POV-Ray : Newsgroups : povray.beta-test : v3.7 example scenes Server Time
3 Jul 2026 11:11:39 EDT (-0400)
  v3.7 example scenes (Message 81 to 90 of 93)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: v3.7 example scenes
Date: 22 Sep 2008 07:02:53
Message: <48d77b5d@news.povray.org>
"Chris Cason" <del### [at] deletethistoopovrayorg> wrote in
message news:48d700f7@news.povray.org...
> Jim Holsenback wrote:
>> I did change ALL distro scenes that called any glass textures the old
>> way.
> I think you missed woodbox.pov then:] (either that or I didn't update
> it for some reason).
I still have modified scenes on my system and it (woodbox.pov) looks like
it's been done on my end. I connected to the ftp site and in
jim/scenes/advanced woodbox.pov has been changed as well.
> While I'd like to see a warning issued, the problem would be that
> anyone with a pre-3.7 scene loading the include file (even if they
> don't use the glass textures) would get the warning ... I expect some
> scenes out there do include files that they don't use, and would thus
> get this warning. Also, anyone running an old scene without a #version
> set would get a parse failure on the missing textures.
> I think we need to provide both for the meantime. Perhaps we also then
> need something like the 'deprecated' warning that is available in
> compilers; we can declare something deprecated (via SDL) and if it is
> used in a scene the parser spits out a warning.
> -- Chris
Perhaps I jumped the gun abit. Things were flying pretty fast and when I
floated the idea of addressing this issue it didn't seem that anyone had any
strong feelings one way or another, so I pulled the trigger. If I could have
a few days to think about how to address this to everyones satisfaction I'd
like to take ownership of putting this issue to rest. In the meantime if
there are anymore specific considerations I should be aware of ..... let 'em
fly!
Date: 22 Sep 2008 09:26:43
Message: <48d79d13@news.povray.org>
another thought .... woodbox.pov will still issue the I_Glass warning if the
modified glass.inc and glass_old.inc files are not in place. Those file are
on the ftp site in the  jim/include directory.
Ciao
Date: 23 Sep 2008 00:47:53
Message: <48d874f9$1@news.povray.org>
You are correct; it appears the updated installer I made had the old
file in it for some reason. Apologies for getting it wrong.
Sure, feel free to think it over. I think we need to move forward on
stuff like this without the fear of being bound to the past, while at
the same time keeping in mind that one of the impediments to upgrading
any software is if a user's old files don't work (properly). Hence we
need to balance things and provide backwards compatibility where possible.
If (as it appears to be the case) the SDL as it stands doesn't provide
a clean way of deprecating existing constructs while still permitting
their use, then we need to enhance the SDL. I'm inclined to add such a
means. For example:
  #declare I_Glass4=
    deprecated once "... some message goes here ..."
    interior {
      ior 1.5
      fade_distance 2.0
      fade_power 1001
if we did it this way, for example, the #declared item is known by the
parser to be deprecated: this generates no warning during the parse of
the #declare itself (or even if the #declare is used in another
#declare), but if it is used in an actual object, the message
associated with it is displayed (if the 'once' keyword is present,
it's only displayed once per parse, otherwise it's displayed each time
it's used in an object).
I'm not saying it has to be done this way; it's just one thing that
comes to mind. It would require the parser to track the deprecated
status of each #declared item (passing up the state if a new declare
inherits a deprecated declare, and so forth), which isn't as clean as
I'd like it to be. The other option is to display the warning anytime
the declare is used (even if in another declare, which means we have
to ensure we don't use such declares as part of something else in the
same standard include file as this would trigger the warning even if
the end-user didn't use the #declared item).
-- Chris
Date: 23 Sep 2008 05:29:06
Message: <48d8b6e2$1@news.povray.org>
> I'd like it to be.
If the SDL could be changed to allow calling parameterless macros
without parantheses, it might be possible to do something like
#declare I_Glass4_Deprecated =
     interior {
       ior 1.5
       fade_distance 2.0
       fade_power 1001
#macro I_Glass4()
   #warning "I_Glass4 is deprecated"
   I_Glass4_Deprecated
Date: 23 Sep 2008 08:53:20
Message: <48d8e6c0@news.povray.org>
message news:48d874f9$1@news.povray.org...
cool .... we're on the same page then.
> means. For example:
>  #declare I_Glass4=
>    interior {
>      ior 1.5
>      fade_distance 2.0
>      fade_power 1001
How big of a deal to do this? Giving the parser the means to do this could
be useful for furture change issues as well right? This issue (I_Glass)
isn't the first time and I'm sure it wouldn't be the last, so I kind of like
this idea at first glance.
> -- Chris
I've pseudo coded an idea but haven't had the time to see if it might lead
anywhere. Basically the idea would use a function to return the state of a
toggle so we could conditionally provide a warning, but your suggestion has
me thinking that my idea is more of a patch than a solution.
Jim
Date: 24 Sep 2008 23:33:49
Message: <48db069d$1@news.povray.org>
Yes, it would be: this is the primary reason why I'm considering it.
I've prototyped this in the parser and it seems to be working OK so
most likely I'll include it in the next beta. I'll get an early copy
to you so you can add support for the keyword in the include files if
you like.
-- Chris
Subject: Re: Need disc space
Date: 25 Sep 2008 06:10:46
Message: <48db63a6@news.povray.org>
"Jim Holsenback" <jho### [at] hotmailcom> wrote in message
news:48a98a0d@news.povray.org...
>> Stephen & Sabrina: I'm done with all my edits and have rendered all the
>> files in the textures directory.
you guys have been silent for awhile ..... any status update?
Date: 25 Sep 2008 06:13:13
Message: <48db6439@news.povray.org>
message news:48db069d$1@news.povray.org...
>> could
>> like
> you like.
> -- Chris
thanks that would be great!
Date: 25 Sep 2008 09:32:53
Message: <48db9305@news.povray.org>
Ok, it's in the FTP dir (pvengine.zip). Note that this has some other
changes related to paths: you may need to copy your standard scenes,
include, ini, and insert menu files to 'My Documents\POV-Ray\v3.7'.
Syntax is as follows:
  #declare deprecated Col_Glass_Old=color rgbf <0.8, 0.9, 0.85, 0.85>;
  #declare deprecated once Col_Glass_Old=... etc
  #declare deprecated "Some message" Col_Glass_Old=... etc
A deprecated identifier generates no message at the time it is declared: a
warning is only issued if it is used.
If the optional 'once' keyword is present it must immediately follow the
'deprecated' keyword and indicates that the warning should only be
displayed once per parse.
If the optional message string is present, it will be used as the warning
to be displayed if the identifier is used. Otherwise, a message of the form
"Identifier 'Col_Glass_Old' was declared deprecated." is used.
An identifier is considered 'used' if it is referenced anywhere (even if in
another #declare).
-- Chris
Date: 25 Sep 2008 09:37:36
Message: <48db9420$1@news.povray.org>
NB I have files from all three of you now: I think the set is basically
complete.
thanks for the help folks!
-- Chris
