POV-Ray : Newsgroups : povray.beta-test : [Linux] RC4 Command line problem with +I Server Time
29 Jul 2024 14:21:44 EDT (-0400)
  [Linux] RC4 Command line problem with +I (Message 1 to 9 of 9)
Subject: [Linux] RC4 Command line problem with +I
Date: 11 May 2002 19:38:34
Message: <slrnadra4b.tj.steve@zeropps.org.uk>
RH6.2 PII 266 320M RAM. POV-Ray 3.5 RC4.
If I don't leave a space between the '+I' and file name command
line completion doesn't work, and if I do I get the following
message.
I've read about this error quite a long time ago, but It's not fixed
yet.
[sjlen:objects]$ povray +I crater_dat.pov
This is a TIME LIMITED BETA TEST version.
Distribution in any form is EXPRESSLY PROHIBITED!
This copy expires in 7 day(s).
Persistence of Vision(tm) Ray Tracer Version 3.5.beta.RC4 Unix
(.Linux.gcc)
  This is a time-limited beta test version.  No re-distribution
   of any sort is permitted.
Copyright 1991-2002 POV-Ray Team(tm)
Possible Command Line Error: Unknown switch 'I'.
Command Line Error: Problem with command line or INI file.
                                             or http://start.at/zero-pps
 12:21am  up 22 days, 21:02,  1 user,  load average: 1.02, 1.12, 1.07
Subject: Re: [Linux] RC4 Command line problem with +I
Date: 11 May 2002 19:48:29
Message: <3cddadcd$1@news.povray.org>
In article <slr### [at] zeroppsorguk> , Steve
> message.
Read the manual to see what options you have to specify a filename.
> yet.
Because it is not an error.
    Thorsten
Date: 11 May 2002 20:48:28
Message: <3cddbbdc@news.povray.org>
> message.
  Try writing the name of the .pov file without the +I (note: the whole name,
ie. with the '.pov' ending included).
Date: 11 May 2002 20:55:48
Message: <slrnadrfa1.175.steve@zeropps.org.uk>
>> message.
And it says:
POV-Ray(1)                 Version 3.5                 POV-Ray(1)
NAME
       povray - POV-Ray: The Persistence of Vision Ray Tracer
SYNOPSIS
       povray   [+Iinput_file]  [+Ooutput_file]  [+/-option  ...]
       [INI_file ...]
  Parsing options:
       I<input_file_name> or Input_File_Name=file
              Specifies the input file to use.  If the input file
              name  is  '-',  the  scene description will be read
              from the standard input.
What am I missing here?
So why does it say it's an error?
sphere{z*5,1pigment{rgb.5}finish{reflection.3specular.5}}box{<-50,-3,-50>
<50,-2,50>pigment{checker/*\__\\__/  * \_\\__*/scale 2}finish{ambient.7}}
light_source/*__\\__\\__\\__\\__\(    ~ )\__\\__\\__\\__\\*/{<2,5,1>*4,1}
/*\\__\\__\\__\\__\\__\\__\\__\\__\~  -/__\\__\\__\\__\\__\\*//* Steve */
Date: 11 May 2002 21:08:22
Message: <slrnadrg1r.1ik.steve@zeropps.org.uk>
>> message.
That works, thanks.  But it's still a bug.
Date: 11 May 2002 21:38:40
Message: <3cddc7a0@news.povray.org>
  No, it isn't. Writing a +I alone is just not supported, period.
Date: 12 May 2002 03:56:07
Message: <3cde2017@news.povray.org>
>>> message.
> And it says:
> NAME
I said *manual* not man page!
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 12 May 2002 07:33:42
Message: <slrnadskoc.7j5.steve@zeropps.org.uk>
>>>> message.
>> And it says:
>> NAME
Man is short for manual.  And the HTML stuff isn't all that useful in a
console as I was when I came accross this bug.
Date: 13 May 2002 22:14:49
Message: <pan.2002.05.14.01.16.38.775907.8594@povray.org>
>>>>> If I don't leave a space between the '+I' and file name command line
>>>>> completion doesn't work, and if I do I get the following message.
>>> And it says:
>>> NAME
I'll fix the manual.
-Mark Gordon
