POV-Ray : Newsgroups : povray.beta-test : Picture index out of range. - Fatal error in renderer: Uncategorized error. Server Time
10 Nov 2026 18:07:03 EST (-0500)
  Picture index out of range. - Fatal error in renderer: Uncategorized error. (Message 1 to 14 of 14)
Subject: Picture index out of range. - Fatal error in renderer: Uncategorized error.
Date: 14 Jan 2012 09:06:04
Message: <4f118bcc$1@news.povray.org>
The following code fails with the following message:
Render failed
The texture scale is relevant.
It does not fail in Pov 3.62
The image map can be downloaded from:
http://www.mmedia.is/~bjj/data/s_rings/sat_ring_color.png
#version 3.7;
global_settings {
  adc_bailout       0.0039
  ambient_light     rgb <1.000,1.000,1.000>
  assumed_gamma     1.00
  irid_wavelength   rgb <0.250,0.180,0.140>
  max_trace_level   5
  number_of_waves   10
  noise_generator   3
  charset           ascii
background { colour rgb <0.000,0.000,0.000> }
#declare Ring_Texture1 =
  uv_mapping
   image_map{
    png "sat_ring_color.png"
    interpolate 2
    map_type 0
   rotate    <90.000,90.000,0.000>
  finish {
   ambient     rgb <0.100,0.100,0.100>
   brilliance  1.000
   crand       0.000
   diffuse     0.600
   metallic    0.000
   phong       0.000
   phong_size  40.000
   specular    0.000
   roughness   0.050
#declare Camera0 =
  perspective
  location <3843.816,38.892,-2660.667>
  up y
  right 1.333*x
  angle 33.000
  sky <-0.004,1.000,0.002>
  look_at < 0.449, 18.943, 0.102 >
}  // end Camera0
disc {  // Disc0
  0,y,4.400000,2.500000
  texture{ Ring_Texture1 }
     scale     <750.000000,750.000000,750.000000>      // Fails 32 bit
//  scale     <800.000000,800.000000,800.000000>      // Fails 64 bit
  // scale     <600.000000,600.000000,600.000000>     // does not fail
  rotate    <0.000000,0.000000,-20.000000>
  translate <-3500.000000,900.000000,900.000000>
}  // end Disc0
camera{ Camera0 }
Regards
Subject: Re: Picture index out of range. - Fatal error in renderer: Uncategorizederror.
Date: 14 Jan 2012 10:02:55
Message: <4f11991f$1@news.povray.org>
> Render failed
Don't know why it passes 3.6 but not 3.7 ... I can verify that it DOES
indeed happen with 3.7. Here's what else I've discovered ... on a lark
since disc primitive doesn't support uv_mapping I commented it out in
texture definition and OK fine. Added uv_mapping statement back in and
changed disc to sphere and it worked ... so it appears to be related to
uv_mapping and disc????
Date: 14 Jan 2012 14:14:38
Message: <4f11d41e$1@news.povray.org>
> Render failed
I can confirm too, it happens with 3.7 binary (win7-64), even when
version is set to 3.6, but not with 3.6.
A tiny shift in the rotation
rotate    <90.000,90.000,0.000> + <0, 1e-14, 0>
fixes this. Perhaps it's something to do with tangents somehow?
Date: 15 Jan 2012 03:38:32
Message: <4f129088@news.povray.org>
Oops! I did not check that.
I get an image if I change the map_type to 1, 2 or 5. At least with
these settings. Incidentally, Bishop3D has a map_type 8 which Hugo
called Parametric. I can see no mention of it in the docs.
Regards
Date: 15 Jan 2012 04:02:59
Message: <4f129643$1@news.povray.org>
> Render failed
Please report this at bugs.povray.org. The mapping falls out of range
internally, which should not happen (or be handled better). It seems like a
coincidence that it occurs only in 3.7 though.
     Thorsten, POV-Team
Date: 15 Jan 2012 09:19:33
Message: <4f12e075$1@news.povray.org>
the parametric object is mentioned in the uv_mapping section of the docs:
http://wiki.povray.org/content/Documentation:Reference_Section_5.2#Supported_Objects
however in the map_type section is does not:
http://wiki.povray.org/content/Documentation:Reference_Section_5.6#The_map_type_Option
I tried map_type 8 and it parsed ok fine ... but get this I also tried
map_type 10 then map_type 100 and those BOTH parsed as well!!!
A separate bug from what you've uncovered???
Also if someone else on the team could provide a clue as to what the
map_type 8 narrative should say, I'll make that change.
On a separate note ... Christoph posted a fix for parametric uv_mapping
back in June of last year, that will roll with RC4
http://bugs.povray.org/task/210?project=2&order=id&sort=desc
Date: 15 Jan 2012 10:00:02
Message: <4f12e9f2@news.povray.org>
added bug report for this:
http://bugs.povray.org/task/232?project=2&order=id&sort=desc
@Stephen: I'll leave the other bug report for you to follow up
Date: 15 Jan 2012 10:41:25
Message: <4f12f3a5@news.povray.org>
>> Render failed
> like a coincidence that it occurs only in 3.7 though.
> Thorsten, POV-Team
Thanks and done:
FS#233 - Picture index out of range. - Fatal error in renderer:
There seems to be a formatting error, comment "//" has been removed and
there are two scales in the texture not commented out.
Regards
Date: 15 Jan 2012 10:49:09
Message: <4f12f575@news.povray.org>
Done after a struggle :-)
Regards
Date: 15 Jan 2012 16:20:12
Message: <4f13430c@news.povray.org>
Am 15.01.2012 20:13, schrieb bart:
>> Render failed
The root cause has been identified by now; it only shows when a ray
happens to hit the image map extremely close to the image border (about
a trillionth (1e-12) of a pixel off in this case), and is due to
precision issues apparently not considered by the original code author.
Date: 16 Jan 2012 05:52:01
Message: <4f140151@news.povray.org>
I guess it's yet another case of computer ending with mathematically
impossible result, like computing the dot product of two unit vectors
and being aware that the result might indeed be bigger than 1, before
trying to compute the arccos of the result to get the value of the
angle. It should not happen... and yet it does in a very few cases.
Good detective work then, dear Clipka!
Date: 22 Jun 2012 08:35:58
Message: <4fe466ae$1@news.povray.org>
After installing RC6 I am still getting the same error.
Below is a link to the scene rendered with one thread. You can see that
the render fails before the block reaches the image border. For
comparison I have included a link to the scene rendered with eight threads.
1 thread
http://imgur.com/8BG0X
8 threads
http://imgur.com/HTldu
Code:
#version 3.7;
global_settings {
  adc_bailout       0.0039
  assumed_gamma     1.00
  max_trace_level   5
  number_of_waves   10
  noise_generator   3
  charset           ascii
  uv_mapping
   image_map{
    interpolate 2
    map_type 0
  finish {
   ambient     rgb <0.100,0.100,0.100> *5
   brilliance  1.000
   crand       0.000
   diffuse     0.600
   metallic    0.000
   phong       0.000
   phong_size  40.000
   specular    0.000
   roughness   0.050
#declare Camera0 =
  perspective
  up y
  right 1.333*x
  angle 33.000
}  // end Camera0
disc {  // Disc0
}  // end Disc0
camera{ Camera0 }
Regards
Date: 22 Jun 2012 11:01:57
Message: <4fe488e5$1@news.povray.org>
Am 22.06.2012 14:35, schrieb Stephen:
Yes; this issue accidently "fell off the bench" and didn't get picked up
again until just after RC6 had been built. Sorry for that, my bad.
Date: 22 Jun 2012 14:54:17
Message: <4fe4bf59$1@news.povray.org>
No worries on my part. I made up a colour map that looks better imo.
Regards
