POV-Ray : Newsgroups : povray.beta-test : Stattering Message Window Server Time
10 Nov 2026 21:59:59 EST (-0500)
  Stattering Message Window (Message 1 to 15 of 15)
Subject: Stattering Message Window
Date: 18 Mar 2002 05:34:21
Message: <3c95c2ad@news.povray.org>
-Hail
  I am experiencing randomly repeating messages on my messages window when
it shares the window with the editor.
 Pentium2 - Win2k, Pov beta13
Subject: Re: Stattering Message Window
Date: 18 Mar 2002 05:43:48
Message: <73hb9usgv7ndqjosp83qtp7kuh552iorlk@4ax.com>
On Mon, 18 Mar 2002 04:33:18 -0600, "Vampyrium" <cyb### [at] hotmailcom> wrote:
Confirmed. I've experienced the same. I wondered how to describe this
appearance and it fits best in above description.
POV 3.5 b 13 icl on WinNT Sp 6 PII 233 with 128 MB
ABX
Date: 19 Mar 2002 10:44:11
Message: <3c975ccb@news.povray.org>
Can you please post a screenshot in p.b-t.b.
-- Chris
PS are you sure this isn't just happening during scrolling ?
Date: 19 Mar 2002 11:15:00
Message: <lpoe9ukm1npfaqfcqmfnmglrvu89okhn51@4ax.com>
On Tue, 19 Mar 2002 13:42:37 +1100, "Chris Cason"
It happened for me under 95 at home so I have to go there to get screenshot.
If you mean scrolling by user it is not my case - it was during automatic
scrolling .
ABX
Date: 19 Mar 2002 15:57:42
Message: <3c97a646$1@news.povray.org>
Try setting GUI priority to 'highest' and see if that stops it.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 20 Mar 2002 02:14:09
Message: <3c9836c1@news.povray.org>
-Hail
  Setting GUI priority to highest stops the problem for me.
Date: 21 Mar 2002 08:52:29
Message: <3c99e59d@news.povray.org>
> scrolling .
If you mean during message output, then this can be considered normal (were
you rendering an animation? during animations a 'fast scrolling' mode is now
enabled).
Date: 21 Mar 2002 09:02:25
Message: <flpj9u0snbj4fob1h2tusuhul10v8j38bm@4ax.com>
On Fri, 22 Mar 2002 00:47:31 +1100, "Chris Cason"
> > scrolling .
yes
I see. To be sure I'll test it again when I'll be at home.
ANX
Date: 21 Mar 2002 10:46:06
Message: <pnvj9ucl99lb7tpf6uqunomv7j7kj29jio@4ax.com>
> enabled).
I've found this behaviour on 3.5 b 13 icl on WinNT Sp 6 PII 233 with 128 MB.
It isn't animation. Two images after moment in p.b-t.binaries:
pane.png shows what appear in message pane and window.png shows what is
displayed after jump to message window. So, should this be considered normal ?
ABX
Date: 23 Mar 2002 21:06:14
Message: <3c9d3496@news.povray.org>
"W³odzimierz ABX Skiba" <abx### [at] babilonorg> wrote in message > I've found this
Can you point me to the scene file that demonstrates this ? (I know it's not
a scene fault, but I want to re-create the exact circumstances of the
problem).
-- Chris
Date: 25 Mar 2002 03:09:56
Message: <dkmt9u8u4q83eb51fq6dqon0lf7b6q9np0@4ax.com>
On Sun, 24 Mar 2002 13:07:58 +1100, "Chris Cason"
> "W?odzimierz ABX Skiba" <abx### [at] babilonorg> wrote in message > I've found this
> problem).
I have changed this source a lot, but when I'll find this again I'll save
screenshots and scene file. Do you need some part of registers or other saved
configuration ?
ABX
Date: 25 Mar 2002 04:35:57
Message: <ekrt9ukrac1bq2c1vet027bp1te0e9i1b7@4ax.com>
On Mon, 25 Mar 2002 09:09:17 +0100, W�odzimierz ABX Skiba <abx### [at] babilonorg>
> configuration ?
Ok. Freash installation on POV 3.5 b 14 icl on WinNT Sp 6 PII 233 with 128 MB.
Just +FN switch added. All switches are listed on screenshots. Scene file on
screenshot and as attachement after moment in p.b-t.binaries.
ABX
Date: 25 Mar 2002 10:01:17
Message: <3c9f3bbd@news.povray.org>
MB.
on
ok, I rendered this exactly as per your example, and the problem does not
occur
for me. Perhaps this is an NT v4 issue ? (though I can't think of why it
should be,
since I do the drawing myself within POVWIN).
can you try it on another computer ? does it happen with the VC6 version ?
-- Chris
Date: 25 Mar 2002 10:13:11
Message: <rcfu9uck5d3hfdq1gh5h2sv1qau7652ehs@4ax.com>
On Tue, 26 Mar 2002 02:03:01 +1100, "Chris Cason"
> ok, I rendered this exactly as per your example, and the problem does not occur
> for me. Perhaps this is an NT v4 issue ? (though I can't think of why it should be,
I have not tested this particular example on any other computer machine yet
but similiar things happens to me at home on 95 iirc
yes. I just tested this and example I posted you makes the same appearance as
I posted. But when I changed source to
  plane{
  z,0
  finish{ambient 1 diffuse 0}
  pigment{function{x}
  scale .35
  translate z*10
then bug dissapeared. Switching between these two scripts shows and hides this
bug.
ABX
Date: 25 Mar 2002 12:29:41
Message: <o9nu9us44bm2i72b01vnafe6c5jg2n75jr@4ax.com>
I just tested this on two other machines
POV 3.5 b 14 icl on WinNT on dual P4 ~1 GHz with 1 GB
POV 3.5 b 14 icl on W2000 on mono P4
I couldn't replicate this behaviour on both.
Do you need additional informations about my PII or NT4 ?
ABX
