POV-Ray : Newsgroups : povray.beta-test : Smooth mesh2 artifacts Server Time
10 Nov 2026 21:13:39 EST (-0500)
  Smooth mesh2 artifacts (Message 1 to 16 of 16)
Subject: Smooth mesh2 artifacts
Date: 28 May 2002 23:19:41
Message: <3cf448cd@news.povray.org>
Lots of people have heard about this problem... I'm not sure if it's been
heavily looked into, but there's definitely a problem with black artifacts
appearing at the edge of smooth meshes.
Anyway, I thought I'd make a formal bug report for it, in hopes that someone
might figure it out and fix it. The following scene, consisting of a mesh
with a single triangle, displays the problem:
 location <0,3,-3>
 look_at 0
light_source {
 <-1,1,-1>*9999
 rgb 1
mesh2 {
 vertex_vectors {
  3,
  -x,x,3*z
 normal_vectors {
  3,
  y,y,y+z // last normal points away from camera, but not *directly* away
 face_indices {
  1,
  <0,1,2>
  pigment {rgb 1}
Pictures will be posted momentarily in p.b-t.b.
RC5, WinXP, 900mhz P3 (i think), 256MB RAM
 - Slime
[ http://www.slimeland.com/ ]
Subject: Re: Smooth mesh2 artifacts
Date: 29 May 2002 02:50:11
Message: <3cf47a23@news.povray.org>
In article <3cf448cd@news.povray.org> , "Slime" <slm### [at] slimelandcom> wrote:
Sorry, but RTFM for double_illuminate!
    Thorsten
Date: 29 May 2002 03:01:19
Message: <3cf47cbf@news.povray.org>
I was under the impression that double_illuminate was merely a workaround.
It looks to me like there's something physically unrealistic here that
deserves some attention. If it's not going to be fixed before the 3.5
release, then that's alright, but if it *is* a bug, then it should at least
be recognized as so.
In the meantime, thanks for the tip.
 - Slime
Date: 29 May 2002 03:38:01
Message: <3cf48559@news.povray.org>
In article <3cf47cbf@news.povray.org> , "Slime" <slm### [at] slimelandcom> wrote:
No, you simply create a normal vector that point in the wrong direction.
POV-Ray allows you to specify any garbage as normal vector while normal
modeling software usually protects you from creating such garbage.
Add this to your scene to see the normal vectors.  To help you see the problem
with the normal vector there is a small yellow "vector" that is perpendicular
to the blue "vector":
cylinder
 -x, -x + y, 0.1
  pigment {red 1}
cylinder
 x, x + y, 0.1
  pigment {green 1}
cylinder
 3*z, 3*z + y+z, 0.1
  pigment {blue 1}
cylinder
 3*z, 3*z + y+z, 0.025
  pigment {red 1 green 1}
 translate -3*z
 rotate x*-90
 translate 3*z
e-mail: tho### [at] trfde
Date: 29 May 2002 09:23:10
Message: <3cf4d63e@news.povray.org>
This is the same problem I noticed some time ago. It also happens with
smooth heightfields for the exact same reason.
  The problem is that the rendering engine assumes that objects return
the *true* normal vector for the given point in their surface. For an object
to render correctly, it *must* give the exact normal vector (ie. a vector
which is exactly perpendicular to the surface at that point).
  Smooth meshes and heightfields don't do this. They return normal vectors
which are not perpendicular to the actual surface. This causes errors in the
rendering.
  What happens is that when the rendering engine shoots a ray and it hits
the surface of an object, the engine asks the object "what's the normal vector
at this point in your surface?".
  Now, if the angle between the returned normal vector and the ray vector
is less than 90 degrees (that is, the normal vector points away from the
point of view of the starting point of the ray), then the engine reverses
the returned normal vector. This is essential for the lighting to work
properly (if the normal is not reversed in this case, you would get all kind
of errors in lighting, ie. surfaces which are illuminated from behind when
they shouldn't, or surface which are not illuminated even though they are
facing a light source).
  This assumes that the normal vector returned by the object is a *true*
normal vector, and it works perfectly when this is so.
  However, if the object returns an erroneous normal vector, ie. a vector
which is not perpendicular to the surface, rendering errors can occur.
  Smooth triangles and heightfields do this, and the price to pay are the
artifacts in the lighting in certain situations.
  The artifact is produced when the *true* normal vector would have an angle
larger than 90 degrees with the ray, but the the actual vector returned by
the object has an angle smaller than 90 degrees with the ray.
  In this case the rendering engine reverses the normal vector even though
it shouldn't. This is because it assumes that it's the true normal vector
when in fact it isn't.
  You can get rid of the artifacts by making the mesh double_illuminated.
When a surface is double_illuminated, it doesn't matter which way its normal
points - it will always be illuminated regardless of which side the light
source is.
  Of course it shouldn't matter that the mesh is now illuminated in both
sides. If this is a problem, then there's little we can do.
  Another place where this problem can be seen is when using the slope pattern,
which also uses the normal vector to calculate the value of the pattern at
a certain point. If the normal is reversed when it shouldn't, the wrong
slope is calculated as well. double_illuminate will not fix this because it
is only related to lighting, not to patterns.
  If you are having this problem in a smooth heightfield, the solution is
to mirror the color_map (or whatever map you are using) around 0.5. This way
it doesn't matter if the normal is reversed.
  Perhaps I should add this text to the povQandA.
Date: 29 May 2002 10:41:33
Message: <3cf4e89c@news.povray.org>
  Done:
http://iki.fi/warp/povQandT/SmoothTriangleArtifact/
Date: 29 May 2002 10:53:43
Message: <3cf4eb77$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> a écrit dans le message de news:
3cf4e89c@news.povray.org...
You could add that the double_illuminate trick may cause bright artifacts on
the borders of the object left in shadow, even for closed meshes. They can
be quite visible too but they are also, fortunately, usually easier to fix
with a paint program than the black ones...
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 29 May 2002 11:02:43
Message: <3cf4ed93$1@news.povray.org>
"Slime" <slm### [at] slimelandcom> a écrit dans le message de news:
3cf47cbf@news.povray.org...
FYI, Christophe Bouffartigue has developed a patch that seems to fix the
problem for Megapov. I haven't tested it but it seems to work quite well.
You can have a look there (see the testmesh anims) and the wpovman072 file.
http://tofbouf.free.fr/temp/
G.
- Posters
Date: 29 May 2002 12:41:18
Message: <3cf504ad@news.povray.org>
  Only if you are using no_shadow to get rid of the shadow line artifact... :P
Date: 29 May 2002 12:52:26
Message: <3cf50749@news.povray.org>
  I added a note about that and also added a note to the shadow line artifact
page about this artifact.
Date: 29 May 2002 16:32:56
Message: <3cf53af8@news.povray.org>
object
Yeah, I was thinking last night and realized what was happening internally.
So, would it be too difficult if, when doing the test to see if the normal
vector should be flipped around, instead of using the perturbed normal, it
used the actual normal? At least with smoothed triangles?
 - Slime
Date: 29 May 2002 17:24:03
Message: <3cf546f3@news.povray.org>
  Yes, it would be difficult with the current implementation. I have looked
at the code myself.
  Hopefully it will be fixed in pov4, as rewriting the whole engine will
allow to take into account this kind of things.
Date: 29 May 2002 17:31:56
Message: <3cf548cc$1@news.povray.org>
looked
> at the code myself.
Oh, alright. =)
I can't wait until the source comes out for 3.5...
 - Slime
Date: 29 May 2002 19:33:33
Message: <3cf5654d@news.povray.org>
> looked
>> at the code myself.
> Oh, alright. =)
  Of course "difficult" is not the same as "impossible".
  It should be possible to achieve the desired effect by making some ugly
hack. When I looked at the code I tried to find a clean and nice way of
doing it, but due to the structure of the code I didn't find any.
  One ugly hack would be making the triangle, mesh and heightfield objects
to write a flag to a global variable (forgive me for swearing in public)
stating that the normal they returned was not the true normal. The
normal-inverting code would first look at this flag, and if the flag states
that the normal was perturbed by the object itself and probably isn't the
true normal, then the code would request the true normal from the object.
Then it would make the decision whether to invert the first normal or not
according to the true normal.
  This of course causes a slight overhead in the rendering of these objects
as they will now have to return two normal vectors instead of one, but this
overhead might be irrelevant.
  Fortunately the "return the true normal" function would have to be
implemented only for these three objects, saving a lot of writing work,
I think.
Date: 29 May 2002 22:16:23
Message: <3cf58b77@news.povray.org>
Yeah. I imagine the code that does the normal checking is just really far
separated from the code specific to height fields and meshes. It's cool,
I'll deal. =)
Actually, I'm waiting for the source code for other reasons too... for
instance, i'm *dying* to be able to create a camera through six functions of
u and v: three functions would determine the camera's position as a functoin
of u and v, and three of them determine the direction the camera is looking
in. (three functions for each in order to create an <x,y,z> vector.)
I dunno. Lots of stuff I'm excited to look into.
 - Slime
Date: 30 May 2002 07:30:24
Message: <3cf60d50$1@news.povray.org>
3cf5654d@news.povray.org...
Looks like I have to post this again :
You can have a look there (see the testmesh anims) and at the wpovman072 and
srcupd72 file.
G.
- Posters
