POV-Ray : Newsgroups : povray.beta-test : problems linking to boost libraries (linux) Server Time
10 Nov 2026 19:25:37 EST (-0500)
  problems linking to boost libraries (linux) (Message 1 to 19 of 19)
Subject: problems linking to boost libraries (linux)
Date: 1 Mar 2009 20:50:02
Message: <49ab3b4a$1@news.povray.org>
I tried to compile the most recent unix source today (the package and
source are both b29 even though the main beta page says the source is
for 31), and can't seem to get it the configure script to find the boost
libraries.
I'm running a fully updated ArchLinux system, and I installed boost 1.37
from the official package manager, and configure failed at checking for
exit in boost_thread-lboost_thread.
I then installed boost 1.38 from source, (after removing it with the
package manager), and got the same error. I tried the config option
'--with-boost-thread=libboost_thread_gcc43-mt' because that is the name
of the library on my system, but it still doesn't work.
Do I need to have the location of the libraries in my $PATH or
something? They are all in the standard /usr/local/lib/, so I didn't
expect it to be weird.
Thanks for any help!
Chris
(I can provide a config.log file if needed, but won't put it inline here)
Subject: Re: problems linking to boost libraries (linux)
Date: 1 Mar 2009 22:05:00
Message: <web.49ab4c181e32e143d7e11e890@news.povray.org>
Did you verify that POV's ./configure script can locate all the boost header
files?
Date: 1 Mar 2009 22:34:30
Message: <49ab53c6$1@news.povray.org>
> files?
I assume it can find the headers, since it's installed in the standard
location (/usr/local/lib/) and a few lines above the error it shows
"checking whether the Boost::Thread library is available... yes".
I also tried to build it with just the boost source,
(--with-boost-src=/home/cshake/Downloads/boost_1_38_0/) and ./configure
works fine, but make dies saying
"*** No rule to make target
'/home/cshake/Downloads/boost_1_38_0/libs/thread/src/barrier.cpp',
needed by 'barrier.o'. Stop".
I looked at that folder and there is no such file 'barrier.cpp' in that
folder or any subfolder, so I am confused.
Chris
Date: 2 Mar 2009 09:05:26
Message: <slrn.gqnptb.962.steev@hot.pl>
(CShake) :
try '--with-boost-thread=boost_thread_gcc43-mt'
> Chris
Slawek
  ________
_/ __/ __/ Zenon Sienkiewicz skrzywdzil Justyne z dwu stron.
 \__ \__ \_______________________________________________________________
 /___/___/ S�awomir Szczyrba                          steev/AT/hot\dot\pl
Date: 2 Mar 2009 11:19:44
Message: <49ac0720$1@news.povray.org>
S�awomir Szczyrba wrote:
> (CShake) :
>> Chris
> Regards,
> Slawek
Thanks, that works for boost.
Now it is throwing errors on zlib,
"checking whether to use the ZLIB library... yes
checking for library containing zlibVersion... -lz
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking for libz version >= 1.2.1... unknown
configure: error: cannot find a suitable ZLIB library"
I know I have zlib 1.2.3 installed, and I tried
'--with-zlib=/usr/include/' (where zlib.h is) and --with-zlib=/var/lib/'
(where libz.so is), neither of which work.
I don't usually have problems compiling anything, boost configured fine
and everything else I run from source has worked (once dependencies are
installed)
Date: 2 Mar 2009 13:00:54
Message: <49ac1ed6@news.povray.org>
"CShake" <cshake+pov### [at] gmailcom> wrote in message
news:49ac0720$1@news.povray.org...
Is Zlib installed as shared lib? I forget the configure switch I used to
install as shared lib. The rest of my install (LAMP server) went fine after
I did this, so mabye it's worth looking into.
Jim
Date: 3 Mar 2009 09:21:49
Message: <49ad3cfd@news.povray.org>
Ah those are tricky paths. When you give --with-zlib=/somewhere, it will
search for includes in /somewhere/include and for the library
in /somewhere/lib. I don't know what to do if you have one in /var and
another in /usr... Symlinks?
Date: 3 Mar 2009 21:04:20
Message: <49ade1a4$1@news.povray.org>
Oops, I looked again and the /var/lib tree was the package manager temp
files, not the installed. libz.so and libz.a are in /usr/lib as well. I
tried --with-zlib=/usr/ [with and without the trailing slash], with the
same results.
I may just give up for now and wait for the next official build of the
beta, I just hoped to use my file/web server box for long renders, since
it's got a decent dual-core CPU.
@Jim - ZLib is a shared library, libz.so.1.2.3.3 is the main file, and
libz.so.1 and libz.so are both symlinks to it. libz.a also exists in
/usr/lib
Did you need to use extra switches to install ZLib as shared, or to
install povray using shared libs?
Date: 4 Mar 2009 06:01:53
Message: <49ae5fa1@news.povray.org>
news:49ade1a4$1@news.povray.org...
> /usr/lib
My apologies if I've confused the issue .....
My Zlib problem was not related to installing the POV-Ray application (beta
or otherwise).
My problem was with installing ImageMagik on my LAMP server. Like you I
thought I had Zlib installed just fine and tried several things until I hit
upon the --shared switch (configure) and just thought it was worth a shot
offering that idea to the discussion.
Good Luck!
Jim
Date: 8 Mar 2009 15:40:43
Message: <slrn.gr87pr.6hv.steev@hot.pl>
Klik-klik-klik... To CShake pisze :
Is zlib-devel installed?
S�awek
  ________
_/ __/ __/ Mniej nale�y obawia� si� g�odu ni� z�ych my�li. -- Henryk Mann
Date: 9 Mar 2009 16:33:13
Message: <49b57d09$1@news.povray.org>
	In fact this might not be a problem with zlib, but something else
in the compiler command-line might prevent liking the test binary that checks
for the libz version.
	In other words, you must check the config.log file to see the actual
error; search for "libz version" (without quotes) to jump slightly above
the error message.
	- NC
Date: 9 Mar 2009 18:42:05
Message: <49b59b3d@news.povray.org>
While it looks like you do, can you confirm that you have the zlib devel
package installed as well?
Jim
Date: 10 Mar 2009 16:10:31
Message: <49b6c937@news.povray.org>
> checks
> the error message.
>     - NC
You are correct, after digging in config.log I see that it is once again
a boost problem:
configure:8561: checking for libz version >= 1.2.1
configure:8593: g++ -o conftest  -pthread -I/usr/lib/../include
-pthread -I/usr/local/include/boost-1_38 -L/usr/lib  -L/usr/local/lib
conftest.cpp -lz -lrt -lm -lboost_thread-gcc43-mt  -pthread  >&5
configure:8596: $? = 0
configure:8602: ./conftest
./conftest: error while loading shared libraries:
libboost_thread-gcc43-mt-1_38.so.1.38.0: cannot open shared object file:
No such file or directory
This error confuses me as well, because
/usr/local/lib/libboost_thread-gcc43-mt-1_38.so.1.38.0 exists, with
permissions -rwxr-xr-x u:root g:root, so it shouldn't have trouble
reading the .so
cshake
Date: 10 Mar 2009 16:22:26
Message: <49b6cc02@news.povray.org>
>> checks
>> the error message.
>>     - NC
> a boost problem:
> configure:8593: g++ -o conftest  -pthread -I/usr/lib/../include -pthread
> reading the .so
> cshake
Well, just downloaded the b31 source and tried again, this time with it
dying at 'checking if boost thread library is usable', but with the same
reasons.
config.log shows the same errors. I'm confused why the switch
'-I/usr/local/include/boost-1_38' exists, since my calling line is
'$ ./configure COMPILED_BY=cshake <cshake+pov### [at] gmailcom>
--with-boost=/usr/local --with-boost-thread=boost_thread-gcc43-mt',
nowhere do I say that boost is within the 'boost-1_38' subdir, because
it isn't. Do I need to create that subdirectory with symbolic links in
it, or edit the configure script to not add the extra path?
Date: 10 Mar 2009 18:08:03
Message: <49b6e4c3$1@news.povray.org>
	So linking is successful since the boost thread lib is indeed found
under /usr/local/lib.
	Now this is the sign that something is wrong at runtime, i.e. as if
/usr/local/lib is not set in the default search path for the runtime linker.
You may check with ldconfig whether this is the case.  For testing before
having to modify your system setup, you may try using LD_LIBRARY_PATH
(e.g. export LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH) before running
configure and (hopefully) the povray binary.
	- NC
Date: 10 Mar 2009 18:14:37
Message: <49b6e64d$1@news.povray.org>
	This path was guessed by configure as a possible search path for
the boost libs after failing looking in "standard" directories.  It won't
harm to search a non-existing path for include files, however that means
maybe the boost install is somewhat screwed.  What is the actual location
of the boost 1.38 headers on your system?
	- NC
Date: 10 Mar 2009 21:07:14
Message: <49b70ec2$1@news.povray.org>
>     - NC
All the .a and .so libraries are in /usr/local/lib/, and all the .hpp
headers are in /usr/local/include/boost-1_38/boost/ (and subdirectories)
Boost was installed from source without any extra configure switches,
just $ ./configure and $ sudo make install.
Date: 10 Mar 2009 21:18:51
Message: <49b7117b@news.povray.org>
OK, guess this is just due to the pov-team only officially supporting
boost 1.37 and not 1.38. I removed all the 1.38 files that were built
from source, and installed 1.37 from pacman (the ArchLinux repository
system), and it worked fine only having to change the name of the thread
library to boost_thread-mt.
Guess this whole thread can be ignored now, or maybe just as a caution
to not use 1.38.
cshake
>>> because it isn't. Do I need to create that subdirectory with symbolic
>>> links in it, or edit the configure script to not add the extra path?
>>     - NC
Date: 11 Mar 2009 07:34:20
Message: <49b7a1bc$1@news.povray.org>
> to not use 1.38.
	No, (under linux at least) 1.38 works as well as any boost version since 1.35.
	Ok, indeed this is what happens by default when installing boost from sources.
Just create a symlink then, e.g.
sudo ln -s /usr/local/include/boost-1_38/boost /usr/local/include/boost
	- NC
