POV-Ray : Newsgroups : povray.beta-test : Docu Corrections Server Time
10 Nov 2026 21:19:56 EST (-0500)
  Docu Corrections (Message 1 to 3 of 3)
Subject: Docu Corrections
Date: 19 May 2002 13:25:10
Message: <3ce7dff6@news.povray.org>
Version 3.5.beta.RC5.icl.win32
6.1.6 User-Defined Functions -
Since % was removed from the syntax, please change the following:
    FACTOR:
        MOD_EXPRESSION [MULT MOD_EXPRESSION]
to:
    FACTOR:
        HAT_EXPRESSION [MULT HAT_EXPRESSION]
10.1.3.4 User defined Functions -
The note under IDENT_LIST should be updated now that the maximum number of parameters
is 56 instead of 20.
Since % was removed from the syntax, make the same change as for section 6.1.6 above.
Also remove the MOD_EXPRESSION and MOD definitions.
6.4.5 Camera Identifiers -
It appears that only transformations may be placed after an identifier in a camera
statement now.  A comment regarding this
might be added to the descriptive text in this section.  The example shows look_at
being used.  Perhaps a transformation may be
shown instead.
10.1.6 Camera -
Please change the CAMERA definition to:
    camera { [CAMERA_TYPE] [CAMERA_ITEMS] [CAMERA_MODIFIERS] }  |
    camera { CAMERA_IDENTIFIER [TRANSFORMATION...] }
Thank you.
Robert Chaffe
http://www.donovansweb.com/~chaffe/
Subject: Re: Docu Corrections
Date: 19 May 2002 13:31:54
Message: <3ce7e18a$1@news.povray.org>
Forgot one.  Also need to remove
    asc (STRING)
from the FN_FLOAT_FUNCTION list.
Robert Chaffe
Date: 24 May 2002 13:04:44
Message: <Xns9218C297DD44Eseed7@povray.org>
I'll make the changes,
Thanks,
Ingo
