POV-Ray : Newsgroups : povray.beta-test : media will be (or is) changed? Server Time
12 Nov 2026 05:38:34 EST (-0500)
  media will be (or is) changed? (Message 1 to 5 of 5)
Subject: media will be (or is) changed?
Date: 13 Jun 2005 06:48:07
Message: <42ad6467@news.povray.org>
I read that something is still being done about media and (alpha)
transparency, and there was talk of the defaults last month, but very little
said lately.
There's obviously a change between 3.6.1 and 3.7 beta 5a which makes media
darker now. Thought it a good idea to post a message here before the current
beta expires. Maybe it's already being dealt with, but I didn't want to let
it go without telling of it myself.
Comparison renderings of the file scenes\interior\media\micro.pov posted to
povray.beta-test.binaries.
Bob Hughes
Subject: Re: media will be (or is) changed?
Date: 13 Jun 2005 11:20:00
Message: <web.42ada38cdb562bc76a3607400@news.povray.org>
"Bob Hughes" <bob### [at] charternet> wrote:
> Comparison renderings of the file scenesinteriormediamicro.pov posted to
OTOH, there is a known difference in the way gamma correction is done
between 3.6.1a and 3.7.beta5a. This file renders exactly the same if
assumed_gamma is set at 2.2 instead of 1...
JYR
Date: 13 Jun 2005 14:00:12
Message: <42adc9ac$1@news.povray.org>
"JYR" <jyr### [at] hotmailcom> wrote in message
news:web.42ada38cdb562bc76a3607400@news.povray.org...
Okay, I see now that using assumed_gamma 2.2 in version 3.6 did make
micro.pov look the same for both versions.
However, something is still wrong. I was trying my own scene file in 3.7
beta when I needed to go back to v3.6, for animation because the beta 5a
still isn't able to animate.
Making the assumed_gamma change, as you suggested, did not correct the media
appearance. I'm seeing an oversaturation of the media. Since I was making
this media-filled object in 3.7 it only looks correct there. Only conclusion
I can make is that something isn't handling the media in the same way
between the two versions.
The clue might be that the density is greater than 1, and now, after
checking with it set to only rgb <1,1,1> I see it seems to fix the look of
it.
Could density be getting clipped in some way in 3.7 beta 5a?
Bob Hughes
Date: 13 Jun 2005 14:16:34
Message: <42adcd82$1@news.povray.org>
> darker now.
This is still the same bug that was initially listed.  Nothing has changed
in this regard, it is still a bug.
	Thorsten
Date: 13 Jun 2005 14:24:09
Message: <42adcf49$1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:42adcd82$1@news.povray.org...
>> media darker now.
Okay, thanks. While reading about media problems from earlier I thought this
might be different somehow.
Bob Hughes
