POV-Ray : Newsgroups : povray.beta-test : scenes\interior\media\hollow1.pov oddities (beta2) Server Time
10 Nov 2026 20:39:49 EST (-0500)
  scenes\interior\media\hollow1.pov oddities (beta2) (Message 1 to 11 of 11)
Subject: scenes\interior\media\hollow1.pov oddities (beta2)
Date: 21 Apr 2005 16:34:32
Message: <42680e58@news.povray.org>
Try rendering scenes\interior\media\hollow1.pov in 3.6 and 3.7beta2.
  The former takes a bit over 2 seconds to render in my computer
(640x480 +a0.3 +am2) while the latter takes more than 1 minute and
the result looks completely different.
Subject: Re: scenes\interior\media\hollow1.pov oddities (beta2)
Date: 21 Apr 2005 16:37:37
Message: <42680f11@news.povray.org>
Also try hollo2.pov in the same directory. While the render time is
now more alike, the result is however quite different.
  Is 'hollow' working at all as it should?
Date: 21 Apr 2005 16:52:38
Message: <42681296$1@news.povray.org>
The truth being told,"hollow" does almost nothing in the first place.  And
yes, it works.
	Thorsten
Date: 22 Apr 2005 02:08:18
Message: <426894d2@news.povray.org>
  By the way, how about changing it, at last, to something else?-)
  Perhaps povray could cause a warning about it being deprecated and
suggest that the new keyword should be used instead.
  What the new keyword would be is open to suggestions. My vote goes
for "allow_media", but even I don't think it's perfect.
  (It would also be nice if an object which has an interior block
with a media block inside would have this property turned on by
default. You could then write "allow_media off" if for whatever
reason you want it that way.)
Date: 22 Apr 2005 06:25:08
Message: <4268d104$1@news.povray.org>
> goes for "allow_media", but even I don't think it's perfect.
hollow also affects fog.
Rune
rune|vision:  http://runevision.com
POV-Ray Ring: http://webring.povray.co.uk
Date: 22 Apr 2005 07:21:15
Message: <4268de2b@news.povray.org>
  Fog can be thought as a very special version of media.
Date: 22 Apr 2005 08:52:39
Message: <4268f397$1@news.povray.org>
Well, the problem has two sides.  One is that hollow is used to allow
atmosphere to "leak" into an object.  The other is that it enabled media
contained within an object.  Now, the second "feature" of hollow is fairly
pointless.  If you add media to an object,why would you not want to make it
hollow - because if you don't the media you specified just won't be visible.
The use with atmosphere on the other hand does make some sense.  But not the
way it currently works because right now if you have an object with media
inside, you cannot get rid off the atmosphere inside (well, you can with the
object pattern and CSG operations, but lets not go there).  So yes, now that
it is finally clear what the code does with hollow, we can make a better
judgment about its usefulness.  But I will leave it at that for today...
	Thorsten
Date: 22 Apr 2005 10:28:59
Message: <42690a2b@news.povray.org>
  I think you are right. The current behaviour of 'hollow' is perhaps
a bit awkward and it probably was not thought thoroughly when it was
developed for the first time.
  You are right in that a more proper way of doing it would be that
objects can have their own media regardless of their properties and that
'hollow' (or whatever keyword) only says whether *other* medias and
atmospherical effects get into the object or not.
  In that sense "hollow" is a quite descriptive keyword, after all.
However, as we all know, practice has shown that it causes tons of
confusion to beginners and even not-so-beginners. They will often
think that it has something to do with CSG or how the object is
rendered (not related to any media/fog) even though it naturally
has no effect on those whatsoever.
  "hollow" is at the same time quite descriptive and very confusing
(because in real life hollowness refers to something quite different
than what it means in POV-Ray).
  I still think it should be changed to something else to avoid
confusions.
  How about "allow_atmosphere"?
  Or "blocks_atmosphere on/off"?
Date: 22 Apr 2005 10:34:33
Message: <42690b79$1@news.povray.org>
Agreed.
> confusions.
parent_media? (Since you might put an object inside a large object that
has media...)
Was wondering whether it should be an object modifier or go in the
interior{} block... but than I realised that if you did that, there
would be issues with not being able to replace textures and stuff...
Date: 22 Apr 2005 12:27:01
Message: <426925d5$1@news.povray.org>
I agree with this and have been thinking this for a while.
> confusions.
Wouldn't it be more convenient, for the newbie and the experienced user, if
it were on by default (external media was allowed)? Since it's common to
have multiple large media containers in the same scene and expect the medias
to all appear everywhere within their containers. Then the keyword could be
something like "ignore_external_media" or something.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 29 Apr 2005 14:43:37
Message: <42728059$1@news.povray.org>
this has been fixed (though there may still be some oddities floating around).
thanks,
-- Chris
