POV-Ray : Newsgroups : povray.beta-test : Scaled preview window looks horrible Server Time
10 Nov 2026 18:39:04 EST (-0500)
  Scaled preview window looks horrible (Message 1 to 16 of 16)
Subject: Scaled preview window looks horrible
Date: 19 May 2010 10:08:44
Message: <4bf3f0ec$1@news.povray.org>
If you render an image bigger than your screen size and set the preview
window to maximised, it uses some really ugly scaling algorithm to fit the
rendered image in the window.  Could something better be used?
Subject: Re: Scaled preview window looks horrible
Date: 19 May 2010 10:22:30
Message: <4bf3f426$1@news.povray.org>
> the rendered image in the window.  Could something better be used?
hmmmm ... could be totally off base here, but isn't that a function of
the window manager you're using and not povray?
Date: 19 May 2010 10:26:20
Message: <4bf3f50c$1@news.povray.org>
Am 19.05.2010 16:08, schrieb scott:
I don't see anything in there that would deserve the term "ugly", except
maybe the scaling of the grey/white checkered pattern indicating the
areas that haven't been rendered yet. That, and maybe the fact that it's
not using any form of interpolation. But I'd consider neither of those
seriously unfit for a preview window.
Though of course if you'd volunteer to improve it, I guess you'd be
happily invited ;-)
(Then again, maybe you're seeing something I failed to see in my simple
experiments I just did.)
Date: 19 May 2010 14:02:44
Message: <4bf427c4$1@news.povray.org>
Am 19.05.2010 16:24, schrieb Jim Holsenback:
I'd be surprised if that was the case even with X Window programs (where
the concept of a window manager does exist), let alone MS Windows (where
there is no such thing as a "window manager" except for the basic
functionality supplied by the OS and whatever GUI framework the app
happens to be using.
Notmally, I'd expect a window manager to add some scroll bars at best,
leaving it up to the application to adjust the window contents to a
changed window size.
Though POV-Ray presently does indeed use some Windows GDI API functions
to scale the image if necessary.
Date: 19 May 2010 15:21:12
Message: <4bf43a28$1@news.povray.org>
BTW, I just had a look at the Windows front-end code, to find that it
would be quite easy to change it to use a prettier scaling method - all
it would take would be to change a scaling-mode constant, and slightly
adjust some code called whenever an SMP square has been rendered.
However, that change would apparently break compatibility with Windows
95/98/Me; I don't think such a minor improvement would be worth that price.
Date: 19 May 2010 17:22:44
Message: <4bf456a4$1@news.povray.org>
clipka escreveu:
who the freak still uses those ancient interfaces?!
a game sig: http://tinyurl.com/d3rxz9
Date: 19 May 2010 18:01:29
Message: <4bf45fb9$1@news.povray.org>
Am 19.05.2010 23:22, schrieb nemesis:
> clipka escreveu:
>> all it would take would be to change a scaling-mode constant, and
>> slightly adjust some code called whenever an SMP square has been
>> rendered. However, that change would apparently break compatibility
>> with Windows 95/98/Me; I don't think such a minor improvement would be
>> worth that price.
How about people who have some spare computer they want to use to run
POV-Ray renders, and choose to install neither XP or newer (because the
computer might be too slow, or they might want to save money on a
license and re-use some old Win98 license for that purpose), nor Linux
(because they don't grok it well enough)?
I'm not saying breaking compatibility would be a horribly dear price to
pay /per se/, but I think /this/ particular issue is not worth paying it.
Date: 19 May 2010 19:36:11
Message: <4bf475eb$1@news.povray.org>
On 05/19/2010 07:01 PM, clipka wrote:
> <snip> nor Linux
ha-ha ... I'm thinking of those tv commercials that say "so easy even a
caveman can do it"
concur ... also I would think this issue would probably be pretty low on
the priority list to boot!
Date: 20 May 2010 03:01:48
Message: <4bf4de5c$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> schreef in bericht
news:4bf45fb9$1@news.povray.org...
> computer might be too slow, or they might want to save money on a license
> and re-use some old Win98 license for that purpose), nor Linux (because
Exactly. I still have an old PC with Me and an even older portable with 98.
Once in a while I use them.  :-)
And I don't grok Linux. ;-)
I agree.
Date: 20 May 2010 03:43:54
Message: <4bf4e83a@news.povray.org>
> maybe the scaling of the grey/white checkered pattern indicating the areas
> that haven't been rendered yet. That, and maybe the fact that it's not
> happily invited ;-)
I'll download the source again and take a look.
Take a loot at the attached (left maximised, right 100%).  I think this is
some kind of "worst case" because it uses diagonal lines and the scale
factor is probably around 99% to fit it full screen.
Download 'image3.png' (44 KB)
Preview of image 'image3.png'
Date: 20 May 2010 03:45:17
Message: <4bf4e88d@news.povray.org>
> would be quite easy to change it to use a prettier scaling method - all it
> would take would be to change a scaling-mode constant, and slightly adjust
That's what I thought.
> price.
Couldn't it be a variable rather than a constant, set by a simple check for
OS version?
Date: 20 May 2010 06:08:05
Message: <4bf50a05$1@news.povray.org>
Am 20.05.2010 09:45, schrieb scott:
>> price.
> for OS version?
Indeed. I'm not familiar with testing for Windows version though, so I'd
file that under "non-trivial change" - I guess there might be quite some
pitfalls to that, given the diversity of past, present and (probably)
future Windows versions (for instance, XP Pro x64 Edition is likely to
identify as Windows 2003 instead).
Another option would be to activate the nicer smoothing mode in 64-bit
versions only, as that's a safe bet for XP or newer.
Date: 20 May 2010 17:31:47
Message: <4bf5aa43@news.povray.org>
Thomas de Groot escreveu:
well, guess that already makes up for 10% of all povray users. :P
True, keep the old code in.
Date: 20 May 2010 17:33:05
Message: <4bf5aa91$1@news.povray.org>
scott escreveu:
>> except maybe the scaling of the grey/white checkered pattern
>> indicating the areas that haven't been rendered yet. That, and maybe
>> the fact that it's not using any form of interpolation. But I'd
>> consider neither of those seriously unfit for a preview window.
>> happily invited ;-)
>> simple experiments I just did.)
> is some kind of "worst case" because it uses diagonal lines and the
> scale factor is probably around 99% to fit it full screen.
BTW, Blender has this same issue, even though being OpenGL rather than
Windows-specific.  Don't know about 2.5.
Date: 21 May 2010 06:00:53
Message: <4bf659d5$1@news.povray.org>
It's actually rather straight-forward as the internal version
numbering is different from the marketing names. The GetVersionEx
API call will fill data into a OSVERSIONINFO struct you pass to
it. If dwMajorVersion >= 5 you're on Windows 2000 or higher.
If the improved scaling method is not yet available in 2000
then the test should be
   dwMajorVersion >= 6 || (dwMajorVersion == 5 && dwMinorVersion >= 1)
for XP or higher. See
   http://msdn.microsoft.com/en-us/library/ms724451(v=VS.85).aspx
for more information.
Date: 21 May 2010 15:43:52
Message: <4bf6e278$1@news.povray.org>
>> rendered.
Hey-oh! You gotta love Microsoft...
Now there is this STRETCH_HALFTONE mode they have for displaying scaled
bitmaps.
Seems like it does what you'd expect it to, when scaling bitmaps /down/
to fit large images into small windows.
Seems like it is /also/ capable of smoothing bitmaps when scaling them
/up/ to fit small images into large windows.
Well, yes, /capable/ it apparently is - but does it /do/ it?
Looks like Microsoft hid some mean little algorithm in there that gets
to decide which image will be smoothed and which will just be scaled
(seemingly depending on how many different colors you have in there)...
Oh bugger!
