons not working as expected?
Date: 20 Mar 2012 13:43:22
Message: <4f68c1ba$1@news.povray.org>
On 03/20/2012 10:03 AM, David wrote:
> Hi,
as compared to what version ... if you were using v3.6 there are a
number of changes that might be the reason. A little more info would be
helpful ;-)
Date: 21 Mar 2012 08:00:38
Message: <4f69c2e6$1@news.povray.org>
"James Holsenback" <nom### [at] nonecom> wrote in message
news:4f68c1ba$1@news.povray.org...
>> Hi,
> as compared to what version ... if you were using v3.6 there are a number
> of changes that might be the reason. A little more info would be helpful
POV Ray 3.7 RC5, Windows 7 64bit
Some of the the light beams in optics.pov are missing. Tested on Windows 7
64 and Ubuntu 11.10 64 and 32 bit versions.
Date: 21 Mar 2012 10:40:19
Message: <4f69e853$1@news.povray.org>
>>> Hi,
>> be helpful ;-)
> 7 64 and Ubuntu 11.10 64 and 32 bit versions.
I did a little trouble-shooting ... swapped (mirror and lenses) textures
around and indeed there seems to be somethings that's not correct. I
don't think it's the objects or textures, so I started playing the
photon global settings and saw slightly different results. Admittedly
I'm weak when it comes to photons, but /think/ that's where the problem
is ... maybe someone a bit stronger on this topic could lend a hand.
Jim
Date: 21 Mar 2012 10:53:41
Message: <4f69eb75$1@news.povray.org>
I looked at it too. It works with RC3 but not with RC4 & 5. Even with
version 3.6
Over to Clipa
Regards
Date: 21 Mar 2012 11:23:54
Message: <4f69f28a$1@news.povray.org>
> version 3.6
> Over to Clipa
Thanks Stephen ... that narrows it down a bit. I looked in revision
control and didn't see anything photon related, so perhaps that
eliminates the obvious. At the very least I think we've proven that
something is fishy. I'm going to submit a bug report.
Date: 21 Mar 2012 11:47:03
Message: <4f69f7f7$1@news.povray.org>
As an aside Jim, I tried to look up "SSLT" in the index of the help
documents. Nothing was found, I had to look up "subsurface". Maybe an
additional entry in the index would be useful.
Regards
Date: 21 Mar 2012 12:00:21
Message: <4f69fb15$1@news.povray.org>
Am 21.03.2012 15:53, schrieb Stephen:
> Over to Clipa
Who's that? :-P
Date: 21 Mar 2012 12:04:10
Message: <4f69fbfa$1@news.povray.org>
yep ... good idea
Date: 21 Mar 2012 12:41:05
Message: <4f6a04a1$1@news.povray.org>
>> Over to Clipa
> Who's that? :-P
Who ever he wants to be. (Sorry kkkkkk)
It kooks to ke kat khoton reflektions are not showing uk. ;-)
Regards
Date: 21 Mar 2012 12:59:27
Message: <4f6a08ef$1@news.povray.org>
Am 21.03.2012 16:23, schrieb James Holsenback:
Guess what - while implementing the new fancy iridescence, someone
(cough) accidently treaded on photons-relevant code and broke it.
Found, fixed & filed.
Date: 21 Mar 2012 13:49:42
Message: <4f6a14b6@news.povray.org>
That was quick. :-D
Regards
Date: 21 Mar 2012 16:34:45
Message: <4f6a3b65$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> wrote in message
news:4f6a08ef$1@news.povray.org...
> Guess what - while implementing the new fancy iridescence, someone (cough)
Glad to see it's all sorted out, thanks all for checking it out!
Date: 21 Mar 2012 16:35:38
Message: <4f6a3b9a$1@news.povray.org>
yep ... pulled change and we be good to go now.
Date: 22 Mar 2012 04:58:26
Message: <4f6ae9b2$1@news.povray.org>
KOK!  :-)
Khomkas
Date: 22 Mar 2012 05:22:56
Message: <4f6aef70@news.povray.org>
> KOK! :-)
> Khomkas
LOL I misread that as kook. But then you might not be wrong. ;-)
Regards
Date: 22 Mar 2012 08:13:16
Message: <4f6b175c@news.povray.org>
>> KOK! :-)
>> Khomkas
K's are tricky ;-)
Date: 28 May 2012 17:00:01
Message: <web.4fc3e6ae35177162cbd609230@news.povray.org>
Yes, I agree, something seems to be wrong with photons reflections in Beta
3.7RC5.
For example, the next scene renders fine in 3.7RC3 but wrong in 3.7RC5 (missing
reflection in the left wall). I didn't try 3.7RC4
wall.pov --------------------------------------------
 global_settings
                assumed_gamma 1.0
 photons {
                count 100000
                autostop 0
                media 10
                adc_bailout 0
                max_trace_level 15
 camera { location <14.9, 1, -8> look_at -z angle 70 }
 light_source { <10,100,150>, 1
//     media_attenuation on
 photons {   refraction on   reflection on  }
 // Room
 union
 { difference
   { box { <-11, -7, -11>, <16, 7, 10.5> }
     box { <-10, -6, -10>, <15, 6, 10> }
     box { <-4, -2, 9.9>, <2, 3, 10.6> }
   box { <-1.25, -2, 10>, <-0.75, 3, 10.5> }
   box { <-4, 0.25, 10>, <2, 0.75, 10.5> }
   pigment { rgb 1 }
 // Scattering media box:
 box
 { <-5, -6.5, -10.5>, <3, 6.5, 10.25>
   pigment { rgbt 1 } hollow
   interior
   { media
     scattering { 1, 0.07 extinction 0.01 }
       samples 30,100
          photons { pass_through }
  box
 { <-10, -5.99, -10>, <15, -6, 10>
   pigment { rgb 1 }
   finish { reflection <0.5, 0.4, 0.2> }
   photons { target reflection on }
Date: 28 May 2012 18:15:35
Message: <4fc3f907$1@news.povray.org>
Am 28.05.2012 22:57, schrieb David Bluecame:
> 3.7RC5.
The problem has been analyzed by now, and a fix will be included in the
next RC.
