POV-Ray : Newsgroups : povray.beta-test : [Linux Beta] Partial Render Statistics? Server Time
10 Nov 2026 21:50:07 EST (-0500)
  [Linux Beta] Partial Render Statistics? (Message 1 to 7 of 7)
Subject: [Linux Beta] Partial Render Statistics?
Date: 3 Apr 2002 09:04:00
Message: <3cab0bd0@news.povray.org>
When you abort the rendering pov-ray 3.1 gives a statistics about the
partial image which was rendered but version 3.5 just aborts without this.
Any reason for that?
3.5.beta.15 Unix (.Linux.gcc), Linux, Pentium III
objects.povworld.org - The POV-Ray Objects Collection
book.povworld.org    - The POV-Ray Book Project
Subject: Re: [Linux Beta] Partial Render Statistics?
Date: 4 Apr 2002 05:42:12
Message: <slrnaaoaeh.u1m.steve@zero-pps.localdomain>
Same here, both with Ctrl-C on command line and with "q" in render
window.  But I never really thought of it as a bug before, just
tried 3.1g and there is some useful info that it spits out when you
abort, so maybe it is a bug.
Here is the extra info I get with 3.1g, I've shortened some lines in
the output below:
Rendering...
Got 1 SIGINT.
Aborting render...
email.pov Statistics (Partial Image Rendered), Resolution 800 x 600
Pixels:            5689   Samples:            5689   Smpls/Pxl: 1.00
Rays:             11378   Saved:                 0   Max Level: 2/15
Ray->Shape Intersection          Tests       Succeeded  Percentage
Box                              39823            5689     14.29
True Type Font                  102402               0      0.00
Calls to Noise:                  0   Calls to DNoise:             10
Shadow Ray Tests:            28445   Succeeded:                    0
Reflected Rays:               5689
Smallest Alloc:                 10 bytes   Largest:            16028
Peak memory used:           147900 bytes
Time For Trace:    0 hours  0 minutes   4.0 seconds (4 seconds)
    Total Time:    0 hours  0 minutes   4.0 seconds (4 seconds)
User abort.
#local i=.1;#local I=(i/i)/i;#local l=(i+i)/i;#local ll=(I/i)/l;box{<-ll,
-((I/I)+l),-ll><ll,-l,ll>pigment{checker scale l}finish{ambient((I/l)/I)+
(l/I)}}sphere{<i-i,l-l,(I/l)>l/l pigment{rgb((I/l)/I)}finish{reflection((
I/l)/I)-(l/I)specular(I/l)/I}}light_source{<I-l,I+I,(I-l)/l>l/l} // Steve
Date: 5 Apr 2002 09:55:53
Message: <3cadbaf9@news.povray.org>
> the output below:
> Rendering...
> Got 1 SIGINT.
> Aborting render...
> User abort.
That is exatcly what I mean. Can we have this as well in POV-Ray 3.5?
I do not want to be finical, but Steve, if your signature would be
correctly seperated by "-- " from the text then my newsreader could
identify it as signature.
Date: 6 Apr 2002 17:43:30
Message: <slrnaauuev.amn.steve@zero-pps.localdomain>
Something I've never understood is why that doesn't work, I've even
marked and copied other people's -- signs, but it makes no difference.
Date: 6 Apr 2002 22:16:46
Message: <kcevau0krpe3feltnfaib44klbo1lct1cu@4ax.com>
  It works for me if a 'whitespace' is added after the 'dashes'. Give it
a whirl.
Alan
ako### [at] povrayorg
a k o n g <at> p o v r a y <dot> o r g
Date: 7 Apr 2002 10:51:35
Message: <3cb05cf6@news.povray.org>
Now your signature is displayed correctly with me. :) The important thing
is the whitespace after the --.
Date: 8 Apr 2002 02:17:37
Message: <slrnab1f0j.nfm.steve@zero-pps.localdomain>
Thanks both to Alan and yourself this is now fixed.
sphere{z*5,1pigment{rgb.5}finish{reflection.3specular.5}}box{<-50,-3,-50>
<50,-2,50>pigment{checker/*\__\\__/  * \_\\__*/scale 2}finish{ambient.7}}
light_source/*__\\__\\__\\__\\__\(    ~ )\__\\__\\__\\__\\*/{<2,5,1>*4,1}
/*\\__\\__\\__\\__\\__\\__\\__\\__\~  -/__\\__\\__\\__\\__\\*//* Steve */
