POV-Ray : Newsgroups : povray.beta-test : POV-Ray 3.7.beta.4 available Server Time
1 Jul 2026 05:53:17 EDT (-0400)
  POV-Ray 3.7.beta.4 available (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: POV-Ray 3.7.beta.4 available
Date: 6 May 2005 09:56:32
Message: <427b7790$1@news.povray.org>
Chris Cason wrote:
Area Lights are fixed: Yay!
~Mike
Things! Billions of them!
Date: 6 May 2005 11:04:33
Message: <427b8781@news.povray.org>
There's a speed-related oddity with one scene:
  scenes\advanced\ionic5\ionic5.pov at 640x480 +a +am2 takes 18 seconds
to render with pov3.6 and almost 4 minutes with pov3.7beta4.
  Other scenes seem to render in a more comparable time (equal or even
faster than pov3.6), so this seems to be a rather unique case.
Date: 6 May 2005 15:12:28
Message: <427bc19c$1@news.povray.org>
news:427b8781@news.povray.org...
Look at the stats for quadric tests and succeeded percentage. It's way off.
I'm seeing somewhere around 40% succeeded from a much lower number of ray
tests in 3.6, yet in 3.7 beta 4 it has over 92 million tests with a mere 5%
or so succeeded.
On my computer the render time is even wider than yours was, being 14
seconds for 3.6 and 6 minutes 10 seconds for the beta.
Bob Hughes
Date: 6 May 2005 15:25:25
Message: <427bc4a5$1@news.povray.org>
Yoiks! Sorry, that was using default AA, not the method 2 as you had done.
Still was similar results; that is, wider span of time and this time it had
over one billion tests with the same kind of percentage succeeded, or 5.78%
compared with over 38% in the 3.6 version.
Date: 7 May 2005 09:41:50
Message: <427cc59e$1@news.povray.org>
The beta doesn't have vista buffers. (Or light buffers.) Is this the
cause? Maybe?
Date: 7 May 2005 09:53:04
Message: <427cc840$1@news.povray.org>
> cause? Maybe?
No.  Essentially vista and light buffers hardly ever give just 1% speed
increase, if any at all.
	Thorsten
Date: 7 May 2005 09:57:10
Message: <427cc936$1@news.povray.org>
>> cause? Maybe?
OK. Was just a thought...
Date: 10 May 2005 02:31:18
Message: <42805536$1@news.povray.org>
this is fixed, thanks.
unfortunately to fix it I had to restore the old (buggy) clipping behaviour
of quadrics, however as this has been present for many years it should not be
a major problem.
-- Chris
Date: 10 May 2005 04:32:44
Message: <428071ac@news.povray.org>
> a major problem.
  I'm not aware of such bug. Could you explain in more detail?
Date: 10 May 2005 15:15:51
Message: <42810867@news.povray.org>
not be
>>>> a major problem.
The issue is that a quadric (not all types, just some) that is clipped_by
another object will potentially return a smaller bounding box than either
that of the object or its original clipping region. This is particularly
evident if you render a scene with and without bounding slabs. Here's an example:
#include "textures.inc"
global_settings { assumed_gamma 2.2 }
   location  <0, 50, -20>
   direction <0, 0,  10>
   look_at   <0, 0,   0>
light_source { <0, 10, -20> color White*2 shadowless }
plane { z, 10 pigment {checker color White color rgb <1,.8,.8>}hollow on }
#declare UnitBox = box { <-1, -1, -1>, <1, 1, 1> }
quadric {
   <-1, 0, 1>, <0, 0, 0>, <0, 1, 0>, 0
   pigment { Blue }
   finish { ambient 0.1 }
   clipped_by{object{UnitBox scale <2,2,2>}}
#if (1)
box
  <-1.4142135, -2.0000000, -1.4142135>
  <1.4142135, 2.0000000, 1.4142135>
  pigment { rgbft <1,0,0,0,0.75> }
object
  UnitBox
  scale 2
  pigment { rgbft <0,1,0,0,0.75> }
If you render this in v3.6 you will get a quadric that is smaller than the
clipping box in some dimensions. If you remove the clipped_by you will see
that in fact it should extend to the edges. 3.7 beta 4 handles the above
scene OK (however beta 5 will revert to the old behaviour unless it's fixed).
The green box represents the defined clipping object and the red box is
what the internal bbox calculations returned for the bounding volume once
the clipped_by had been applied.
If you turn off the two bottom objects via the #if (0) or just add -mb to the
command-line you'll see the quadric properly contained within the clipping
region.
The issue is caused by an optimization in the bounding box calculations that
attempts - for a number of different types of quadric - to determine, given a
defined clipping region in one direction (e.g. two planes), the maximum
extent of the quadric in another direction. It also does this even if the
clipping region is finite (e.g. the box given above).
The problem is that it generates this estimate (at least in this example)
with an assumed z of 0.0, ignoring the fact that it extends beyond the
calculated x value of 1.4142135 at z = -1.0 or +1.0 (and/or elsewhere, I
didn't analyze this thoroughly).
You can see this more clearly by moving the camera to <0, 50, 0> and
rendering with the boxes turned on, and with and without -mb.
While I could just return the clipping region rather than allowing the code
to optimize it this way (and in fact I made a small improvement in that area;
previously if the mixed terms were non-zero it just returned without setting
the bbox at all, now at least it will set it to the clip), the issue is that
often (e.g. in the ionic example scene you gave), the clip is performed with
planes and as such the object will still be infinite in some direction(s)
unless the calculations are done. It would appear a number of scenes depend
on the old behaviour and do not use finite clip regions (which is what my
changes had assumed).
The proper fix would be to make a more thorough estimation of extent for each
of the covered quadric types (cone, hyperboloid and paraboloid, in each of x,
y, and z axes) and return a more correct bbox.
-- Chris
