POV-Ray : Newsgroups : povray.beta-test : Missing parenthesis causes bad crash Server Time
10 Nov 2026 19:03:27 EST (-0500)
  Missing parenthesis causes bad crash (Message 1 to 7 of 7)
Subject: Missing parenthesis causes bad crash
Date: 25 Aug 2009 02:16:30
Message: <4a9381be$1@news.povray.org>
Can someone confirm a crash on the following code?
   #include "fubar.inc"
   Bar(42)
   #macro FooBar() #end
   //fubar.inc
   #macro Foo(Fnord) #end
   #macro Bar(Ignord) Foo(23 #end
Subject: Re: Missing parenthesis causes bad crash
Date: 25 Aug 2009 12:54:47
Message: <4a941757$1@news.povray.org>
Le 25/08/2009 08:16, clipka nous fit lire :
No crash, sorry, with beta.33 (linux x86_64, from sources)
But instead a strange message about the bogus file:
==== [Parsing...] ==========================================================
File '              d' line 3: Parse Error: Expected ')', # found instead
Fatal error in parser: Cannot parse input.
Render failed
(wrapped by newsreader)
Might nevertheless be a random pointer for the file name.
You crashed, I was lucky.
Date: 25 Aug 2009 13:10:38
Message: <4a941b0e$1@news.povray.org>
"Le_Forgeron" <jgr### [at] freefr> wrote in message
news:4a941757$1@news.povray.org...
Beta 34 in Windows 7 RC.
I added the missing ) and put another error and POV reports the file and
line number as it should.
Date: 25 Aug 2009 18:49:38
Message: <4a946a82$1@news.povray.org>
I guess that's what it is.
Date: 26 Aug 2009 19:27:04
Message: <4a95c4c8@news.povray.org>
Yes. I was using the sse2.win32 version and only received a parse error.
Then I tried the non-sse2 version and quickly received an access
violation at 0x005ba88b. Now both versions crash. I have attached the
.dmp file for you.
Sam
Download 'pov-ray-3.7.0.beta.34.msvc9-sse2.win32-4a95c3bc.dmp.dat' (43 KB)
Date: 26 Aug 2009 19:42:56
Message: <4a95c880@news.povray.org>
> .dmp file for you.
A new development: I added the missing parenthesis after reopening POV,
and got it to render, of course. Then I removed the parenthesis and
received the parse error again. Without a crash. Here are the contents
of the message pane:
Messages cleared.
Preset INI file is 'C:\DOCUMENTS AND SETTINGS\SAM\MY
DOCUMENTS\POV-RAY\V3.7\INI\QUICKRES.INI', section is '[512x384, AA 0.3]'.
Preset source file is 'C:\Program Files\POV-Ray for Windows
v3.6\scenes\2009\Summer\bugTesting\fubar_scene.pov'.
Rendering using command line '+ft -f -a0.17 +am2 +r3'.
Rendering with 4 threads.
Parser Options
   Input file: C:\Program Files\POV-Ray for Windows
   Remove bounds........On
   Split unions.........Off
   Library paths:
     C:\Documents and Settings\Sam\My Documents\POV-Ray\v3.7\include
     C:\WINDOWS\Fonts
Render failed
CPU time used: kernel 0.03 seconds, user 0.00 seconds, total 0.03 seconds.
Elapsed time 0.14 seconds.
That was with the sse2 version. I closed POV after the parse error
reopened sse2 again without fixing the parenthesis, and quickly received
the access violation at the same address in memory, 0x005ba88b. It's not
sse2-dependent. The crash seems to occur when you close POV after the
parse error, reopen it and try to render again without fixing the
parenthesis.
Sam
Date: 28 Aug 2009 13:54:23
Message: <4a9819cf@news.povray.org>
I duplicated the crash reliably; did my input help in the least?
Sam
