POV-Ray : Newsgroups : povray.beta-test : [doc] concat with one parameter Server Time
10 Nov 2026 21:19:56 EST (-0500)
  [doc] concat with one parameter (Message 1 to 16 of 16)
Subject: [doc] concat with one parameter
Date: 21 May 2002 05:13:24
Message: <3cea0fb4@news.povray.org>
RC5 for Unix
#debug concat("POV")
works fine, but the doc says:
concat(S1,S2,...)
IMO the doc and not the function should be changed because this is a useful
feature to give an RVALUE (and not an IDENTIFIER) as parameter to a macro.
Or is there a better (shorter) way?
Felix Wiemann
Subject: Re: [doc] concat with one parameter
Date: 21 May 2002 06:36:28
Message: <3cea232b@news.povray.org>
  I don't understand why you can't give the value directly.
Date: 21 May 2002 11:07:48
Message: <3cea62c4@news.povray.org>
If the string is modified inside the macro but the original string is
needed after execution, it's necessary to use concat. For example:
#macro M(S)
        #debug "\n"  // linefeed
        #debug S     // "POV-Ray"
        #debug "\n"
        #declare S = substr(S, 5, 3)  // S = "Ray"
        #debug S     // "Ray"
        #debug "\n"
#declare S = "POV-Ray"
M(concat(S))
#debug substr(S, 1, 3)  // "POV" or "Ray"
The output is:
POV-Ray
Ray
POV
but if you change M(concat(S)) to M(S) the output is:
POV-Ray
Ray
Ray
Felix Wiemann
Date: 21 May 2002 11:51:57
Message: <pan.2002.05.21.10.54.53.841372.2143@mac.com>
In that case, either the macro is written wrong or you are using it
wrong. The concat() function is for concatenating strings, not making
temporary copies. I don't see any reason to document that use, it is
basically a hack and should be discouraged because it leads to code that
appears to do something other than what it really does.
If you don't want to declare a temporary variable, a macro is a better
solution than misusing the concat() function. Something like:
#macro clonestring(String)
    #local tmpString = String
    tmpString
POV-Ray TAG e-mail: <chr### [at] tagpovrayorg>
WWW: http://homepage.mac.com/chrishuff/
Date: 22 May 2002 07:53:39
Message: <3ceb86c2@news.povray.org>
Where's the problem with concat? It works fine. Aren't POVers (and computer
users in general) known for using a function for something totally
different than it was designed for? And I don't see any possibility that's
as short as concat.
Why?
>     tmpString
> #end
Is much longer. So not better but worse.
Felix Wiemann
Date: 22 May 2002 09:22:18
Message: <3ceb9b89@news.povray.org>
  Have you tried just enclosing the string in parentheses?
>>     tmpString
>> #end
  Perhaps you should learn some basics of (modular) programming.
  "It's much longer" is a really poor excuse for making bad code.
  You have to write one #local more - so what? The alternative is to write
an extra 'concat()' several times, which makes the code quite obfuscated
and longer.
Date: 22 May 2002 09:46:44
Message: <3ceba144@news.povray.org>
What do you mean? Enclose the variable name in parentheses? That of course
won't work. Note that the string itself is normally not available before
parsing so it's necessary to use a variable.
Hmmm... The SDL is actually not very modularized. It's more a description
language than a programming language. Macros and functions are possible but
structures or even classes aren't supported. When I want to write a program
for POV-Ray, I write a C++ program which generates SDL code.
> and longer.
OK, normally it's better to write well understandable code, but I'm
currently working on my signature, so in this case it's very important to
save even a few bytes.
And IMHO it's not a problem to understand what concat with one parameter
does.
Felix Wiemann
Date: 22 May 2002 09:53:48
Message: <3ceba2ec@news.povray.org>
  I said "string", not "variable name".
  When you call your macro, do: MyMacro(("The string"))
  That doesn't mean you shouldn't make your code as modular as the language
allows.
Date: 22 May 2002 14:05:54
Message: <pan.2002.05.22.13.08.54.207328.2163@mac.com>
> computer users in general) known for using a function for something
> totally different than it was designed for? And I don't see any
> possibility that's as short as concat.
It's common so it must be good?
I already explained the problem with using concat(). It is intended for
concatenating strings, not cloning them. To anyone reading the code, it
looks like you made a mistake: the code does not do what it says it does.
That is a bad thing.
> Why?
If you really can't tell...I give up.
>>     tmpString
>> #end
I hope I never have to maintain anything you write...
It is longer by 5 characters, because its name says what it does. That is
a good thing. If the extra 5 characters is that bad, rename it: call it
clnstr() or something. And if you are using it multiple times, it would be
better to skip the macro completely and just use a temporary variable...in
that case, it is shorter than your misuse of the concat() function: the
usual naming convention just adds "tmp" or something similar, which is 5
characters shorter than a call to concat().
Date: 22 May 2002 14:08:26
Message: <3cebde99@news.povray.org>
Sorry, I thought of quotation marks.
In this example it doesn't make sense. MyMacro((S)) doesn't work either,
error: "Expected 'numeric expression', string identifier found instead"
>   language
> allows.
You're right. As I said, I need it for a signature, so it's important that
it's very short.
INGO, could you perhaps update the doc?
| concat(S1,S2,...)
to
| concat(S1,...)
or something similar.
Felix Wiemann
Date: 22 May 2002 14:15:21
Message: <3cebe038@news.povray.org>
ACK.
>>>     tmpString
>>> #end
If one knows that concat(S) creates a copy, it won't be a problem.
OK, *if*.
Sorry, I wrote that from my current point of view. I'm writing a signature,
so the chars needed to declare the macro (or the temporary variable) are
important, too.
Felix Wiemann
Date: 22 May 2002 14:39:44
Message: <3cebe5ef@news.povray.org>
  Well, it was just a guess from my part.
  With floating point numbers it works, but apparently not with strings.
> it's very short.
  There's probably another way of doing it without concats and locals. ;)
Date: 22 May 2002 17:58:55
Message: <3cec149f@news.povray.org>
I think this whole discussion is pointless. The use of concat() with one
parameter of course shouldn't be arbitrarily restricted, since some might
find it useful. But I think the docs shouldn't be changed either, since it
would only encourage people to make their scripts more confusing.
Anders
light_source{6#local D=#macro B(E)#macro A(D)#declare E=(E-#declare
C=mod(E D);C)/D;C#end#while(E)#if(A(8)=7)#declare D=D+2.8;#else#if(
C>2)}torus{1..2clipped_by{box{-2y}}rotate<1 0C>*90translate<D+1A(2)
*2+1#else}cylinder{0(C-v=1).2translate<D+C*A(2)A(4)#end-2 13>finish
{specular 1}pigment{rgb x}#end#end#end-8;1B(445000298)B(519053970)B
(483402386)B(1445571258)B(77778740)B(541684549)B(42677491)B(70)}
Date: 27 May 2002 03:56:55
Message: <3CF1D995.76359CAA@frege.mathematik.uni-freiburg.de>
> concat(S1,S2,...)
> feature ...
I agree this is a useful feature, although for different reasons.
Consider the following macro:
#macro reverse_string (s)
concat(
  #local j=strlen(s);
  #while (j>0)
    ,substr(s,j,1)
    #local j=j-1;
It is essential for use with the empty string that concat still works with
only one parameter. This macro is a quick hack and probably not the
best way to reverse a string, so consider it just an example.
  Mark Weyer
Date: 27 May 2002 04:10:53
Message: <66q3fucd0jm23dsdfi0jgi30qn3cto0cmq@4ax.com>
On Mon, 27 May 2002 09:00:37 +0200, Mark Weyer
  #if(strlen(s)>1)
    concat(
      #local j=strlen(s);
      #while (j)
        substr(s,j,1)
        #local j=j-1;
  #else
    s
ABX
Date: 27 May 2002 05:22:30
Message: <3CF1EDA4.6B5091DE@frege.mathematik.uni-freiburg.de>
I suppose, I did not make myself clear enough.
Of course there would be workarounds if concat(s) was
prohibited. The point is, that these are not as clearly readable
or writable any more. To provide a better example:
#macro foo_string(s)
  concat(
    #local i=0;
    #while (i<strlen(s))
      #local i=i+1;
      ,... //(do something longish with the i-th caharacter of s)
With your case distinction one would have to write the longish stuff
twice or declare a macro/function that does it.
The former is errorprone (consider changes later apllied to "...")
and not as readable (the human has to parse "..." twice).
The latter would introduce a macro/function to the namespace that will
probably never again be used and also inhibits fluent parsing by the
human.
But still, the point is not to argue over specific examples.
Concatenation is a binary operation that fulfills the axioms of monoids.
Hence it is canonically extendable to an operation taking lists of
strings as input.
As the povary team has decided to provide this generalization, it is
natural
to allow ALL lists of strings, especially one-element lists and the
empty list.
OK, I know the empty list, ie. concat(), is not permitted,
but that is a different story...
  Mark Weyer
