POV-Ray : Newsgroups : povray.beta-test : beta.33 for Windows: Not Reproducible Server Time
10 Nov 2026 19:03:27 EST (-0500)
  beta.33 for Windows: Not Reproducible (Message 1 to 4 of 4)
Subject: beta.33 for Windows: Not Reproducible
Date: 7 Aug 2009 13:32:39
Message: <4a7c6537$1@news.povray.org>
Check this out:
* Start beta.33 (make sure you really start it fresh)
* Enqueue the following sample scenes:
   - scenes\textures\finishes\arches.pov
   - scenes\textures\normals\normavg.pov
   - scenes\textures\finishes\arches.pov (again!)
* Go for it, paying close attention to the direction and frequency of
the waves in the arches.pov shot (easiest to see at bottom left).
Duh! Shouldn't the scene render identical in both runs?! Looks like
something doesn't get properly initialized.
(Tested with the 64-bit release here.)
Subject: Re: beta.33 for Windows: Not Reproducible
Date: 7 Aug 2009 13:43:15
Message: <4a7c67b3$1@news.povray.org>
Well, what is the wave pattern in arches? There is a (global) method that
initiates all waves, but that would not be much different from 3.6. Is the
bug visible there, too?
	Thorsten
Date: 7 Aug 2009 14:39:12
Message: <4a7c74d0@news.povray.org>
Thorsten Froehlich schrieb:
> that initiates all waves, but that would not be much different from 3.6.
> Is the bug visible there, too?
>     Thorsten
Same thing in 3.6.2, yes - I just checked.
In 3.7, I can track down the bug to a global variable "Number_Of_Waves",
which is initialized to its default value (10) once at startup of the
whole app, and then no more (I guess the same mechanism applies to 3.6).
Any scene having a "number_of_waves" parameter will sort of change the
default for the next scene to be rendered.
There's another potential problem with the waves initialization: The
wave pattern data will always be initialized for 10 waves, no matter how
high or low it is set by the user; for smaller values set in the scene
this is no real problem, because it just accesses the first N waves; but
higher values will lead to accesses beyond the actually allocated data
block.
For the time being I'll change that to impose a maximum limit of 10 on
number_of_waves (higher values were useless anyway), and store the
actual number of waves in the scene data. But I guess it's worth
thinking about moving the waves data into the thread completely. Global
variables are ugly, and it's not really a huge amount of data.
(BTW, the problem should be reproducible in Unix as well, by setting up
an animation that explicitly defines "number of waves" to something
other than 10, but leaves it at the default for later frames; rendering
the whole animation would then cause different results than rendering
just the later frames.)
Date: 7 Aug 2009 16:27:38
Message: <4a7c8e3a$1@news.povray.org>
>> 3.6. Is the bug visible there, too?
>>     Thorsten
Ah, yes, one of the old dead bodies in the code. Should be one of the last
ones. We did mark all globals years ago, so the few remaining ones are easy
to find :-)
The question is if it is really needed or maybe just generating like 100 and
setting the limit there would be more than enough...
	Thorsten
