POV-Ray : Newsgroups : povray.beta-test : Source code status Server Time
3 Jul 2026 02:23:46 EDT (-0400)
  Source code status (Message 11 to 20 of 27)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: Source code status
Date: 10 Feb 2008 21:14:11
Message: <47afaf73$1@news.povray.org>
nemesis wrote:
> Chris Cason <del### [at] deletethistoopovrayorg> wrote:
>> I presume no-one had problems with this EXE?
> I'd be glad to be of any help, but I'm running Linux.
no problem, there have been a few folks who did download it, and I guess no
news is good news :/
-- Chris
Date: 10 Feb 2008 23:45:00
Message: <web.47afd257ce3b77caaaacc8f30@news.povray.org>
I'm probably too late but I just found the Tools menu empty and couldn't get
"reloaded" until I moved the pvtools.ini to the location being asked for.
Here's what the messages said, before and after:
Loaded 0 tools from C:\Users\Bob\AppData\Roaming\POV-Ray for Windows\pvtools.ini
into Tool Menu.
Loaded 8 tools from C:\Users\Bob\AppData\Roaming\POV-Ray for Windows\pvtools.ini
into Tool Menu.
So I'm not sure if this was a problem or something unfinished or...?
I did the pvengine /install from a command line and that seemed to do what was
intended. Have the 3.7 registry entries. What I had done was to create a
duplicate folder renamed POV-Ray for Windows v3.7, containing everything from
the v3.6 folder.
Also renamed the help file as suggested and it works, too.
Date: 11 Feb 2008 00:05:01
Message: <web.47afd728ce3b77caaaacc8f30@news.povray.org>
Sorry, I neglected to give system info:
Vista Home Premium
AMD Turion 64 X2
And just now realized the SSE2 does crash when drag'n'drop is done. Error is
access violation exception generated at address 0x0060b9d4
Regular pvengine.exe doesn't crash.
Date: 11 Feb 2008 04:40:01
Message: <web.47b01728ce3b77caaaacc8f30@news.povray.org>
sorry again, not thinking!
That SSE2 wasn't part of this beta 25a, so of course you already knew that. I
wasn't paying attention to what all I copied over to the new v3.7 folder I
made.
Date: 11 Feb 2008 13:12:50
Message: <op.t6dgvnwt7bxctx@e6600.bredbandsbolaget.se>
On Mon, 11 Feb 2008 02:18:57 +0100, Chris Cason
I did a fresh install of 3.6.1c, verified that it works, and then tried
the beta exe:
When launched from a subdirectory of \POV-Ray\bin, I get "ERROR: Cannot
find Home entry in registry (and cannot infer it)."
When launched from the \POV-Ray\bin directory, I get an access violation
exception.
The machine in question is running a Core2Duo E6600 (2.4 GHz) with 2 GB
RAM on WinXP Pro.
FE
Date: 12 Feb 2008 05:25:52
Message: <47b17430@news.povray.org>
> exception.
yes, I just found this myself, which is why I put off the source release a
day or so. thanks for the report.
-- Chris
Date: 13 Feb 2008 04:06:09
Message: <47b2b301$1@news.povray.org>
Frederik, Kyle, Tom - you should have received email from me by now with a
link to the source code preview. If not, please check your spam filter.
-- Chris
Date: 13 Feb 2008 16:49:20
Message: <op.t6hf8ha97bxctx@e6600.bredbandsbolaget.se>
On Wed, 13 Feb 2008 10:06:07 +0100, Chris Cason
> Frederik
Hmpf!
Some preliminary remarks:
Building the editor dlls requires that you have the ATL libraries and
headers installed. They are included in the default installation options
of VC2k5, but can be deselected. Not a big deal, but worth mentioning in
the build instructions.
Using the 'DEVELOPMENT' macro to make POV-Ray search for the editor dlls
in the 'codemax' directory (as described in the readme) does not work,
because it looks for them in the wrong place. POV-Ray looks for
'"..\\codemax\\" BINDIRNAME "\\" EDITDLLNAME', but it should be
'"..\\..\\codemax\\" BINDIRNAME "\\" EDITDLLNAME'.
The linker fails to link in the debug info in 'vc80.pdb' because it is not
in the same directory as 'povcore-debug.lib' (one is in 'Win32 Debug', the
other in 'bin32'). I have not yet investigated what impact this has on
debugging.
Compilation produced no errors though, and the resulting executable seems
to work fine. I have not attempted to add OpenEXR yet.
FE
Date: 13 Feb 2008 20:33:15
Message: <mg67r3lbg93hk8p7cedf3c1nbt5l2b6pfa@4ax.com>
Chris,
I sent you an email reply outlining my results.  Let me know if you don't get it.
Kyle
Date: 13 Feb 2008 20:40:49
Message: <al67r3p1knur85hf5b1e54bqv4fdbtqpje@4ax.com>
On Wed, 13 Feb 2008 22:49:19 +0100, "Fredrik Eriksson" <fe79}--at--{yahoo}--dot--{com>
As a side note, the ATL libraries and headers are not included in VC++ 2005 Express
Edition.  The
header files are in the Windows platform SDK, but the atlthunk.lib library isn't.  I
found a
workaround that seems to have worked here...
http://www.codeproject.com/KB/wtl/WTLExpress.aspx
