![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
When rendering the attached POV file, POVRay craches with a access
violation. I have also included the dump file.
I am rendering at 320x240 AA0.3, on a PentiumD 620 (2x2.8GHz) with 1Gb of
DDR RAM.
This crash is 100% repeatable and it always crashes in exactly the same bit
of the image, the 4th block of 4th row at 320x240.
I beleive the problem may be due to light_group handling as this was the
last thing I added to the scene file. If I remove the light_group from the
Pod #declare, it renders OK. It also renders quite OK in POV3.6.1c
If you need any more info, just ask
Rarius
Download 'battlestar.pov.txt' (34 KB)
Download 'POV-Ray-3.7.0.beta.19.msvc8-sse2.win32-45C8B008.dmp.dat' (46 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: POV-Ray-3.7.0.beta.19.msvc8-sse2.win32 crash
Date: 7 Feb 2007 15:30:27
Message: <45ca36e3@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> DDR RAM.
Thanks for this, will investigate.
-- Chris
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 7 Feb 2007 23:44:19
Message: <45caaaa3@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> DDR RAM.
> -- Chris
For what it's worth, rendering that scene file on the same version and
with the same rendering options doesn't cause a crash for me.
Lance.
thezone - thezone.firewave.com.au
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 8 Feb 2007 03:00:15
Message: <45cad88f@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Lance Birch" <-> schreef in bericht news:45caaaa3@news.povray.org...
>>> of
>>> DDR RAM.
>>> bit
> Lance.
Neither did I register a crash. Rendered smoothly. 4th row, 4th block takes
longer that's all.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> DDR RAM.
Does this problem still occur with the current beta? I did analyse the dump
you provided but it doesn't have enough information to really be sure of the
cause; if it still happens with beta 20a I'd want to get you a debug compile
so the dump is more detailed.
regards,
-- Chris
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> dump
> the
> compile
> regards,
> -- Chris
I have just re-run the test with the same files... It fails consistantly
with 3.7Beta20, both SSE2 and standard build. But works consitantly with
3.7Beta20a, both builds!
Many thanks
Rarius
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
