POV-Ray : Newsgroups : povray.beta-test : max_intersections Server Time
10 Nov 2026 18:31:04 EST (-0500)
  max_intersections (Message 1 to 5 of 5)
Subject: max_intersections
Date: 28 Aug 2010 12:33:34
Message: <4c793a5e@news.povray.org>
When I tried to increase max_intersections in 3.7 I got a parse error.
"Nonic03_Fail04X_.pov" line 10: Parse Error: No matching } in
'global_settings', float function 'float constant' found instead
global_settings {
     adc_bailout       0.001
     ambient_light     rgb <1.000,1.000,1.000>
     assumed_gamma     2.200
     irid_wavelength   rgb <0.250,0.180,0.140>
     max_intersections 64
     max_trace_level   150
     number_of_waves   10
     noise_generator   3
     charset           ascii
Am I missing something?
Best Regards,
Subject: Re: max_intersections
Date: 28 Aug 2010 12:47:02
Message: <4c793d86$1@news.povray.org>
Am 28.08.2010 18:33, schrieb Stephen:
> global_settings {
> adc_bailout 0.001
> assumed_gamma 2.200
> max_trace_level 150
> number_of_waves 10
> noise_generator 3
> charset ascii
It's a bug, not a feature :-/
According to the POV-Ray source code, "max_intersections FLOAT" is
apparently supposed to do nothing in POV-Ray 3.7, but the parser fails
to eat the FLOAT parameter.
You can work around this by commenting-out the offending line (or
placing a "#if (version < 3.7)...#end" around it). Actually, you should
also have received a parser warning, "'max_intersections' is no longer
needed and has no effect in POV-Ray 3.7 or later."
Date: 28 Aug 2010 13:19:42
Message: <4c79452e$1@news.povray.org>
I love them. ;-)
Oh! did I miss out that it had a #version 3.6; before the Global
Settings block?
Then it is feature that I did not get the warning with #version 3.6; but
do with #version 3.7; :-P
BTW I am going to submit another bug report because I’m getting an “An
access violation exception was generated at address 0x0046fbd0” with a
scene that has a few reflections and refractions. It has been confirmed
by StephenS.
What sort of dump do you want with the scene file?
Best Regards,
Date: 28 Aug 2010 13:33:00
Message: <4c79484c$1@news.povray.org>
Am 28.08.2010 19:19, schrieb Stephen:
Yes, that's intentional indeed :-)
> by StephenS.
Dunno, I think Chris knows how to analyze Windows "core dumps". I
personally prefer to re-create the error and single-step around the code.
Date: 28 Aug 2010 14:07:29
Message: <4c795061$1@news.povray.org>
Aye right! :-D
>> by StephenS.
Well I'll Start a new thread and upload the scene file in
povray.beta-test.binaries as it needs an imagemap for it to fail.
Best Regards,
