POV-Ray : Newsgroups : povray.beta-test : Beta 28 now available Server Time
10 Nov 2026 19:46:41 EST (-0500)
  Beta 28 now available (Message 1 to 19 of 19)
Subject: Beta 28 now available
Date: 2 Aug 2008 11:54:54
Message: <4894834e@news.povray.org>
Beta 28 is now available for Windows 32-bit. 64-bit will follow shortly. I
will also be updating the source to beta 28 in the next day or so.
I can't at this point provide any information about the availability of
Linux binaries, however with the source updated it will be fairly easy for
Linux users to build their own.
-- Chris
Subject: Re: Beta 28 now available
Date: 2 Aug 2008 13:37:09
Message: <48949b45$1@news.povray.org>
> -- Chris
This might be a dumb question, but now that we're using an installer,
should we uninstall the old beta before installing the new one or simply
install over it?
...Chambers
Subject: Re: Beta 28 not installing on my Vista user or admin
Date: 3 Aug 2008 00:25:52
Message: <48953350$1@news.povray.org>
"Chambers" <ben### [at] pacificwebguycom> wrote in message
news:48949b45$1@news.povray.org...
> install over it?
I tried to install as-is and got a message stating the previous one must be
uninstalled. Says the same in the actual installer, too, but after the fact.
I figured that was best anyway but I actually saw your message here first
and thought I'd take the risk. ;)
Problem is... it never finished the install, giving a error 1925. Says it
couldn't be done without administrator privileges (or some such), and yet
the Vista OS user account was already set to that being the only one
present.
Added another account, set that to administrator and the original to
standard user. Staying logged in and switching to the new administrator
account, again the installer was interrupted by that same error 1925.
Still haven't tried going back to the now "standard" user account to try it
that way, just about to do that so I will post back here.The installer
choices (radio buttons) of one user or all did not change the end result so
far.
Date: 3 Aug 2008 00:41:18
Message: <489536ee$1@news.povray.org>
"Bob Hughes" <omniverse charter net> wrote in message
news:48953350$1@news.povray.org...
> ---8<---snip---
> it that way, just about to do that so I will post back here.The installer
> so far.
no luck going back to "standard" user account and also logging off the
administrator account (did have both logged on before). The installer seems
to want administrator privileges regardless of the "Only for me" choice.
/*bob hughes*/
Subject: Re: Beta 28 successful install Vista user
Date: 3 Aug 2008 04:34:49
Message: <48956da9$1@news.povray.org>
This is only a guess about why I succeeded in getting the beta 28 installer
to put POV onto my Vista Home notebook... UAC set to off. Simple as that
maybe. However, I don't know anything about multiple users in Windows having
seldom ever done it. And Vista is a complete unknown to me in that
department.
The installer actually greyed out the two choices for "only me" or "all", so
apparently without UAC it ignores that. Now this is the confusing part, I
believe I ran the installer from the new administrator account yet the file
was in my other user/downloads subfolder. The greyed out portion still had
the "me" option as the other user name and not the new user.
Maybe others of you know about this user account stuff and understand that,
I sure can't explain it or if it might be something peculiar to the beta 28
installer itself.
To further describe my particular experience with this, I found I needed to
get the povray.ini and quickres.ini files put back in place like I had been
using them. The readme.txt in the installation folders \Scenes\ and \ini\
certainly help but since Vista (Home anyhow) has the destination paths
hidden and a different location (AppData\Roaming) from XP or 2000, as told
of, I'm still wondering what will happen when people try to migrate from 3.6
to 3.7 and can't figure this out.
Also, trouble with writing to the \include\ subfolder, lacking permission.
What I'm doing now is making a C:\include\ folder to put INC files into and
then adding that to the povray.ini library paths, which in itself isn't
straightfoward yet since the tools.ini isn't available for editing from
within POV-Ray itself.
I don't want to be negative about the whole thing... ;^) I like the new look
and installer thus far. Congrats on the work.
/*bob hughes*/
Date: 3 Aug 2008 07:34:28
Message: <9t5b94tfhq19bkokf11js6afmdbs46k15h@4ax.com>
On Sat, 2 Aug 2008 23:25:50 -0500, "Bob Hughes" <omniverse charter net> wrote:
>present.
I had problems too. I could not install it as an administrator neither as a
single user nor multi user ??? So I switched of the User Account Control.
I disconnected from the internet then:
Switched off UAC
Restart
install Pov
Switched on UAC
Restart
Play with Pov-Ray :)
Regards
Date: 3 Aug 2008 07:53:35
Message: <48959c3f@news.povray.org>
Apologies to those who attempted to install on Vista and weren't able to.
The problem was due to the fact that despite setting the INSTALLPATH
property to the appropriate location (under AppData), Windows Installer was
still attempting to install the files into program files. This should now
be rectified. There will still most likely be weirdness installing for all
users under Vista - probably UAC will not trigger, blocking the install.
This isn't really an issue since All Users isn't fully supported yet.
-- Chris
Date: 3 Aug 2008 08:07:17
Message: <op.ufa7ygwo7bxctx@e6600>
On Sun, 03 Aug 2008 06:25:50 +0200, Bob Hughes <omniverse charter <"net>">
> it couldn't be done without administrator privileges (or some such), and
> yet the Vista OS user account was already set to that being the only one
> present.
Under Vista, with UAC enabled, even administrator accounts do not have
full administrator privileges. Either disable UAC or right-click the
executable and choose "Run as administrator".
Typically, Vista will notify you when an installer needs administrative
privileges, and prompt the user, but not always. It may have something to
do with the name of the installer; at least that is how it worked in XP.
FE
Date: 3 Aug 2008 11:40:01
Message: <web.4895d0a2a249cb29bd42b07a0@news.povray.org>
3.7 beta 28 installed perfectly on Vista Basic with UAC turned on, no errors
like the 27 version.
Date: 3 Aug 2008 17:41:50
Message: <4896261e$1@news.povray.org>
"Chris Cason" <del### [at] deletethistoopovrayorg> wrote in
message news:48959c3f@news.povray.org...
> was
Good to know there was a reason other than something I was doing with Vista.
Glad you figured it out Chris.
As the others have said, UAC off was what finally made sense, which must
have been the difference between a no-go and successful install. I chose to
try this in the middle of the night (again) when I wasn't thinking clearly
to begin with.
Curious thing then that the posting by SafePit here was okay even though UAC
was on... something about Vista Basic? This was another lesson for me in
using Vista, to look at UAC first not last.
/*bob hughes*/
Date: 3 Aug 2008 22:20:30
Message: <4896676e@news.povray.org>
Executables can have a "manifest" saying they need admin privileges. The
same kind of manifest used on Windows XP for an app to say it wants to be
XP-styled (by loading the newer common controls library).
Date: 4 Aug 2008 03:19:13
Message: <4896ad71@news.povray.org>
Good news, Chris!
It is time for a file conversion tool (import/export), I think. And the
radiosity should be change from alpha to regular. Well, let's see. But
POV-Ray is a masterpeice of good work!
My best wishes for the team, and lots of thanks,
Sven
Date: 4 Aug 2008 05:09:22
Message: <4896c742$1@news.povray.org>
"Bob Hughes" <omniverse charter net> a écrit dans le message de news:
4896261e$1@news.povray.org...
> UAC was on... something about Vista Basic? This was another lesson for me
> in using Vista, to look at UAC first not last.
It worked OK here too (Vista Home Premium) with UAC on. The only issue, as
previously reported, is that AppData is hidden by default, so users must
unhide it to be able to browse through the ini and demo scenes files.
G.
Date: 4 Aug 2008 06:39:28
Message: <4896dc60@news.povray.org>
I wasn't aware of that (hadn't noticed when testing). The installer does
however place a link to the scene files in the start menu group and IIRC on
the desktop.
It's also rather ironic if hidden is in fact the default; according to the
InstallShield documentation, one of the requirements for Vista logo
cerfification is that files installed for non-admin users go under AppData.
-- Chris
Date: 4 Aug 2008 07:20:22
Message: <4896e5f6$1@news.povray.org>
"Chris Cason" <del### [at] deletethistoopovrayorg> a écrit dans
le message de news: 4896dc60@news.povray.org...
> on
> the desktop.
OK I'll have a look.
> AppData.
Apparently the question of where to install + store writeable files in Vista
does not have an easy answer.
http://lists.runrev.com/pipermail/use-revolution/2007-February/094217.html
Also it looks like InstallShield doesn't have a variable for
CSIDL_COMMON_DOCUMENTS so workarounds are needed.
http://community.installshield.com/showthread.php?t=159616 (see last
message)
http://community.installshield.com/showthread.php?t=181423
G.
Date: 4 Aug 2008 08:13:26
Message: <op.ufc2wnmv7bxctx@e6600>
On Mon, 04 Aug 2008 12:39:26 +0200, Chris Cason
> the
> AppData.
"Application Data" is where you store configuration files and such. Files
that users work on directly go under "My Documents" or "Shared Documents".
FE
Date: 4 Aug 2008 08:50:30
Message: <4896fb16$1@news.povray.org>
"Gilles Tran" <gil### [at] agroparistechfr> wrote in message
news:4896e5f6$1@news.povray.org...
> dans le message de news: 4896dc60@news.povray.org...
>> on
>> the desktop.
I was overlooking the scene file shortcut at first because I don't show
icons in order to better see the background image wallpaper (a pov
rendering). My most-used programs are on Quick Launch, or last used list of
the Start Menu.
I know now the shortcut will provide access to those files outside of POV,
despite them not showing in Computer or user file lists.
>> the
>> AppData.
> Vista does not have an easy answer.
> message)
Helping me by reading more... found a web page describing path changes from
older Windows to Vista:
http://www.svrops.com/svrops/articles/jpoints.htm
When I read what I could find about AppData\Roaming things began making less
sense. ;)
Just saw what Fredrik Eriksson said and the Users\Public location comes to
mind, but that's after the short reading I was doing before. I'm sure
something will work out, I have faith.
/*bob hughes*/
Date: 4 Aug 2008 17:38:10
Message: <489776c2@news.povray.org>
> AppData.
Files local to a specific user account. That doesn't necessarily mean "files
the user will want to see or tinker with".
Date: 7 Aug 2008 07:51:31
Message: <489ae1c3@news.povray.org>
> message)
Thanks for that; it's an interesting read. Glad to know I'm not the only
one scratching their head.
I did think of installing the scene files etc into 'My Documents' (and its
equivalent on Vista*). But - perhaps I am too pedantic - I have always
disliked 'My Documents' and don't even tend to use it on my own machine. I
simply find the name Microsoft gave it as quite condescending. I realise
this is not a good technical reason to avoid using it in an installer and I
might very well end up doing this; I guess it's just habit that I avoid it:)
If I do move the files I will probably move them all from AppData. While
there are some files in AppData that don't need to be in My Documents (e.g.
the Insert Menu, which already has a means of being opened from the program
directly), I really don't want to have three separate locations for POV
files (e.g. in the case of an all-users install).
-- Chris
* At least Microsoft got rid of the 'My ...' prefix in Vista.
