POV-Ray : Newsgroups : povray.beta-test : POV-Ray 3.7.beta.3 available (fix) Server Time
12 Nov 2026 05:46:34 EST (-0500)
  POV-Ray 3.7.beta.3 available (fix) (Message 1 to 12 of 12)
Subject: POV-Ray 3.7.beta.3 available (fix)
Date: 3 May 2005 05:45:03
Message: <4277481f$1@news.povray.org>
Users of the non-SSE2 build (pvengine.exe) please note that I mistakenly
included a non-optimized version in the archive. The zip file now available
at http://www.povray.org/beta/ includes the correct EXE.
-- Chris
Subject: Re: POV-Ray 3.7.beta.3 available (fix)
Date: 3 May 2005 11:51:22
Message: <pan.2005.05.03.15.51.22.816773@nospam.com>
Just out of curiosity, is there a plan for a beta of a Linux build?
Kinda itching to get my hands on it to start playing with it (particularly
interested in MP support). :-)
Jim
Date: 4 May 2005 09:16:02
Message: <4278cb12@news.povray.org>
builds for other platforms will most likely wait until the core code settles
down. the changes necessary to get POV to the state where we can support SMP
properly (we didn't want to do a hack) are massive, as will become clear when
the source code is released. apart from the internal re-structuring needed
for threading we have both logically and physically separated the front and
back ends (frontend being the UI, backend being the renderer), which has
changed the way that the platform-specific code integrates. As this work is
not yet complete, it's probably better that we get it all done to avoid
duplication of effort before other platforms follow.
sorry that's not much of an answer but it's the best I can give right now :-(
-- Chris
Date: 4 May 2005 12:18:18
Message: <pan.2005.05.04.16.18.17.565504@nospam.com>
Kinda what I expected, really - and if it were me making the decision, I
probably would do the same thing....Still, I had to ask. :-)
Thanks, and look forward to seeing it on Linux.  I'm quite interested to
see how long it takes to render the "Blueblob" post from p.b.i on a DP
system at the settings I've used - right now, it's around 160 hours or so
and about 33% done...
Jim
Date: 4 May 2005 13:28:58
Message: <4279065a@news.povray.org>
That's what happens when you use AA depth 9 =)
I hope that's method 1 and not 2.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 4 May 2005 16:09:08
Message: <pan.2005.05.04.20.09.07.953457@nospam.com>
>> so and about 33% done...
It's method 2, actually - mostly a curiousity thing than anything -
machine with one processor sitting idle most of the time - it's weird
having a render run at niceness -20 and still being able to play
armagetronad with the first-person view/highest quality/highest
resolution/all reflections turned on. :-)
Jim
Date: 4 May 2005 16:19:10
Message: <42792e3e@news.povray.org>
Do you know that method 2 with depth 9 is a possible 263,169 samples per
pixel? =)
Of course, often you'll get much fewer than that... but even so, I doubt
you'd ever notice a difference between depth 3 and 4, let alone 9.
 - Slime
Date: 4 May 2005 16:23:15
Message: <42792f33@news.povray.org>
> pixel? =)
  According to my experience method 2 gives higher quality results at
bigger threshold values than method 1.
  Using a very high number of samples is reasonable only if there are
*tons* of subpixel-sized details. This is usually rare.
Date: 4 May 2005 16:27:35
Message: <42793037$1@news.povray.org>
Infinite checkered plane has infinitely small squares.
But they cover such a *tiny* area of the surface...
Similar situation with (say) reflections on a cylindrical shape. Lots of
small details; you definitely need good AA for it to look right. But I
don't think I have *ever* been above depth 4...
It would, of course, be trivial to do a back to back compare to see the
results...
Date: 4 May 2005 16:47:28
Message: <pan.2005.05.04.20.47.28.214263@nospam.com>
> pixel? =)
Actually, I didn't know that. :-)
Possibly - I may do one that's a depth 3/4 (heck, that'd give the other
processor something to do) to compare the results. :-)
Jim
Date: 5 May 2005 03:29:22
Message: <MPG.1ce378728f158f97989d63@news.povray.org>
In article <4278cb12@news.povray.org>, nospam-
new### [at] deletethispovrayorg says...
Would this imply that it may then become possible to use a more simple
front end or even create one as a module that could one Windows be an
ActiveX control or a Python app on Linux, etc? In other words, strip off
the existing front end and make one that can be tied into another
application, as long as appropriate information is provided to state that
the backend is in fact POVRay when its first loaded? I mean the plugin
system that is available and programs like Moray use is nice, but I felt
it always did leave a bit to be desired in some cases.
void main () {
  If Schrödingers_cat is alive
    call functional_code()
  else
    call crash_windows();
Date: 5 May 2005 04:15:01
Message: <d5ckfr$2s5$1@chho.imagico.de>
First of all a dynamically linked frontend and a stripped-down backend
would violate the spirit and the letter of the current license - this
has been explaind in depth in the past including the lack of possibility
to simply change the license.
Apart from that what you wrote does not mention what you think would be
possible by dynamically linking the POV-Ray backend with a different app
that is not possible to do via stdin and stdout of the official version.
  Note i am not saying such things don't exist but you have not
mentioned any.  One thing i could think of is the possibility to pause
and resume a render (without stopping it) but this would be quite simple
to add by having POV-Ray interpret pause and resume commands from stdin.
BTW i just announced a program in tools.general that demonstrates how
you can integrate POV-Ray into another program using these means.
Last updated 03 May. 2005 _____./\/^>_*_<^\/\.______
Date: 5 May 2005 17:32:22
Message: <427a90e6$1@news.povray.org>
Well, it's always been *possible* to do this, assuming one was willing to
modify the source :). However, if you mean, "will it be easier to do this",
the answer is that if we decide to make this interface available it would
indeed be easier.
however at this point I can't comment further on our plans along these lines.
-- Chris
Date: 5 May 2005 19:19:43
Message: <MPG.1ce45780cf764cf8989d64@news.povray.org>
In article <d5ckfr$2s5$1@chho.imagico.de>, chr### [at] gmxde says...
Well. The one advantage having something closer to a library than a
stdin/stdout system has is being able to easily drop it into another
application. You don't need to know as much about how and why it works to
use a library. At worst you might need a wrapper for the language you
plan to use. Stdin and Stdout aren't as universal as they should be, if
they where people wouldn't have developed DCOM, Corba or other
implementations for a different method of linking stuff together.
Of course, most of the problem wasn't just having POVRay sitting
someplace else chugging away in its own window, so much as the lack of
anyone trying to find out what all of the interfaces where good for and
my almost nonexistent skill in C. Yeah, its possible to create a wrapper,
etc. for 'other' languages, but if you don't comprehend the way they work
in C you are out of luck with the rest too. Decoupling the frontend and
backend means the backend 'could' be more like a library than a full
application, which makes the interface between them less complex, doesn't
require complicated plugins to sit as intermediaries, etc. Sort of the
computer equivalent of interchangeable parts + fewer moving ones that
might break. But that may just be how clueless I am about how any of it
works in the first place. ;)
Hmm. Will take a look.
void main () {
  else
Date: 6 May 2005 03:15:02
Message: <d5f596$2sl$1@chho.imagico.de>
I don't see any concrete example.  Note currently communication of
POV-Ray via stdin and stdout is essentially one-way - the only input it
recognizes is to pause after the render when pause is on and wait for a
keypress.  But this can be changed of course.
> if
In a lot of cases these techniques are simply abused, often simply to
obfuscate the communication (so 3rd parties have difficulties to develop
replacements for one side of the communication, often made waterproof by
using patented techniques in the communication).  But again a concrete
example would be necessary.
Date: 6 May 2005 21:22:34
Message: <MPG.1ce5c5a01edc30e0989d65@news.povray.org>
In article <d5f596$2sl$1@chho.imagico.de>, chr### [at] gmxde says...
Well, I don't write a lot of stuff, but the only real example I can think
of is what Adobe Acrobat Reader does with something like IE. Where just
because the 'file' being viewed is not recognized by the application that
loaded it, doesn't mean it has to show up in a separate application. Same
with imbedded video, etc. It might be nice for instance to add dynamic
graphics, though obviously not animation, to a MUD, by adding some way
for the client to 'imbed' POVRay, not just wait for it to finish then
display the result. This was in fact what I was trying to work out when I
last looked are POVRay integration issues. The fact that the only
existing example where all a) incomplete and didn't use the features I
would need to make it work and b) it was in C, buried the idea. Now, with
Dual-core support, faster machines, etc. its even more reasonable an
idea. After all, a mud deals in text, it could feed a SDL with changes
for time of day, weather, etc. that are part of includes for the MUD +
the SDL for the room being seen to do almost anything. Not a full 3D
environment, but a 'major' jump up from a fixed picture, or worse
multiple pictures for time of days, season, etc. I would love to try it,
but POVRay as it stood tended to make even trying inconvenient. With a
clearer interface, the whole 'visible' part could be stuck into a Lua
based plugin for something like Mushclient on Windows or as some similar
plugin for a client under Linux. To do it currently seems more
complicated than that, but I may simply have even less of a clue what I
am looking at than I know I do. ;) lol
void main () {
  else
