POV-Ray : Newsgroups : povray.beta-test : Beta 37 changes to file gamma? Server Time
10 Nov 2026 18:39:06 EST (-0500)
  Beta 37 changes to file gamma? (Message 1 to 30 of 30)
Subject: Beta 37 changes to file gamma?
Date: 27 Apr 2010 17:39:20
Message: <4bd75988@news.povray.org>
Just trying out beta 37 of povray and all output files are over bright
compared with earlier versions.
I always add the following lines to the end of my povray.ini file.
; .png Image Type by default
Output_File_Type=N
; Picture brightness
Display_Gamma=1
File_Gamma=1
The display seems ok but the output file is lighter, even with the default
file type (BMP).
Anyone else having trouble or is it my setup thats gone wrong somewhere?
Cheers.
Subject: Re: Beta 37 changes to file gamma?
Date: 27 Apr 2010 17:56:57
Message: <4bd75da9$1@news.povray.org>
Am 27.04.2010 23:39, schrieb Quietman:
At present I can't rule out that I might have broken something with
change #4932.
I'll try to recreate your scenario to see what's happening. Are using
assumed_gamma? If so, what value it is set to?
BTW, regardless of whether this is a bug or not, be advised that
File_Gamma=1 is not a good idea if you intend to share generated image
files; and are you sure that your display subsystem does indeed have an
overall gamma of 1.0 as indicated by Display_Gamma?
Date: 28 Apr 2010 10:59:10
Message: <4bd84d3e$1@news.povray.org>
Am 27.04.2010 23:56, schrieb clipka:
> change #4932.
Darn - I did indeed break it quite thoroughly.
Date: 28 Apr 2010 12:01:01
Message: <4bd85bbd$1@news.povray.org>
> Output_File_Type=N
> Display_Gamma=1
> File_Gamma=1
As a workaround, try setting File_Gamma to something like 0.98 or 1.02.
(Any value smaller than 0.99 or greater than 1.01 should do.)
Date: 29 Apr 2010 04:21:13
Message: <4bd94179$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> schreef in bericht
news:4bd84d3e$1@news.povray.org...
>> change #4932.
OK. So this means that, if we do not want to work around this now, we should
better wait for the next beta (and stick with beta 36)?
Date: 29 Apr 2010 04:34:42
Message: <4bd944a2$1@news.povray.org>
Am 29.04.2010 10:21, schrieb Thomas de Groot:
> "clipka"<ano### [at] anonymousorg>  schreef in bericht
>>> change #4932.
I didn't break it as thoroughly as it seemed at first: The error only
kicks in when File_Gamma is set to 1.0 (or, more precisely, 0.99 to
1.01), which is normally not recommended anyway, so I fancy that the
average user will not be affected. Phew. <wipes sweat off forehead>
So please do upgrade to beta 37 and give it a go, as there are many
changes in there waiting for thorough testing.
Date: 29 Apr 2010 04:56:19
Message: <4bd949b3@news.povray.org>
news:4bd944a2$1@news.povray.org...
> kicks in when File_Gamma is set to 1.0 (or, more precisely, 0.99 to 1.01),
> which is normally not recommended anyway, so I fancy that the average user
OK. Anyway, the choice was taken out of hands as beta 36 crashes when going
automatically to the update site. I produced a mini-dump file, should I send
it somewhere? Have others the same experience?
Date: 29 Apr 2010 11:42:12
Message: <4bd9a8d4$1@news.povray.org>
>clipka" <ano### [at] anonymousorg> wrote in message
>news:4bd85bbd$1@news.povray.org...
>> Output_File_Type=N
>> Display_Gamma=1
>> File_Gamma=1
Setting them both to 1.02 fixed it.
Gamma settings have always been a source of trouble for my own renders with
povray. I can remember using version 3.5 and having to change gamma to
something lower. I stopped using assumed_gamma 1 in every file and changed
to the povray.ini settings when they were introduced.
I find using the defaults (2.2?) produces very bright washed out files. The
best fix I have found so far is to set both gamma settings to 1. It makes
the renders look natural in tone and colour for me.
I only do this for a hobby on a Samsung R700 laptop so sharing files with
anyone else isn't likely to happen. I assume it has a regular LCD screen (as
far as gamma goes).
Thanks for the help :)
Date: 29 Apr 2010 12:24:49
Message: <4bd9b2d1@news.povray.org>
  If you had been using true gamma 2.2 for all your povray images for your
entire life, you would find a gamma of 1.0 unbearably dark.
  The reason is that if you were accustomed to the proper gamma, you would
be using the adecuate colors for that gamma (eg. 0.5 for a *truly* mid-gray
color, etc).
  As for image map images which don't have gamma info in them, they have to
be pre-gamma corrected manually when using the correct gamma for your system.
POV-Ray 3.7 implements now a keyword to do that.
  Question: If someone "lies" to POV-Ray by claiming that his system uses
a gamma of 1.0 when in reality it uses a gamma of 2.2, and renders an image
with that setting, will that image look the same in a different system with
a different gamma (eg. one with a gamma of 1.8), or will it look different?
If so, how different (brighter, darker...)?
Date: 29 Apr 2010 15:30:22
Message: <4bd9de4e@news.povray.org>
Am 29.04.2010 17:42, schrieb Quietman:
I take a bold guess that this is probably because you're used to the way
older POV-Ray versions did it, and have developed an instinct how to
achieve the desired results for the old versions. Unfortunately that
instinct don't work with the /more realistic/ model used in 3.7.
You may also have been fooled by earlier betas which couldn't handle
input images properly (they did indeed get those input images too bright
and washed-out).
Well, I guess I'm trying to evangelize you here, but in the end it's
your choice of course.
Date: 29 Apr 2010 15:57:01
Message: <4bd9e48d$1@news.povray.org>
Am 29.04.2010 18:24, schrieb Warp:
Actually you can typically go without explicitly using that mechanism,
as POV-Ray will still make a sophisticated guess and perform an implicit
gamma-adjustment which should be fine for most cases.
It doesn't matter what POV-Ray settings were used to create the image
file: An image file created with a "lie" will suffer exactly the same
effects when transmitted to another system as an image file created
without a "lie".
When moving an image file from a gamma 2.2 system to a gamma 1.8 system,
the file may or may not look a tad brighter and more washed-out,
depending on whether the file format carries gamma information, and/or
whether the "target" system makes a correct guess that the image was
created to look good on a gamma 2.2 system.
Date: 29 Apr 2010 17:23:56
Message: <4bd9f8ec$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> wrote in message
news:4bd9de4e@news.povray.org...
>> The
> You may also have been fooled by earlier betas which couldn't handle input
> images properly (they did indeed get those input images too bright and
> washed-out).
> Well, I guess I'm trying to evangelize you here, but in the end it's your
> choice of course.
If I use the default settings of 2.2 how do I make my renders look less
washed out? I don't use anything fancy or complicated, usually one light
coloured white... I really don't know what to do about this.
Date: 29 Apr 2010 17:54:19
Message: <4bda000b$1@news.povray.org>
Am 29.04.2010 23:23, schrieb Quietman:
There are several reasons why your scenes may look washed-out:
- Your pigments may simply be too bright and desaturated.
- You may be using too much ambient.
- Distance-based light fading (or absence thereof) might also play a role.
Note that virtually all the inc files and sample scenes were created for
comparatively old versions of POV-Ray, so their materials are not really
good for 3.7 unfortunately.
Date: 30 Apr 2010 07:07:17
Message: <4bdab9e5@news.povray.org>
  Maybe that should be changed?
Date: 30 Apr 2010 07:22:50
Message: <4bdabd8a$1@news.povray.org>
does that mean you're volunteering ;-)
Date: 30 Apr 2010 08:01:23
Message: <4bdac693$1@news.povray.org>
Am 30.04.2010 13:07, schrieb Warp:
Definitely so.
Date: 3 May 2010 14:30:01
Message: <web.4bdf150a90dc9ef6cdadb0b0@news.povray.org>
"Quietman" <quietman1968 at hotmail dot com> wrote:
> Hi,
> Output_File_Type=N
> Display_Gamma=1
> File_Gamma=1
> file type (BMP).
> Cheers.
Hello,
I have the same problems with PovRay 3.7 beta 37.
Previous beta version was OK for me : 3.7 beta 36. But for installation of beta
37 it was need to uninstall beta 36... Now all pictures are white...
I tried with this ini seetings:
; Persistence Of Vision raytracer version 3.5 sample file.
File_Gamma = 0.980
Display_Gamma = 0.980
Antialias=On
Sampling_Method=1
Antialias_Threshold=0.1
Antialias_Depth=4
Input_File_Name=name.pov
Output_Alpha=off
Output_File_Type=N   ;; S= bmp, T=uncompressed tga &  N png output
+w800
+h600
;+w3200
;+h2400
Cyclic_Animation=off
Pause_when_Done=on
But if "assumed_gamma 0.98" at 0.98, 1.00, 1.02, 2.0 ,2.2 is present in the .pov
file, same result in the picture : white.
It seems that we can obtain something right if we comment assumed_gamma value :
//assumed_gamma 0.98
in the .pov file
and if we use File_Gamma and Display_Gamma in the ini file.
Now, the modification of assumed_gamma "value" in the .pov file seems to have no
effect on the picture (display)
May it is possible to find beta 36 somewhere?
Many thanks for your advices.
Cheers,
JJ
Date: 3 May 2010 17:34:39
Message: <4bdf416f$1@news.povray.org>
Le 2010-05-03 14:25, JJ a écrit :
> "Quietman"<quietman1968 at hotmail dot com>  wrote:
>> Hi,
>> Output_File_Type=N
>> Display_Gamma=1
>> File_Gamma=1
>> file type (BMP).
>> Cheers.
> Hello,
> File_Gamma = 0.980
> Antialias=On
> Sampling_Method=1
> Antialias_Depth=4
> Output_Alpha=off
> Output_File_Type=N   ;; S= bmp, T=uncompressed tga&   N png output
> +w800
> +h600
> ;+w3200
> ;+h2400
> Pause_when_Done=on
> in the .pov file
> Cheers,
> JJ
assumed_gamma is been phased out and obsolete.
Removing it, or commenting it out is the thing to do.
I don't see your problem on my side. In fact, the files I render with
beta 37 are identical to the beta 36. But, I had the habit of removing
any assumed_gamma before I started using any of the 3.7 betas.
In some scenes, I found some prety weird values, like 0.1, 5 or more,
and some negative values...
Anyway, file_gamma and display_gamma should be set to the actual gamma
value of your system. 0.980 very probably is not the real gamma of your
system. Normaly, it's closer to 2.2.
Date: 4 May 2010 04:50:00
Message: <web.4bdfdf1390dc9ef6cdadb0b0@news.povray.org>
> Alain
Hello Alain,
Many thanks for your answer.
I tried to remove "assumed_gamma" in the .pov file. In both cases, with (value
0.8, 1.0 or 2.2) and without, the picture in the render povray window is the
same and the picture in the file picture (e.g. picture.bmp, png or tga) is very
bright washed out. I tried equally with and without radiosity and the same
results: very bright washed out files.
When I use as the first lines in the .ini file:
  File_Gamma = 0.98
or 1.0 or 2.2 I have the same problem:
gamma in the display povray window and the file picture (bmp, tga or png) is not
the same: very bright washed out files
But with this ini file, we can read equally in the message windows
    "Parse warning: gamma_correction not specified or inferred so is turned off
for compatibility with this pre POV-Ray 3.7 scene."
So how we can specify the same gamma for the render povray window and the file
picture?
Many thanks,
JJ
Date: 4 May 2010 20:33:46
Message: <4be0bcea$1@news.povray.org>
>> Alain
> Hello Alain,
>    File_Gamma = 0.98
> picture?
> Many thanks,
> JJ
To set both to the same thing, use the same value in the ini file.
Set Display_Gamma to the gamma of your system. It sets the gamma for the
preview.
Set File_Gama to that same value or 2.2
Maybe you have a problem with your viewer.
Date: 5 May 2010 07:51:11
Message: <4be15baf$1@news.povray.org>
Am 03.05.2010 20:25, schrieb JJ:
> File_Gamma = 0.980
> Antialias=On
> Sampling_Method=1
> Antialias_Depth=4
> Output_Alpha=off
> +w800
> +h600
> ;+w3200
> ;+h2400
> Pause_when_Done=on
Are you sure these are the same settings that you used with beta.36?
To be frank, I can't imagine you used PNG output when working with
beta.36 - because with PNG files, it doesn't matter what encoding gamma
(derived from File_Gamma) is used: They will only seem to match the
render preview if you set the proper Display_Gamma for your system
(provided the image viewer does a proper job).
Anyway, a beta.37a is just about to be released that will restore
beta.36 gamma behavior.
Date: 5 May 2010 08:50:00
Message: <web.4be168fc90dc9ef6cdadb0b0@news.povray.org>
> > File_Gamma = 0.980
> > Antialias=On
> > Sampling_Method=1
> > Antialias_Depth=4
> > Output_Alpha=off
> > +w800
> > +h600
> > ;+w3200
> > ;+h2400
> > Pause_when_Done=on
Hello Clipka and Alain,
If two povman have the same problem, may be they are a problem somewhere in the
beta 37?
I use this ini file:
> > File_Gamma = 0.980
> > Antialias=On
> > Sampling_Method=1
> > Antialias_Depth=4
> > Output_Alpha=off
> > +w800
> > +h600
> > ;+w3200
> > ;+h2400
> > Pause_when_Done=on
 With file gamma AND (so both) Display gamma values 0.98, 1.0, 2.0 and 2.2,  the
picture in the povray window and the picture in the file is not the same for
povray 3.7 beta 37 but it was OK with the previous version. My input files are
all the same, but with beta 37 the gamma is not the same. It's to much time ago
that I don't use v3.6. But finally, may be I will return back to v 3.6 because
the time need for rendering picture is the same with v3.7 beta 37 so why to use
full charge of the CPU for the same result and time consuming.
- So how to obtain the same gamma settings in the povray render windows and file
and which file format you recommand for povray 3.7 beta 37 windows XP, Vista and
7.
- If it is possible to find the previous version somewhere?
many thanks for your advices,
best regards,
JJ
Date: 5 May 2010 10:05:39
Message: <4be17b33$1@news.povray.org>
Am 05.05.2010 14:47, schrieb JJ:
> beta 37?
Believe me, one of the primary principles I go by when assessing alleged
software errors is that the software /is/ guilty unless evidence
/strongly/ indicates otherwise. So typically I'd try to reproduce the
error scenario as faithfully as possible, and see if the error does
occur or not. If it doesn't, next assumption is that I /misunderstood/
the error scenario, so I start toying around within different
interpretations of the description. If that still doesn't produce the
reported error, I go by the assumption that the error scenario was not
/described/ properly, so I toy around even more. Only if I run out of
ideas what might have gone wrong with the /communication/ about the
error (and believe me, I'm quite creative at that) - or if during the
process I find a scenario which plausibly fits the error description but
is definitely not a bug - do I find the software not guilty.
I did some tests here, and I did find that in the scenario you
described, beta.36 /does/ give the very same results as you report for
beta.37.
Also note that as of now, you are the /only/ person reporting this very
error; Quietman's problem was obviously of different nature, as the
proposed workaround did work for him.
So I do repeat: I cannot find anything like what you report in beta.37
(aside from the File_Gamma=1.0 issue seen by Quietman) that hadn't been
there in beta.36 as well.
I'm not saying you can't possibly see what you claim to be seeing - but
I do suspect that the File_Gamma=1.0 bug in beta.37 found by Quietman
motivated you to have a much closer look at Gamma than ever in beta.36,
and now you're surprised about 3.7 behavior that has been there for
quite a while already, and you just never encountered it before. To me,
the most plausible assumption is that you never tested with PNG output
file format in beta.36 and earlier.
That's not what I see here:
- I /do/ see outright /broken/ behavior in beta.37 with File_Gamma=1.0.
but not for 0.98 or 2.0 or 2.2.
- I also /do/ see gamma discrepancies between preview window and written
file for some other combinations of File_Gamma, assumed_gamma and output
file type, but I do see those very same effects with beta.36 as well.
So my conclusion is that yes, beta.37 does behave as you report, but
your memory of beta.36 behavior is not as accurate as you believe.
> 7.
I strongly recommend to:
(0) Do /not/ use assumed_gamma anymore.
(1) Set Display_Gamma to a value that does really fit your display
subsystem - so that you see in the preview window what POV-Ray expects
you to see.
(2) If your display subsystem gamma is significantly different from 2.2,
make sure that your image viewing program is aware of this fact - so
that you see in your image viewing software what that software expects
you to see (and what POV-Ray expects you to see there).
(3) Use File_Gamma=2.2 unless you want to generate height field data
(unless you are perfectly sure you will never want to view the images on
any other computer or share them via internet) - so that any person
(including you possibly) viewing the output images on any other computer
or with any other image viewing software have the best chance of seeing
what POV-Ray expects them to see in those images.
(4) Depending on what you intend to do with the image, use either
OpenEXR (because it's simply the best) or PNG (because it's one of the
two most common, and does increases the chance of being displayed
properly on other computers) as output format, or JPEG if you don't
intend to post-process it (because it's the other of the two most common).
(5) Design your scenes to look good with these settings right from the
start.
For /legacy/ scenes, make sure to use the "#version 3.6;" statement (or
whatever applies), /do/ use the "assumed_gamma" statement, and do /not/
use the "File_Gamma" setting. Also, do /not/ use PNG output, but rather
BMP or some such.
The POV-Ray dev team has no interest whatsoever in older betas being
circulated freely. You may want to test the brand-new beta.37a though,
which fixes the issue reported by Quietman; I also gave it some thorough
testing to verify that behavior is really identical to beta.36 again
regarding output gamma. (See http://www.povray.org/beta/)
Date: 5 May 2010 22:08:37
Message: <4be224a5$1@news.povray.org>
>>> File_Gamma = 0.980
>>> Antialias=On
>>> Sampling_Method=1
>>> Antialias_Depth=4
>>> Output_Alpha=off
>>> +w800
>>> +h600
>>> ;+w3200
>>> ;+h2400
>>> Pause_when_Done=on
> beta 37?
>>> File_Gamma = 0.980
>>> Antialias=On
>>> Sampling_Method=1
>>> Antialias_Depth=4
>>> Output_Alpha=off
>>> +w800
>>> +h600
>>> ;+w3200
>>> ;+h2400
>>> Pause_when_Done=on
> 7.
> best regards,
> JJ
My ini file DON'T contain ether File_Gamma nor Display_gamma and my
renders show and display correctly.
Maybe it's a problem that occurs only when you explicitely set those
parameters...
Date: 6 May 2010 01:56:11
Message: <4be259fb@news.povray.org>
I'd like to get the mini-dump please - can you email it?
-- Chris
Date: 6 May 2010 03:40:51
Message: <4be27283$1@news.povray.org>
"Chris Cason" <del### [at] deletethistoopovrayorg> schreef in
bericht news:4be259fb@news.povray.org...
>> going
>> send
OK. I send an e-mail with the mini-dump file attached, to the address
indicated in the licence page. Subject name of mail will be "mini-dump of
crash version 3.7"
Date: 6 May 2010 05:05:44
Message: <4be28668@news.povray.org>
> of crash version 3.7"
Got it, thanks a lot, it enabled me to find the bug.
-- Chris
Date: 6 May 2010 09:52:20
Message: <4be2c994$1@news.povray.org>
bericht news:4be28668@news.povray.org...
Glad to have been of help  :-)
Date: 7 May 2010 09:00:41
Message: <4be40ef9$1@news.povray.org>
> default file type (BMP).
Any feedback on beta.37a behavior in this respect? Anyone still
experiencing gamma issues?
Date: 11 May 2010 12:45:01
Message: <web.4be9889290dc9ef6cdadb0b0@news.povray.org>
> preview.
> Alain
Alain,
Thanks for your advices, it seems near to be OK with beta 37a now. Just need to
adjust a little bit.
Best,
JJ
