POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.7 beta 5 available Server Time
12 Nov 2026 05:38:32 EST (-0500)
  POV-Ray v3.7 beta 5 available (Message 1 to 18 of 18)
Subject: POV-Ray v3.7 beta 5 available
Date: 19 May 2005 14:19:51
Message: <428cd8c7@news.povray.org>
POV-Ray 3.7.beta.5 is available from http://www.povray.org/beta/.
This beta is currently for the Windows platform only and includes standard,
SSE2, and 64-bit binaries.
Note: to view an original bug report, prefix the message ID with the URL
http://news.povray.org/. For example, to read <42765ef3$1@news.povray.org>,
visit http://news.povray.org/<42765ef3$1@news.povray.org>. The '<' and '>'
are optional (if using a shell you may want to omit them).
The following features are not supported but will be added prior to release
  o Animation.
  o Radiosity.
  o Dispersion.
  o Mosaic preview.
  o Light and vista buffers. These may replaced with a more efficient system.
  o Ability to choose block size allocated to threads.
  o Resume render (a.k.a. 'continue').
  o Windows rerun dialog and statistics.
  o Redirecting text message output to files.
Known issues which will be fixed
  o There is an issue with media and transparency. See
    <42769324$1@news.povray.org>.
  o The windows editor does not always detect new files as type 'povray'.
  o Text layout of windows message page not yet finished (e.g. no wrapping,
    early wrapping).
  o There are memory leaks, and memory tracking is not yet complete.
  o In many cases speed is not as good as 3.6.
  o Photon support is not yet completed.
  o There are some differences in the way gamma correction works.
  o Anti-aliasing method 2 currently takes more samples than in version 3.6
    and earlier.
Changes between 3.7.beta.4 and 3.7.beta.5
Fixed a photon building issue that caused progressive slowdown.
Fixed scattering media problem reported in <427ca163@news.povray.org>.
  (This also fixes <427c0121@news.povray.org>).
Parser now honors Split_Unions and Remove_Bounds options.
Fixed lathe artifacts bug reported in <427c0f95@news.povray.org>.
Fixed no_image and no_reflection issues reported in
  <427c1900@news.povray.org>.
Fixed area light orient issue reported in <427c14ef@news.povray.org>.
Fixed issue where a new clip statement would overwrite a previous one rather
  than appending to it.
Fixed speed issue with quadrics by reverting to old bbox calculation method.
Fixed a swathe of memory leaks.
Changes between 3.7.beta.3 and 3.7.beta.4
Fixed indexed PNG alpha problem reported in <42765ef3$1@news.povray.org>.
Fix area light problem reported in <427a3fa5$1@news.povray.org>.
Fixed crash during trace of lathe reported in <42796797@news.povray.org>.
Improved handling of cancel/pause render.
Fixed max_trace_level calculation and display (see
  <42769105@news.povray.org>).
Fixed image memory leak.
Fixed speed issues reported in <42769f6d@news.povray.org>.
Fixed shadow problem mentioned in <42769f6d@news.povray.org>.
Fixed sphere_sweep bug reported in <42773e51@news.povray.org>.
Fixed 'inverting pre-declared union' crash reported in
  <42769b59@news.povray.org>.
Fixed focal blur issue.
Fixed omnimax camera bug reported in <42775c1b$1@news.povray.org>, plus
  several other related camera issues.
Fixed facets pattern crash reported in <42773fab$1@news.povray.org>.
Changes between 3.7.beta.2 and 3.7.beta.3
Partial render (start col/row etc) now works
Fixed CSG merge issue reported in <42645c3b@news.povray.org>.
Added warning and better progress reporting to photons.
Some hollow media fixes.
Re-enabled alpha display in render window for windows port.
Fixed alpha bug reported in <web.426402d627a031d914107e060@news.povray.org>
Fixed no_image bug from <web.426402d627a031d914107e060@news.povray.org>
Changed default bounding threshold back to 3 as per v3.6.
Fixed alpha inversion bug in BMP, Targa, and PNG file reading/writing.
Fixed crash mentioned in <42689685@news.povray.org>.
Fixed noise generator default issue reported in <426898db@news.povray.org>.
Fixed irid problem reported in <42680b39@news.povray.org>.
Fix for area light problem from Massimo Valentini.
Made quick_colour work as it should.
Changes between 3.7.beta.1 and 3.7.beta.2
CSG should now work properly
Problem with too many recursions when rendering shadows fixed
I/O restrictions should now work
Fixed recursion bug in renderer
Initialise photon variables
Restore ability to open error file in editor (note: column number not always
  correct).
Fixes no-display crash
Fixes image closing bug
Tweak to some radiosity local vars
Fixes rendering area bug
Fixes AA method 2 brightness issue
Add output file type '+FB' (bmp).
Add 'bmp' token to parser.
Fix for BMP reading.
File output defaults to on.
Fix render quality options output.
Change references to 'CPU(s)' to 'thread(s)'.
Update render time output to include fractional seconds.
Fix crash reported in <4263125b@news.povray.org> and one related bug.
Intentional changes for POV-Ray 3.7
The version directive and command-line setting no longer provide compati-
bility  with most rendering bugs in versions prior to POV-Ray 3.5. However,
compatibility with the scene language is provided for scenes as old as POV-
Ray 1.0 just as in all previous versions of POV-Ray. Nevertheless, we
strongly recommend you update scenes at least to POV-Ray 3.5 syntax if you
plan to use them in future versions of POV-Ray.
This version uses multi-threaded rendering by default. The ability to render
in more than one thread is primarily of use to those users who have SMP
machines (i.e. more than one CPU). There have been reports of benefits for
users of hyperthreading systems, particularly with higher thread counts (e.g.
16 threads).
You can render in only one thread by using the '/THREADS 1' switch in the
Windows version. Note that parsing and photon building will only use one
thread no matter how many are specified. However photon scenes will benefit
from multiple threads once photon building has completed.
Subject: Re: POV-Ray v3.7 beta 5 available
Date: 19 May 2005 20:24:01
Message: <428d2e21@news.povray.org>
I am having problems rendering many scenes.
  For example with scenes\advanced\skyvase.pov it doesn't seem to be
able to pass the parsing stage. It just parses 25K tokens and then
sits there doing nothing.
  The same happens with scenes\advanced\wineglass.pov,
scenes\advanced\chess2.pov and others.
  When I try to render scenes\advanced\sunsethf.pov it gives several
times the error message "Fatal error in renderer: Invalid parameter."
and stops. The same happens with scenes\advanced\bwstripe.pov.
Date: 19 May 2005 21:13:54
Message: <428d39d2$1@news.povray.org>
ups, yes, I see. I know what this is and will upload a fixed version later today.
-- Chris
Date: 20 May 2005 00:35:10
Message: <428d68fe$1@news.povray.org>
"Chris Cason" <nos### [at] deletethispovrayorg> wrote in message
news:428d39d2$1@news.povray.org...
> today.
> -- Chris
Not sure if I have the most recent file. It is dated 5/20 so I presumed I
happened upon the fixed beta 5. Maybe not, either way I thought I'd mention
this:
I can render the chess2.pov okay, although the other files, stated above,
all show that repeated error (3 times) Warp told of.
Date: 20 May 2005 04:19:35
Message: <428d9d97@news.povray.org>
Beta 5a is now available, which fixes a problem that would cause some scenes
to fail to render with an 'invalid parameter' error.
-- Chris
Date: 20 May 2005 09:38:29
Message: <428de855@news.povray.org>
Now sunsethf.pov starts rendering but it hangs when the render gets
to the heightfield/water/watever.
  skyvase and chess2 still hang at parsing stage.
Date: 20 May 2005 12:15:55
Message: <428e0d3b$1@news.povray.org>
news:428de855@news.povray.org...
Ahh, so I didn't have an updated beta 5 before, eh?
Well, 5a seems to be rendering skyvase and chess2 okay here.
Although, sunsethf rendering does appear to be freezing up without errors or
anything seeming wrong. I tried changing the png used for the HF to a jpeg
and same occurs.
Something else... I gave AA a try on the chess2 render and it slowed by over
5 times and message window shows AA being used instead of ignored due to
focal blur being used.
As to the other discrepencies between Warp's observations and mine I'll give
my system info if that might be a reason.
POV for Windows beta 5a (not SSE2 or 64 bit)
Windows XP HE SP2
P4-M 2.0 GHz
1024 MB DDR SDRAM
Date: 20 May 2005 13:23:53
Message: <428e1d29$1@news.povray.org>
That is correct, the limitation that focal blur and AA cannot be combined
has been removed from POV-Ray 3.7 :-)
Naturally, with both enabled rendering gets reaaaaaaaaly slow.  But quality
of focal blur images should be better in general now.  If you don#t want the
slowdown, just disable AA and everything should basically work like in 3.6 .
	Thorsten
Date: 20 May 2005 13:43:12
Message: <428e21b0$1@news.povray.org>
this is a different bug, now fixed, thanks.
I can't replicate this. Both parse and render fine here.
-- Chris
Date: 20 May 2005 13:55:09
Message: <428e247d@news.povray.org>
  Did you try with the sse2 binary?
  My mistake, I forgot to check if it could be a problem with that
binary and didn't test it with the normal binary. The latter renders
them ok but the sse2 binary hangs at parsing time.
Date: 20 May 2005 14:47:05
Message: <428e30a9@news.povray.org>
> combined has been removed from POV-Ray 3.7 :-)
Nice :)
Date: 20 May 2005 20:47:11
Message: <428e850f$1@news.povray.org>
Cool! So does that mean that if you have AA enabled, it will always send the
rays through the sample point of the image plane, but if you don't, it will
send the rays through a random point in the pixel on the image plane, as in
3.6? Or with AA disabled, will it now send the rays through the center of
the pixel?
It would be great if this were coupled with the ability to clip before
anti-aliasing, so that you could clip after focal blur but before AA,
creating well-anti-aliased bright blurs of light. =)
 - Slime
 [ http://www.slimeland.com/ ]
Date: 20 May 2005 23:49:50
Message: <428eafde$1@news.povray.org>
I've found that the wineglass.pov file might at first appear to render okay
in the regular executable but I noticed it doesn't have the parts of the
glass the way they should be. Apparently the QCone_Y, being a quadric, isn't
able to be used right in the CSG intersection. In fact, while I made changes
to the top of the glass it somehow affected the bottom, completely different
declares. Very odd thing.
To see the glass parts you might want to change the glass texture to be
opaque. I replaced that with pigment { rgb 1 }.
Date: 21 May 2005 00:12:14
Message: <428eb51e$1@news.povray.org>
Another problem but also a bit of answer about the sunsethf.pov not
rendering. It's the waves normal. Discovered this reason when trying to find
out why mist.pov wasn't rendering either, it uses the ripples normal.
Date: 21 May 2005 15:56:33
Message: <428f9271$1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:428e1d29$1@news.povray.org...
>> over 5 times and message window shows AA being used instead of ignored
>> due to focal blur being used.
Thanks Thorsten. News to me, too.
Now that I've checked on it more, by rendering the file focalblur.pov in
scenes\camera, at first I thought that the AA was being done in a unique
way. Which, perhaps it is. It's like it affects the blurring regions
inversely and exponentially. Then I realized it might need more 'depth' or
larger AA sampling array, so I used +r5 and that cleaned up the out-of-focus
parts great.
For example, if +a0.1 is used alone it looks disasterous, almost like a
defective AA. Increase the ray depth and it seems able to encompass the
blur.
Better yet, AA method 2 is superb for this. I tried +a0.3 +r1 +am2 and
improved the non-AA rendering without a slowdown. In fact, I'd suggest
everyone not even use method 1.
Date: 21 May 2005 16:30:31
Message: <428f9a67@news.povray.org>
  Perhaps method 2 should be made the default when using focal blur?
Date: 21 May 2005 21:48:24
Message: <428fe4e8$1@news.povray.org>
> blur.
Isn't there an AA bug for method 1 in the current beta? Or was that fixed?
 - Slime
Date: 22 May 2005 07:55:24
Message: <4290732b@news.povray.org>
  It seems to still be there. It might indeed be the reason why he is
getting an awful result in that focal blur scene.
