POV-Ray : Newsgroups : povray.beta-test : 3.7 beta Unix/Linux source code now available. Server Time
10 Nov 2026 19:55:48 EST (-0500)
  3.7 beta Unix/Linux source code now available. (Message 1 to 22 of 22)
Subject: 3.7 beta Unix/Linux source code now available.
Date: 27 Feb 2008 06:46:55
Message: <47c54daf$1@news.povray.org>
Folks,
The Linux source for 3.7 (currently marked beta 25b) is now available via
our beta source page, http://www.povray.org/beta/source/. Please be sure to
read the INSTALL included within the archive if you intend to build it.
regards,
-- Chris
Subject: Re: 3.7 beta Unix/Linux source code now available.
Date: 27 Feb 2008 11:58:12
Message: <47c596a4@news.povray.org>
wonderful!  as soon as I get home, I'll try it out!
Date: 27 Feb 2008 11:59:30
Message: <47c596f2$1@news.povray.org>
oh, I got too excited that didn't even remember I have only
single-core... :P
oh, well, the source may be entertaining enough!
Date: 27 Feb 2008 12:45:01
Message: <web.47c5a0575980e9263b3ced460@news.povray.org>
already compiled it in a x86_64 GNU/Linux box, but still some bugs around.
Most critical one for me is that even tough I have 64G RAM and a 4 quad-core
Xeon, I get a "Fatal error in renderer: Out of memory." due to some problem
with interiors. Does anyone know about the status of this bug?
Anyway, SMP works perfectly!
Date: 27 Feb 2008 15:40:00
Message: <web.47c5ca0d5980e9267d55e4a40@news.povray.org>
I can't find a full, up-to-date list of known bugs. Perhaps the best thing to do
would be to start a new thread and post a minimal scene to show the problem.
Tom
Date: 27 Feb 2008 20:02:34
Message: <47c6082a$1@news.povray.org>
This is not a bug, it is an internal buffer that trades speed for memory
limits. It should not be needed, but a better solution is complicated and
time intensive to implement.
	Thorsten
Date: 28 Feb 2008 03:46:14
Message: <47c674d6@news.povray.org>
  Could the reaching this limit be detected and a better error message be
shown? Now it looks just like a regular "out of memory" error while it
really isn't, as it's a particular special case. Perhaps a more informative
message could be better in this situation.
Date: 28 Feb 2008 05:23:05
Message: <47c68b89$1@news.povray.org>
> shown?
I said a better solution is possible, did I not? ;-)
	Thorsten
Date: 28 Feb 2008 07:20:36
Message: <47c6a714$1@news.povray.org>
Sample scene please?
Date: 28 Feb 2008 10:30:00
Message: <web.47c6d25a5980e926f5d6567d0@news.povray.org>
Not sure if this is the right location to post this...
I managed to get it compiled on a quadcore system running Fedora 8, though it
took a while to figure out that I had to configure with the option
"--with-boost-thread=boost_thread-mt"
Test render during compilation worked fine, but when I went to render some old
scenes I had laying around I would  get the message:
"Timed out waiting for worker thread startup"
If I keep running the command it will eventually work, but I generally get the
time out message instead of parsing and rendering.
I decided to try beta binary and got the same thing.
Seems like it should be something simple, but I don't know where to start.
SMP worked fine when it would actually render.
--paul
Date: 28 Feb 2008 11:14:58
Message: <47c6de02@news.povray.org>
Thorsten Froehlich nous apporta ses lumieres en ce 2008/02/28 05:23:
>>> memory limits. It should not be needed, but a better solution is
>>> complicated and time intensive to implement.
>> shown?
>     Thorsten
The error message should read "Buffer overflow", not "Out of memory".
You know you've been raytracing too long when you can recite your high school
Trig book from memory.
Date: 28 Feb 2008 11:16:33
Message: <47c6de61$1@news.povray.org>
That will scare the hell out of users who know those two words related
to security vulnerabilities.
Date: 28 Feb 2008 11:54:25
Message: <47c6e741$1@news.povray.org>
Nicolas Alvarez nous apporta ses lumieres en ce 2008/02/28 11:16:
Undetected buffer overflow is bad. Detected ones or those that cause a process
to abort are usualy not a problem.
Alternately, it could be "Work buffer full", or "Buffer fault".
Date: 28 Feb 2008 12:00:31
Message: <47c6e8af$1@news.povray.org>
> process to abort are usualy not a problem.
It isn't a buffer overflow.
	Thorsten
Date: 28 Feb 2008 12:08:44
Message: <47c6ea9c@news.povray.org>
*I* know that, but go explain it to naive users, who have "buffer
overflow = security exploit" on their heads.
http://blogs.technet.com/markrussinovich/archive/2005/05/17/buffer-overflows.aspx
Also, the buffer didn't overflow. It reached a limit, and stopped there.
So such a message would be incorrect anyway.
Date: 28 Feb 2008 15:08:36
Message: <47c714c4$1@news.povray.org>
	This indeed seems to happen on Fedora 8 and some current gentoo distro
at least.  Others such as Debian or Ubuntu usually work.  At the moment
I can't tell what might cause the problem, i.e. whether it has to do with
libc, boost, the system thread library or else  :-/
	- NC
Date: 29 Feb 2008 10:55:37
Message: <47c82af9$1@news.povray.org>
Nicolas Alvarez nous apporta ses lumieres en ce 2008/02/28 12:08:
So "Buffer full" or "Buffer limit reatched" would be a more correct message.
Date: 29 Feb 2008 12:30:24
Message: <47c84130@news.povray.org>
  The message should also say *which* buffer. That way the user can know
better what exactly is it in his scene that is causing the problem.
Date: 1 Mar 2008 03:29:37
Message: <47c913f1$1@news.povray.org>
Le Thu, 28 Feb 2008 21:08:35 +0100, Nicolas Calimet a modifié des petits
morceaux de l'univers pour nous faire lire :
distro
> with libc, boost, the system thread library or else  :-/
> 	- NC
Yes. I confirm that.
I'm on gentoo amd64 (~amd64: unstable), and it looks like it can run once
then fails.
Even invoking only "povray --version" does produce this issue: first time
is ok, next are "Timed out".
My setting is
# ./configure COMPILED_BY=... --disable-io-restrictions
(... is a place holder)
# make check
# make install
Even adding --disable-optimiz-arch does not change the issue.
A reboot (it's a bit hard) allow one run.
I made a ps before first run, then after second (failed) run: no lagging
process.
The trigger seems to be in vfesession.cpp vfeSession::Initialize
Might it be related to a resume state ?
Shouldn't this issue have it's own thread ?
even the sequence:
# ./configure ....
# make check
# make check
would trigger the issue.
Any suggestion how I could help ?
Date: 1 Mar 2008 08:53:41
Message: <47c95fe5$1@news.povray.org>
it is great to have the code, I enjoy playing around with it ;)
With my self-compiled pov-ray beta I keep getting errors like "Xlib:
unexpected async reply (sequence 0x68)!". I suspect the reason is that
POV calls SDL functions from different threads or from signal handlers.
SDL's graphics functions are not thread-safe. I do not have this problem
when I switch the display off.
I have not tried the official binary.
Lukas
Date: 4 Mar 2008 05:27:36
Message: <47cd2418@news.povray.org>
I would tend to agree. Since the OP didn't post a sample scene or respond
to my request for one, I can't do much at this point, as I simply don't
know what part of the code is involved. It appears that others do know
this, though - could someone perhaps take the time to actually *tell* me
what part of the interior code in question this is? Or provide a scene so I
can find out myself?
-- Chris
Date: 4 Mar 2008 05:46:18
Message: <47cd287a$1@news.povray.org>
It comes from the fixed size vector code as far as I can guess.
	Thorsten
