POV-Ray : Newsgroups : povray.beta-test : Buglist 22 Apr 2002 (RC2) Server Time
3 Jul 2026 19:32:03 EDT (-0400)
  Buglist 22 Apr 2002 (RC2) (Message 15 to 24 of 34)
Subject: Re: Buglist 22 Apr 2002 (RC2)
Date: 23 Apr 2002 11:01:12
Message: <3cc57738@news.povray.org>
Ok, noted. (Although a shorter example would have been nicer...)
Date: 23 Apr 2002 11:11:32
Message: <3cc579a3@news.povray.org>
Curiously it doesn't crash in the unix version...
Date: 23 Apr 2002 11:16:31
Message: <dkuacusdpe57c3blp8a5fh6rsngtibui34@4ax.com>
Confirm crash of this shorter version of script on
POV 3.5 RC2 icl on WinNT Sp 6 PII 233 with 128 MB
ABX
Date: 23 Apr 2002 12:30:31
Message: <3cc58c27@news.povray.org>
Skiba <abx### [at] babilonorg>  wrote:
> Probably nothing to worry about but ... In changes.txt there is note about
> Change 1523 : "Partial fix for radiosity recursion problems" in RC2 section.
> If it is a partial fix then there must be something left still not work. But
> there is no note in your list about anything like official not fixed bug in
> radiosity.
Because there is change 1526...
    Thorsten
e-mail: tho### [at] trfde
Date: 23 Apr 2002 12:44:55
Message: <0i3bcu4pte94ifedlcn2u2eqipbrc41dqc@4ax.com>
On Tue, 23 Apr 2002 18:30:26 +0200, "Thorsten Froehlich" <tho### [at] trfde>
Then the name of 1526 fix should be fixed to "Final fix for radiosity
recursion problems" in next RC then ;-)
YKIHBRTL
Date: 23 Apr 2002 13:05:59
Message: <el4bcugnvpi6g74lm0od6etuiutme91vn7@4ax.com>
On Tue, 23 Apr 2002 13:41:53 +0200, Christoph Hormann <chr### [at] gmxde>
wrote:
> All right, but i'm afraid it's no more that short then.
After walking around rotated monitor I have good news for you Chris :-).
On my tests crash disappear when sequence of:
> #macro IC_Matrix (Fn, Mtrx)
> #macro IC_RotateR (Fn, Vect)
> #macro IC_Rotate (Fn, Vect)
is replaced with short
  #local f_T=function{transform{rotate -Vect}};
  function{Fn(f_T(x,y,z).x,f_T(x,y,z).y,f_T(x,y,z).z)}
It not changes that your macros shouldn't crash however you can make stable
version. I think in correct form it shuld rather
transform{rotate Vect inverse}
ABX
Date: 23 Apr 2002 13:13:29
Message: <3cc59639@news.povray.org>
No, because it did not fix the problem, it simply restored the old behavior.
The changes which caused the problems were made because some other part was
using much more stack space then really necessary.  The best solution was to
move some arrays that were allocated on the stack into arrays allocated in the
heap and to add a pool that prevents frequent (and thus time-consuming)
allocating/freeing.  The side effect of this is that more layers are now
supported in texture tests (which is noted in the same change).  So fixing one
bug (http://news.povray.org/povray.beta-test/21445/) adds a feature as well
    Thorsten
Date: 23 Apr 2002 13:15:45
Message: <3cc596c1@news.povray.org>
In article <3CC54881.BC5FFDD5@gmx.de> , Christoph Hormann
I found the problem.  There currently is no workaround other than using less
complex functions.
In fact the problem is fairly serious but random in nature because it is
related to a changed pointer returned by a realloc() not getting used
everywhere...
    Thorsten
Date: 23 Apr 2002 14:32:32
Message: <3CC5A8C0.5E74D59B@gmx.de>
Nice.
> everywhere...
Does this mean it will be fixed in next beta?
Last updated 20 Apr. 2002 _____./\/^>_*_<^\/\.______
Date: 23 Apr 2002 15:32:43
Message: <3cc5b6db@news.povray.org>
In article <3CC5A8C0.5E74D59B@gmx.de> , Christoph Hormann
Of course :-)
    Thorsten
