POV-Ray : Newsgroups : povray.beta-test : Checking for existing bugreports Server Time
10 Nov 2026 18:31:04 EST (-0500)
  Checking for existing bugreports (Message 1 to 11 of 11)
Subject: Checking for existing bugreports
Date: 24 Jul 2010 07:59:15
Message: <4c4ad593@news.povray.org>
I have a scene that occasionally fails to render in 3.7 Beta 38 with the
error: “Parse Error: Cannot open input file” but renders OK in 3.6.2.
(It renders OK the second time I render it.)
I see that Roman had the same error message in Dec 2008 but that was for
64 bit and concerned radiosity. My problem concerns making lots of
copies of a “grass” patch with the 32 bit version.
Where can I check it has not been reported before and if it hasn’t where
can I report it and upload the file?
Best Regards,
Subject: Re: Checking for existing bugreports
Date: 24 Jul 2010 09:00:23
Message: <4c4ae3e7$1@news.povray.org>
Am 24.07.2010 13:59, schrieb Stephen:
http://bugs.povray.org should have everything you're asking for.
Date: 24 Jul 2010 10:15:12
Message: <4c4af570$1@news.povray.org>
Thanks Christoph,
I've uploaded a scene file (Parse Error: Cannot open input file) to
p.beta-test.b for testing and confirmation before filing a bug report.
Best Regards,
Date: 24 Jul 2010 10:35:00
Message: <web.4c4af9365f4219c369e6eda50@news.povray.org>
> Thanks Christoph,
> Best Regards,
>  Stephen
It ran for me, first time, and after, Pov3.7.38b 32bit
Stephen S
Date: 24 Jul 2010 11:01:04
Message: <4c4b0030@news.povray.org>
Am 24.07.2010 16:31, schrieb StephenS:
> Stephen S
Same here, beta.38 64bit version.
Actually I can't think of any reason why POV-Ray should abort parsing
that scene - which obviously has no other input files except the main
scene file - with that error message. Except maybe POV-Ray's attempt to
parse the file clashes with an attempt of the editor to save the file.
Do you happen to have auto-save enabled?
Date: 24 Jul 2010 11:16:58
Message: <4c4b03ea@news.povray.org>
Am 24.07.2010 17:01, schrieb clipka:
Well, now I've seen the message, too - after having set the #while loop
count to 1000 (instead of 100 as you suggested).
Tried it again multiple times, only to get various different error
messages. The second one I got seems most credible to me: "Out of memory".
Which indicates that we have some memory allocation attempts in POV-Ray
that aren't properly checked for success.
Date: 24 Jul 2010 11:33:04
Message: <4c4b07b0@news.povray.org>
When I switched off auto save and increased the count to 200 I got an
unknown internal error. PovRay did nor release all ram and when I closed
PovRay I got a runtime error.
Microsoft Visual C++ Runtime Error
"This application caused the Runtime to close in an unusual way."
Please contact the apps support team...
Best Regards,
Date: 24 Jul 2010 11:34:10
Message: <4c4b07f2$1@news.povray.org>
>> Thanks Christoph,
>> Best Regards,
>>   Stephen
Did you change the count?
Best Regards,
Date: 25 Jul 2010 09:00:00
Message: <web.4c4c35395f4219c317eb69780@news.povray.org>
> Best Regards,
>  Stephen
Yes ;-)
On one computer 300 will run out of memory, pov 32bit.
On another computer 700 still works, pov 64bit. Interestingly if I try to close
down POV-Ray after this render, I can get the 'runtime error', but waiting
several minutes and POV-Ray closes without problem. Still releasing memory?
Stephen S
Date: 25 Jul 2010 11:04:20
Message: <4c4c5274$1@news.povray.org>
>> Best Regards,
>>   Stephen
> Yes ;-)
Maybe I should have said that I am running 32 bit Win7 on an Intel core2
Duo with 3 Gigs of Ram and lots of other programs running.
If Christoph wants me to create a bug report I will if not...
Best Regards,
Date: 26 Jul 2010 09:01:14
Message: <4c4d871a$1@news.povray.org>
On my machine it seems to use about 700 MB for every 100 iterations, I can
see the mem usage going up in task manager as it is parsing.  If I set it to
more than the amount of RAM, I get "Unknown internal error! Render failed"
in the message window followed by the standard Windows "program has crashed"
box.
