POV-Ray : Newsgroups : povray.beta-test : RC4 SSLT question Server Time
4 Nov 2026 07:38:41 EST (-0500)
  RC4 SSLT question (Message 1 to 13 of 13)
Subject: RC4 SSLT question
Date: 27 Feb 2012 13:13:33
Message: <4f4bc7cd$1@news.povray.org>
With the changes to the SSLT code in RC4 there is now only one
controlling vector, translucency, instead of two, scattering and
absorption. What if any is the relationship between translucency,
scattering and absorption?
Scattering and absorption made sense to me and the reference pdf gave
values for some materials. So how do we go about using translucency?
Regards
Subject: Re: RC4 SSLT question
Date: 27 Feb 2012 19:26:16
Message: <4f4c1f28@news.povray.org>
I find the new method much more simpler ... I started with the scene
file that was added ~scenes/subsurface/subsurface.pov and played around
with it changing things and observing the affect. It's a simple scene
and renders fairly quickly. I then graduated to a little bit more
complicated object then started playing with that ... move the light,
and/or change the camera view. Hint cylinders make a better test object
(the edges) than say rounded (sphere). Don't forget to play with the
scaling (mm_per_unit: smaller value makes it more transparent at the
edges, larger lessens the affect) ... keep it simple at first until you
get the hang of it, then graduate to more complicated shapes.
BTW: RC5 is on deck because of the bug report you lodged. clipka's fix
also fixed a couple of other issues I found during testing, so it won't
be prone to crashes due to improper usage ... a bit more robust. Don't
get discouraged, it's a cool feature and well worth the seemingly
tedious learning curve ... lastly the use of color vectors with a zero
component is still problematic ... zero diffuse as well IIRC
Date: 27 Feb 2012 19:32:52
Message: <4f4c20b4$1@news.povray.org>
OH yeah ... forgot to mention the to don't forget the interior {ior
whatever} part ... bundle that with the rest of the texture definition
as a material
Date: 28 Feb 2012 06:10:14
Message: <4f4cb616$1@news.povray.org>
Simplicity is not always best. Think about how many people complain
about M$ windows and iTunes.
A good suggestion. It looks like I will need to run a series of
experiments instead of just being able to convert my existing scenes.
Bah! Kiddy stuff. :-P
It is generally with meshes that I have been using it with.
That is fine, Chris sent me an evaluation copy to test. :-)
> clipka's fix
That is good.
> Don't
That is understandable. A totally black surface will not have any
subsurface scattering. Although a little error trapping doesn’t seem too
hard to imagine but what do I know? ?_?
> as a material
It is easy to notice if you have forgotten it. The render is too fast. :-)
What I really wanted is an understanding of what the translucency values
mean in RL.
To my way of thinking a value of <1, 1, 1> would mean that the material
is completely translucent and all the colour components are allowed to
penetrate unhindered. Why can we use a value > 1?
Yes some experimenting is needed.
Regards
Date: 28 Feb 2012 06:23:30
Message: <4f4cb932$1@news.povray.org>
simpler shapes ... walk before ya run ;-)
>> Don't
not just rgb 0 ,.... rgb <1,0,0> should be rgb <1,0.01,0.01> .... etc
Date: 28 Feb 2012 06:37:30
Message: <4f4cbc7a$1@news.povray.org>
I know, I know. But... ;-)
>>> Don't
I just… Oh never mind. ;-)
I have just made a cylinder mesh and am about to start experimenting.
I’ll use a Pov cylinder too for comparison. Dinna fash yersel :-P
Regards
Date: 28 Feb 2012 11:44:22
Message: <4f4d0466@news.povray.org>
Am 27.02.2012 19:13, schrieb Stephen:
There were various major drawbacks with the parameterization based on
scattering and absorption.
First, while they allowed to plug in physical properties of a material
directly, sources for such data is scarce (that one pdf is the only
source I'm currently aware of), and tweaking those properties to mimic
any other desired material - even just a similar material with different
color, or a material with same color but stronger or weaker SSLT effect
- is non-trivial to say the least.
Second, those two parameters fully determined the material's color,
leaving the classic pigment parameter with no effect; this resulted in
more maintenance effort if you wanted test renders without SSLT to use
similar colors.
And last not least, with those parameters it was a major challenge - if
not impossible - to make use of classic image textures (like, say, Poser
skin textures) together with SSLT.
The new parameterization makes it straightforward to achieve a
particular effective color by simply specifying that color as a pigment;
this leaves you with only one RGB parameter to toy around if you want to
mimic a particular material, automatically keeps SSLT and non-SSLT color
of a material in sync, and enables you to change the material color - or
apply standard image textures - in a pinch.
The new parameterization also imposes no added limitations: Any material
you could model with the old parameterization can also be modeled with
the new one.
The translucency parameter specifies the so-called "mean free distance"
of a light ray in the material (in mm), i.e. the average distance a
light ray travels before it is either absorbed or scattered. This can be
more than 1.0 mm in case of very "waxy" materials, and could
theoretically be as large as infinity (for a perfectly transparent
material).
I've only recently heard of Poser figures coming with translucency maps,
which obviously need to specify values in the range 0..1; it would be
interesting to know what parameterization is used there, so we could
adapt POV-Ray to easily make use of them as well; the SSLT syntax is
therefore still in flow.
Date: 28 Feb 2012 12:40:57
Message: <4f4d11a9$1@news.povray.org>
> material).
Thanks Christoph I understand it better now that I know what the values
related to. I can get a mental image of what is happening.
I don’t suppose that you have any figures for different materials? Or is
that too much to ask for?
I've not heard of that. Interesting!
Regards
Date: 28 Feb 2012 14:28:23
Message: <4f4d2ad7@news.povray.org>
> distance" of a light ray in the material (in mm), i.e. the average
> distance a light ray travels before it is either absorbed or
> scattered. This can be more than 1.0 mm in case of very "waxy"
> materials, and could theoretically be as large as infinity (for a
> perfectly transparent material).
It probably depends on photon wavelength as well, although I'm not
sure that effect is strong enough to impact the visual perception of
an object with translucency.
Date: 28 Feb 2012 17:07:43
Message: <4f4d502f@news.povray.org>
Am 28.02.2012 20:28, schrieb Christian Froeschlin:
The wavelength-dependency of the mean free distance is indeed quite
significant in some materials; that's why translucency is an RGB parameter.
Date: 29 Feb 2012 03:00:02
Message: <4f4ddb02$1@news.povray.org>
For what it's worth :-)  I mentioned that in my latest post in p.t.poser.
Date: 29 Feb 2012 11:12:33
Message: <4f4e4e71$1@news.povray.org>
> Thomas
When you were talking about hair?
I thought that clipa was talking about the body meshes.
Regards
Date: 1 Mar 2012 03:29:13
Message: <4f4f3359$1@news.povray.org>
My latest is about body meshes ;-)
See message: "Use and significance of the different body maps in Poser 8+"
