POV-Ray : Newsgroups : povray.beta-test : Buglist 22 Apr 2002 (RC2) Server Time
3 Jul 2026 20:56:05 EDT (-0400)
  Buglist 22 Apr 2002 (RC2) (Message 5 to 14 of 34)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Buglist 22 Apr 2002 (RC2)
Date: 22 Apr 2002 08:59:42
Message: <3cc4093e@news.povray.org>
> You have missed (still crashesin RC2):
> http://news.povray.org/oh5lbuc2d8t5tkfss917sfl83ovn9qmvnf%404ax.com
  I could not reproduce this.
  I tried with RC2 in Win98 and Solaris and neither crashed. Both printed:
Warning: Ken
Date: 22 Apr 2002 09:18:37
Message: <tv28cukkuer4k648ohf51v48ai2jrn4ugu@4ax.com>
> Warning: Ken
Yes, such warning was an intention but it still causes "The POV-Ray core
rendering caused an access violation problem." dialog window on my machine.
So anybody can confirm ?
ABX
Date: 22 Apr 2002 11:38:28
Message: <3CC42E75.8D15D050@gmx.de>
Warp wrote:
>   I might have missed some bugs reported since the last buglist, so feel
> free to reply with a note.
I still get a crash with the second problem from:
http://news.povray.org/3CB1B39A.3F70A85A%40gmx.de
As said in that thread this is probably due to the very long and deeply
nested function.
See also Thorsten's last reply to this:
http://news.povray.org/3cbf29d2%40news.povray.org
Last updated 20 Apr. 2002 _____./\/^>_*_<^\/\.______
Date: 22 Apr 2002 12:05:03
Message: <3CC434AF.64CA2268@gmx.de>
Yes, no immediate crash, but this waring dialog.
Date: 22 Apr 2002 12:26:53
Message: <a6e8cugc8nqj1ie5iqoj6gtvkbtoouab92@4ax.com>
On Mon, 22 Apr 2002 18:05:03 +0200, Christoph Hormann <chr### [at] gmxde>
I'm still experimenting with it and found that it not crash if it is not first
render of current instance. For example I:
1. started new instance,
2. opened empty editor,
3. pasted this script,
4. commented whole thing to behave as empty script,
5. rendered to black image properly
6. uncommented script
7. rendered to black image with #warning: Ken
When I repeat all above without steps 4-6 then it crashes.
ABX
Date: 22 Apr 2002 12:36:47
Message: <3CC43C1E.2061A543@gmx.de>
Have you tried turning your monitor upside down and walking 3 times around
the table before?
SCNR.
Date: 22 Apr 2002 13:06:15
Message: <kbg8cu8e58nmighgg54rfho4c49bn2brdk@4ax.com>
On Mon, 22 Apr 2002 18:36:46 +0200, Christoph Hormann <chr### [at] gmxde>
> the table before?
Thorsten said some day there is no magic in parser but message told me it is
an exception so I will perform this test next time :-)
ABX
Date: 22 Apr 2002 15:58:45
Message: <3cc46b75@news.povray.org>
  It would be really nice to get a short (and undivided) example code that
demonstrates this. It's not nice to have to get some include file from
somewhere.
Date: 23 Apr 2002 07:42:00
Message: <3CC54881.BC5FFDD5@gmx.de>
> somewhere.
All right, but i'm afraid it's no more that short then.
// BEGIN POV-Code
  location <0.2,0.2,-1>
  look_at  <0,0,0>
  right (4/3)*x
light_source {
  <1000, 2500, -5000>
  color rgb 1.2
#include "transforms.inc"
#declare IC_Arr=array[12]
#macro IC_Merge_Array(Array)
  #local Size=dimension_size(Array,1);
  function {
    min(
      #local Counter=0;
      #while (Counter<Size)
        #if (Counter>0) , #end
          Array[Counter] (x,y,z)
        #local Counter=Counter+1;
#macro IC_Matrix (Fn, Mtrx)
  function {
    Fn(x*Mtrx[0][0] + y*Mtrx[0][1] + z*Mtrx[0][2],
       x*Mtrx[1][0] + y*Mtrx[1][1] + z*Mtrx[1][2],
       x*Mtrx[2][0] + y*Mtrx[2][1] + z*Mtrx[2][2])
#macro IC_RotateR (Fn, Vect)
  #local Vect=Vect+<0,0,0>;
  #local Cx=-Vect.x;
  #local Cy=-Vect.y;
  #local Cz=-Vect.z;
  #local MtrxA=array[3][3]
  #local MtrxB=array[3][3]
  #local MtrxC=array[3][3]
  #local MtrxA[0][0] = 1.0;
  #local MtrxA[0][1] = 0;
  #local MtrxA[0][2] = 0;
  #local MtrxA[1][0] = 0;
  #local MtrxA[1][1] = cos(Cx);
  #local MtrxA[1][2] = -sin(Cx);
  #local MtrxA[2][0] = 0;
  #local MtrxA[2][1] = sin(Cx);
  #local MtrxA[2][2] = cos(Cx);
  #local MtrxB[0][0] = cos(Cy);
  #local MtrxB[0][1] = 0;
  #local MtrxB[0][2] = sin(Cy);
  #local MtrxB[1][0] = 0;
  #local MtrxB[1][1] = 1;
  #local MtrxB[1][2] = 0;
  #local MtrxB[2][0] = -sin(Cy);
  #local MtrxB[2][1] = 0;
  #local MtrxB[2][2] = cos(Cy);
  #local MtrxC[0][0] = cos(Cz);
  #local MtrxC[0][1] = -sin(Cz);
  #local MtrxC[0][2] = 0;
  #local MtrxC[1][0] = sin(Cz);
  #local MtrxC[1][1] = cos(Cz);
  #local MtrxC[1][2] = 0;
  #local MtrxC[2][0] = 0;
  #local MtrxC[2][1] = 0;
  #local MtrxC[2][2] = 1;
  #local fn_X=IC_Matrix (function(x, y, z){ Fn(x, y, z) }, MtrxA)
  #local fn_Y=IC_Matrix (function(x, y, z){ fn_X(x, y, z) }, MtrxB)
  IC_Matrix (function(x, y, z){ fn_Y(x, y, z) }, MtrxC)
#macro IC_Rotate (Fn, Vect)
  #local Cx=(Vect.x/180)*pi;
  #local Cy=(Vect.y/180)*pi;
  #local Cz=(Vect.z/180)*pi;
  IC_RotateR (function(x, y, z){ Fn(x, y, z) }, <Cx, Cy, Cz>)
#macro IC_Cone (Start, Radius1, End, Radius2)
  #local Start=Start+<0,0,0>;
  #local Cx=Start.x;
  #local Cy=Start.y;
  #local Cz=Start.z;
  #local Len=vlength(End-Start);
  #if (Len=0)
    #error "iso_csg.inc: Error: zero height cone"
  #local fn_T=function { Reorient_Trans(End-Start, x)  }
  #local fn_X=function(x, y, z){
    max(sqrt(y^2 + z^2) - Radius1+x*((Radius1-Radius2)/Len), -x, x-Len)
  #local fn_Y=
  function(x, y, z){
    fn_X(fn_T(x, y, z).x,
         fn_T(x, y, z).y,
         fn_T(x, y, z).z)
  function {
    (fn_Y((x-Cx),(y-Cy),(z-Cz)))
  function {
    min(
      #local Counter=0;
#declare IC_Arr[0]=IC_Cone(0, 0, x+y, 1)
#declare IC_Arr[1]=IC_Rotate(IC_Arr[0], 30*z)
#declare IC_Arr[2]=IC_Rotate(IC_Arr[1], 60*z)
#declare IC_Arr[3]=IC_Rotate(IC_Arr[2], 90*z)
#declare IC_Arr[4]=IC_Rotate(IC_Arr[3], 120*z)
#declare IC_Arr[5]=IC_Rotate(IC_Arr[4], 150*z)
#declare IC_Arr[6]=IC_Rotate(IC_Arr[5], 180*z)
#declare IC_Arr[7]=IC_Rotate(IC_Arr[6], 210*z)
#declare IC_Arr[8]=IC_Rotate(IC_Arr[7], 240*z)
#declare IC_Arr[9]=IC_Rotate(IC_Arr[8], 270*z)
#declare IC_Arr[10]=IC_Rotate(IC_Arr[9], 300*z)
#declare IC_Arr[11]=IC_Rotate(IC_Arr[10], 330*z)
#declare fn_XX= IC_Merge_Array(IC_Arr)
isosurface
  function { fn_XX(x, y, z) }
  max_gradient 1.6
  contained_by { box { -2, 2 } }
  pigment { rgb <0, 0.2, 1.1> }
  finish { specular 0.3 }
  scale 0.1
// END POV-Code
Date: 23 Apr 2002 10:19:42
Message: <8vqacu4as77ojv54hshn94rdn4b4ar9u60@4ax.com>
>  Officially confirmed bugs:
Probably nothing to worry about but ... In changes.txt there is note about
Change 1523 : "Partial fix for radiosity recursion problems" in RC2 section.
If it is a partial fix then there must be something left still not work. But
there is no note in your list about anything like official not fixed bug in
radiosity.
ABX
